18
Thats true, With 210,000 is it worth dumping cams in it? How much slop is in the crack after all these miles? I suppose, I don't have any blow-by (From rings or valve seats) no ticking or knocking, so it might be worth it. I think I better put a new waterpump and timing kit on this thing first, running on stuff found in MilesFox's garage
Rust.... and work on Mtn Grizzly
TheLoyale replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Pics! ? -
Yep, thats the typical issue with the covers. The sleave is only pressed in and has a rough mating surface. But with age thye break loose and the bolt gets stuck. Sometimes the bolt can be very hard to unscrew from the sleave (I tested one old one I had once) Had to use a vise and about 15lbs of force to break the bolt loose. You can always leave the rear half of the covers on (Like I did) it helps keep stuff out. I don't know to many folks that have had issues with stuff getting onto the belts (Rocks etc) If you really want to run th covers, you can zip-tie them on if you still have a few holes that aren't broken off. -Tom
If you dripping oil its either coming from the Oil Pump seal and O-ring (Micky Mouse seal) or the cam seals/o-rings (Or both) this will cause lower oil pressure, or your sending unit on the front of the oil pump is getting old. If you going to do Timing belts then since you are in there, I would get a new waterpump and seal, New By-pass hose for the top of the waterpump, New oil pump and seal kit, Fel-pro Cam carrier seals, and new Timing tensioners (If yours sound like Skateboard wheels, it is time to replace them) Check out Rockauto for this stuff, or you can get a Timing kit off ebay for $120 IIRC. If you do all this, then you will have no worries with this engine for a long time. Also, leave the timing covers off, makes it way easier to re-tension the belts and check them. Plus next time you replace them, you don't have to pull the Crank pulley. If your oil pan gasket has some sepage, just torque the bolts a little and see if it helps. Cheers, -Tom:)
This has nothing to do with the thread, but it is my thread, so I'll post in it what I'l like. Lol
Yes, I live by that. I have twisted the heads off hot bolts to many times. I hate when you just feel it give, your like OMFG! As for the camber bolts in the rear, I am pretty damn sure they were, I am trying to remember, but I think they did have a lump on one side. I do remember marking them for a reason. All this stuff looked factory too, I don't think anyone ever took this car to a shop or the dealer for servicing
Yeah I know a 5spd is the way to go, Maybe some day eh.. Once this 4EAT takes a crap (If it ever will) Oh wait, maybe I have to drive my car like all these other dumb kids, making the trans work very hard to shift, I always make sure the tranny wants to engauge smoothly even at red-line shifts, I will back off the throttle just a fraction so it will glide in rather then struggle. I hear a lot of dumb kids drive past my house and just how they don't treat their car well. This kid that lives kiddie-corner from me has a '01 Mirrage sedan with a fart-can on it, he trys to make it sound like its stick, he'll punch it then back way off the gas then hit it hard again (For a delay sound) thats not the way you treat an auto, your making it work extra hard that way DUMB KIDS, OMG!
Lets see your before and after photos
TheLoyale replied to Mr. Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Its the magic of Administration
