Everything posted by SoobGoob
Abs and at CEL after battery change
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks somick, I tried waiting with key on before starting but I will try again today. Maybe I didn’t wait long enough.
My uncle bought a 2010 outback 2.5 auto, which shortly after the battery went bad. He had it replaced at Autozone and after the replacement it started throwing three codes. u0122 lost communication with VDC module P0700 trans control sys (mil requested) P1718 DTC definition not found occasionally I get a wheel speed sensor code but I can’t remember which circuit Symptoms are ABS light on, at temp light flashing, won’t shift back into park from drive. Hard start, starter almost feels like it sticks. battery is a cheap econo whatever. Seller offered to cover labor at shop, they plugged in diagnosed the abs pump swapped it and there was no change. The shop was down the street from me and he asked if I could store it for a bit so I’ve been working on it. All of the problems started when the battery was replaced. work/diagnosis I’ve completed. Reset computer multiple times. Cleaned grounds. Tried larger interstate battery. Checked all fuses and fuse voltage drop test (all good). Charged battery. Voltage good, alternator charging. Swapped back in known good abs pump. Idled it for a while. Drove it around the neighborhood but not on freeway. Looked for loose connections. It about to go to the dealer unless anyone here has any insight, it seems to be a common problem but with no common solution. Thanks all!
Secondary air pump delete
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX@GeneralDisorder I just ordered 4 valves 8 guides and 16 seals through the machine shop totaling only 120 bucks. This seems like it will be much easier a job than the delete and cheaper. Thanks for your input, hope all is well!
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this the valve grind job with a drill I’ve read about? I would love to do just the 4 valves and sell off the extra heads I purchased.
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe only machine shop in bend is weeks out on any head work at all. Is replacing valves easily done? That is one job I have not done yet
Hey everyone it’s been a long time since I’ve needed to ask for advice! I currently am working on a 09 forester xt i picked up cheap with a slipped timing belt. Drivers side exhaust valves are bent. I picked up a pair of good second hand heads but they are pre secondary air pump. I see this is a common delete with this engine but my big question is, will it run without having the ecu reprogrammed? I understand i will have a CEL. I will get the reprogram done but I need it to at least be able to drive out of my shop and the 25 miles to home. Thanks all in advance for the help!
Ea81 head interchangeably
Oh and this brat is completely rust free, even the bed still had all of the factory paint
There is a good chance he has the year wrong, it is definitely a turbo. I looked it over it has the correct mirrors, trim, engine, etc. I do have the mechanical knowledge to do the work required (thanks Rick). If the heads are cracked can they be repaired? Also what is the likelihood they are cracked? Same as every other Subaru? I know these early turbos have a unfortunate disposition. Oh and they didn’t specify the condition of the head, it was a son talking for his father who had bought it but then couldn’t find a head. So it may be a head gasket or a bad head.
Patiently waiting for @GeneralDisorder to fill me in.
Hey everyone, long tim since I posted on here, maybe 10 years. Glad to see this forum is still around and hopefully not full of all the kids that used to own civics that switched to Subaru’s. The reason for today’s visit is that while pulling parts for my brothers truck I happened across 3 brats on a farm property, 2 standard 4wd ea81’s with a topper mostly in good condition. But inside the old auto shop next to the paint booth for the last 20 years sat a dusty but clean and straight 1986 turbo brat with 82k on the clock. Parked due to a bad head. I have the right of first refusal at a good price but wondering if the turbo heads are different from the na engines? I know these cars aren’t the pinnacle of reliability but Ive always wanted a brat (not an auto though) anyway. That’s my question! and for those who skip to the end. 1. can I use na ea81 heads on a ea81t motor? 2. if not, who has a set they would sell me?
legacy and forester part interchangeability
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI read online on some compiled brake info the gt rear brakes are larger than my rear brakes? Is this not true? Like I stated it is a forester s so it does have disc. Thanks numbchux
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry idosubaru I didn’t have the year when I posted. I do now, it is a 98 Gt limited. From what I’ve read the front brakes are the same but the rears are larger. I’m mainly looking for upgrade parts.
