RAYJAY
Everything posted by RAYJAY
  1. the 80's also ..... hey guys we're showing our age with tis conversation ..... lol obd II was a standard so all car makers had the same codes and interface system not like obd I which was manufacture related, Jeff
  2. its the credit from where the original poster got the write up from fyi and the 2nd O2 sensor was installed originally because of so many of us removing the cats on the OBD-I cars from the early 90"s ....any one rember a test pipe ..... lol jeff
  3. Credit for the original fix goes to Peaty of Scoobymods. If you have an upgraded or aftermarket exhaust installed, you might get the P0420 CEL since the rear O2 sensor is seeing more flow and thinks something is wrong with the catalytic converter. By installing a rear O2 spacer, you can reduce the amount of flow the rear O2 gets, and stop the CEL. Once again, I am not responsible for anything you do to harm anything or anyone. Tools needed: -22mm wrench (or 22mm open sided socket w/ breaker bar) -1/2 inch drill bit -1/4 inch drill bit (anything in this range will work; you just need to open up the second spacer for more flow) -Drill (drill press would be way easier) -Vice -Jack/jackstands Items/Materials: -Help! Spark Plug Non-Fouler part # 42002 (#42009 works as well) -PB blaster (if you can't get the sensor out) -30 minutes (you'll never get this back) found here with pictures http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=14675&start=0
  4. done it on my 04 gt 20,000 mile ago, not a problem in the world and the 2004 gt have the Cali emissions on it converters are high $$$$$$$$$ Jeff
  5. year ??? new ? used ??????? you can get different model info at http://www.cars101.com/ Jeff
  6. sears now makes a 1/2 c3 impact gun http://www.sears.com/shc/s/p_10153_12605_00917090000P?keyword=c3+1/2%22+impact
  7. http://www.cars101.com/subaru/forester/forester2003.html 03 was a major make-over for the Forester a few things new on all models All new Dashboard All new Center console re-designed with 2 cupholders Hill holder clutch is back! (manual only) Side airbags standard on all models Dual stage deployment front passenger airbag Aluminum alloy hood (lighter weight) Aluminum alloy rear gate (lighter weight) Counter balanced glove box (easier open) Dual vanity mirrors Dual overhead console bins Fuel door release lever Larger disc brakes Illuminated power window switches Accessory plug in console plus dash lighter plug Re-designed driver's seat with greater height adjustment range Tilt wheel has larger range No passenger door key, key works on driver's door only (and remote entry is std on all models) new on X (only $250 more than 02 L) X model replaces L 16" wheels (were 15") Keyless remote standard (was optional) Variable delay front wipers (replaces single speed) Rear window wiper de-icer CD player/AM/FM/Weatherband standard (no cassette avail)
  8. have the AC and use a tree .....
  9. you can off set the 16 ' wide door to help on having a shop area on one side , the single door will help you not having the center piller so once you pull in you can park the car to the side, and a 24 x 28 to me is only big enuf to work on one car at a time, Keith if you need more info or idea's great site there a little snobbish over there snap-on or die lol but some great ideas on buliding and outfitting garages. and hi to another Pa person on the northeast side http://www.garagejournal.com/forum/index.php?
  10. he right about the epoxy and yes it will chip and peel, I use a beir solid floor stain easy to clean and yes it will wear off but its super easy to recoat every couple of years tried to post the pictures here but there uber large here ias a link to my write up on the beir stain http://www.garagejournal.com/forum/showthread.php?t=4708&highlight=beir link to all my garage pictures http://www.speedfreaksgarage.com/jeff/GARAGE%20FLOOR%20REDONE/
  11. what is a liter = http://en.wikipedia.org/wiki/Litre and 1 liter = 0.264172052 US gallons so 60 Liter = 15.85 US gallons
  12. i picked up the bolt drawers about 10 years ago, the wife ***************ed me out about them..... until i repainted and started to use them then it was a good idea. the slat wall i got on a deal about 10 years ago also. I must have bought 25 sheets of it brand new with enuf drop ceiling to do my basement for around $200 bucks they were building a mall around here then and both item came in the wrong color ....... i always look for a steal .....opps mean a deal ....
  13. ok here is my set up pictures are a couple of years old, have added some more equipment since then.....
  14. over on mud's site http://forum.ih8mud.com/tools-fabrication/257801-welding-upsidedown-whats-secret.html i just do spot welds and keep filling it in
  15. 900 lb per inch .......... a air impact rum at 450 to 800 Ft pounds your impact gun runs about app. 75 ft lbs To convert foot pounds to inch pounds, multiply by 12. To convert inch pounds to foot pounds, divide by 12. Jeff
  16. A little off topic but looking at the kits now ,I have 71,000 on my 2004 gt 2.5 sedan non turbo should i do the timing belts now or wait till about 90,000 ??? or just do the coolant flush and thermostat change? Jeff
  17. Hi i have a 2004 LGT factory tire is 205/55/16 i have abrand new set of fuzion HR1 in size 215/60/16 will this size fit / has any one tried it yet Jeff
  18. If you bought the paint local the paint shop will sell you the right reducer for your weather conditions you will have to let them know the temp of the garage and humidity levels you will be painting in , one good thing about painting now no bugs in the paint..............lol Jeff
  19. the q123 are the right wire set for this car figure i would post if any one else need the info
  20. jason is on vacation till next week the parts guy is ordering a set of the Q123 in to see if there the one's I need. as for production date of car the vin is telling them the date is 1 of 2004 has any one seen screwups on parts and productuion date before ???? and is there any difference with the car being a gt over a regular L model Jeff
  21. hi all i don't know if I'm in the right area of the forum for this post if not please move it to the right area . now my problem I have a 2004 legacy gt 2.5 motor atx cali emissions ordered my wires from jason at audburn Subaru (great guy) my car has all 4 wires the same length (19.5 ") the set i got (Part numberSOA430Q119) has 2 wires 16.75" and 2 wires 21.5" long any idea on the right part number for this car? Jeff
