RainbowRoo
Everything posted by RainbowRoo
  1. Hey, a picture would be great. Mine needs the same done.....my nose is way too, low.
  2. This is the stuff I use. Not as cheap as it used to be. I put it on the driving lights, headlights and fog lights. Works great. The company I used to get it from only sells it inthe 100 foot roll, now. So, I hope this stuff works as well. http://www.envision-graphix.com/PRODUCTS/Lamin-X/Lamin-X.htm
  3. Sent you a PM for a roof rack.
  4. I am planning on getting a stock K & N filter, and was wondering about sticking some holes in the air cleaner cover, and then maybe a small hood scoop. Have any of you ever done this and or have a opinion? Not really interested in putting on a weber. My goal is a a little better preformance. On the 86 EA82 Wagon...4x4...."old speed"
  5. Custom bumpers... Roof racks... and I will second the high colsole/center armrest.
  6. And pretty expensive for yard art.
  7. Over his father's dead body.. ..It is parked in my yard after all... ..It is a nice little car and would make a good daily driver. ...Since the rest of what he has is tweeked, I have advised him to hang on to it, something dependable to drive in the rain.....but what do I know.....I am only the DAD:rolleyes: .
  8. Welcome, Only one Subaru, how is that possible.......
  9. Yes, you may very well be right. But it would have been a progessive, problem. So getting the right horse shoe (lift bracket) should take care of the preload. It did not start out doing it when I kicked the tire. It has been getting worse over time, started with a little noise, and now a whole lot, resulting in, now when I kick the tire it does it, did not make that noise before. So, with the correct bracket, I will be able to replace the shock/struts and that should take care of it, the later part of the racket.
  10. RainbowRoo (William), If your rear horseshoes look like this (side view): | | . \ . . \ Okay, this is the one I have. I will pm.....
  11. It is more of a metalic squeek...sounds like it is coming from the body. I have check the torque, on the bolts since installation. And if you kick the side of the tire, it will cause it too, squeek too. During install, I took loose the bottom of the shock/strut. And it was preloaded out about 4 inches. And yes, this is a PK lift. 3 in. It is just annoying as all get out..... I want to get new springs and struts in the rear, but not till I know what it making this noise.
  12. The rear shocks/stuts on my wagon make a heck of a squieking noise with the lift kit on? Even going driving on pavement. :-\ Anybody else have this problem and a fix???????
  13. Both of my XT's have the telescoping wheel, so they will not fit on a 86 GL Wagon???.
  14. I have the stock, in the wagon now (what I would call a "A") and want to put the XT "parts car" (upside down "L" shape) one on the it. Not that there would be a color match, but as you can see I would not be worring about that. I have blue seats in the thing, for gooness sake. Thanks.
  15. Hi, Son, Maybe you should also check into the oil cooling if you have not already, I am going to do that with the turbo. Love, DAD
  16. 1) What is "bump"..?.:-\ .?....you all use it, all the time and could not find it in FAQ's. Is it that you sent a private message????????? 2) will a XT steering wheel fit on a EA82 Wagon?
  17. EVIL, TRULY, EVIL To play with ones, hopes and dreams.
  18. Now, that took some serious work. Good job.
  19. Yellow, I would go with YELLOW.... ...okay, okay, just kidding.
  20. Okay, no expert here, but which cat is bad. Here is where I got mine....for the 86 Wagon. It had not heat sheilding on it but neither did the one I took off. It was running like a dog:( , before the new cat. I have had the new one in for about a year and a half. http://www.cheapexhaust.com/
  21. No, problem stop on by, Tubone. And Son, if you do not behave you will be driveing the 65 Toyota.....
  22. I was going back and forth from e-bay to the board...watching to see if someone found it and put it on here.....I was sweating it. Would have paid more, but did not really want to, after buying the 87 earlier in the month, I have gone way to far into the auto spending budget....
  23. 972 of those 8-tracks on e-bay.....bet you can even get "Saturday Night Fever"
  24. Yes, well. He did forget to mention that it had a cracked windsheild, and had not been cleaned inside, since it was new. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7962298646&sspagename=STRK%3AMEWN%3AIT