hey all, been a long time living in the toyota world. recently purchased a 2001 forester s for commuting. also recently my friends 2nd gen legacy gt got hit by a drunk driver and is destined to the scrapper. he gave me the go ahead to swap whatever i feel i want. obviously the gt wheels are the first grab, beyond that im not sure what else will fit. so thats what im wondering, if anything else between the 2 platforms will bolt on? hopefully the larger rotors and calipers? cheers
help with a new to me ej20t forester
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate: got under it today armed with some soapy water and found one small exhaust leak at the bottom of the uppipe. I'm going to replace all of the exhaust gaskets on the front. Took off the intercooler visually inspected for any leaks and made sure everything was tight at reinstall. Cleaned the iac and the throttle body. Found a digital boost controller under the dash, hooked back up, found turbo timer and hooked back up but car won't stay running after I turn it off. Found TD04 turbo from wrx. Found greddy fuel management system with "active" light lit. Going to get all the manuals for these items before I fudge with it. I'll keep you updated after I replace the exhaust gaskets. Would even a small exhaust leak make a difference? Also noticed on the boost gauge that I never boost over 7-8 psi
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHappy holidays guys. Haven't had a chance to check much with Christmas and such. Will take a look tomorrow and see what I can find. Wtdash as for the hesitation issue it's definitely not turbo lag. It's more like I have a leak somewhere causing positive air to escape and high pressure. I would describe it as a "shudder" during positive pressure/High revs/acceleration. Also noticed a popping sound when I let of the gas at higher revs, so I'm thinking it's either running rich (can smell unburnt petrol) or exhaust gaskets are bad on the heads. Thoughts?
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh also, yes the CEL comes on at bulb check. But not after engine is started
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn going to test for vacuum leaks soon. Is maf cleaner sprayed around the engine looking for revs still the way to go on a turbo engine? I will also check the piping this afternoon for any leak, should I use the same method or do a visual inspection/make sure everything is tight? This engine has a coil pack not coil on plug. I am also experiencing pretty poor fuel economy, I haven't done the math yet but it seems that way. As for driving on the other side of the road, holy crap. I always thought to myself "I can drive a RHD car on the left, easy. But when you find yourself coming to an intersection and you know it's just reverse of how it usually is, it can still throw you for a loop. Plus the wipers and turn signal stalks are swapped so I find myself turning on the wipers a lot instead of the signals hahaha. Checking for your blind spot is weird. Overall, it's all weird. Like learning how to drive all over again.
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry there wasn't supposed to be a comma. No cel, no codes being thrown. It has roughly 160k
SoobGoob replied to SoobGoob's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh also there is no CEL, code being thrown. Cheers
Hey all! Been a long time since I've been on ultimate subaru! Fell in love with my 4Runner years ago and until yesterday didn't own another subaru. So long story short is I am from Portland Oregon but currently living in Melbourne. I purchased a used 1999 forester gt with a ej20t in it. The car overall is in decent shape, runs alright except for 2 things. Sometimes it idles low and a little rough. Usually after speeds of 100k/hr. Which lead me to believe the maf. So I took the pod filter off and refitted the stock air box with a new filter and cleaned the maf. Not much changed but at least it's not pulling in hot engine air anymore. The other symptom is when I'm accelerating a little hard and the turbo starts to go positive, it's not a smooth acceleration. There's a little bit of a "hesitation" or "chug" I'm not quite sure how to describe it. I'm not very familiar with turbo engines, the only I've owned until now being the legacy sport sedan general disorder now owns. But I never drove it lol. Gotta love projects. If there's any regular servicing of the turbo system I should do immideatly that would also be handy info. Thanks all! Glad to be back
Loyale windows won't roll down
Thanks for the help everyone I will look into those. If one windows motor goes out will the rest not work? Because none of them are working. I will check the **** under the drivers seat. (relays I think he meant) and the wiring at the drivers door. I did also hear buzzing when trying to roll any of them when the stopped working at first. Couldn't tell where it was coming from. Front passenger compartment comewhere
I replaced all three relays under the passenger seat. And the drivers door switches with a known good one. Fuse is good and I get nothin when I push the buttons.
Need carb help
i see them on ebay but havent bought one yet. i went out and got a book for my car first not looking forward to working on this carb. might buy a webber kit instead
Ea82 that offered 2wd and rear disc?
Finding turbos at the junker is easy. But a 2wd turbo is hard. I am gonna buy the hubs to swap my 77dl to rear disc. Anyone have a part number
Does anyone know what model gl10 or any model/year that offered rear disc and was 2wd. If available at all. I need those hubs and am just going to try to order them. Need to know years/models that had these. Thanks!
