Everything posted by subaru360
Superoo 72 GL racecar
Midcoast or Downeast. I've looked at a few houses in or near Belfast so far.
Hopefully Maine. The house I really wanted half a block from the ocean sold recently before I got enough money together.
I haven't posted here a lot lately. This car was a lot of fun to work on. I only drove it around the block a few times but I recall it handling like a go kart.
MAF sensor interchange
subaru360 replied to hankosolder2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall the aa160 mafs are the same. It will work. 97 impreza and 98 outback use the same maf.
Documented: The 1970 FF-1 Project car...
The only way to fix that is to have the block sleeved on that cylinder. You could tap and plug the hole on the outside of the block.
Question about gearing, 3.70vs.3.90vs.4.11vs.4.44
subaru360 replied to superu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat guy is a hack. He was trying to sell that car on ebay and the rollcage was built out of black iron plumbing pipe.
I would put a nice aftermarket electric pump back by the tank, below the fuel level or as low as you can. Then run new steel lines up to the front and put a pressure regulator under the hood. I would just vent the evap to the atmosphere somwhere back by the tank. I usually just run a hose with a loop in it along the filler neck and vent it there as high as possible.
anyone have engine valves stick
Doesn't sound right. If the valves stuck open they would have hit the pistons and be bent. It sure wouldn't run smooth or have good power then.
First Tranny swap...Done!! Pics with Lift!
subaru360 replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think that would work.
subaru360 replied to Bucky92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX95 legacy is male rear axles, no pin.
Machine the nick in this head? With pic
subaru360 replied to larrykjr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to resurface it now anyway. The guy doing the work for you used one of those 3m pads on the gasket surface and it's not flat anymore.
Phase II SOHC Coolant Temp Sender Compatibility?
subaru360 replied to sid_vicious's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are only 2 of them. 3 wire and 2 wire. Use what the car originally had.
Legacy Outback VDC Rear Subframe rusted through?
subaru360 replied to william_hunter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSame thing rots it out from the bottom up. Holds moisture underneath it.
subaru360 replied to william_hunter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWinter driving and especially parking over dirt does them in fast.
subaru360 replied to william_hunter's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI see that all the time around here. Not uncommon at all.
3-car seats.....?
subaru360 replied to elmwood22's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, they fit, but it's really tight.
Engine swap, Impreza to Legacy
subaru360 replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSame engine. Possibly 1 or two vacuum hoses might be different, no big deal.
97 Legacy GT broke inlet pipe to Rear Cat
subaru360 replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe parts places don't stock them and they don't fit right when they get them. For some reason only the factory one fits right. It'll hold up for a long time, ones I did a few years ago are still leak free.
subaru360 replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou just need to pick up a split flange from autozone and a new donut gasket from the dealer. They all break there. There is almost always enough left for a split flange to grab. Use the bolts that come with the split flange and forget the spring bolts.
Replace front tone ring 99 OBW
subaru360 replied to 987687's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnplug the abs module under the hood and take the abs bulb out of the dash cluster. The abs sucks on these cars anyway. Or buy a used hub/spindle assembly if you really want to fix it.
Rear Differential Bushings
subaru360 replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe older ones don't have that removable bar. You have to pull the whole rear subframe out.
subaru360 replied to wrongturninwv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou need to pull the crossmember out. You can try to press them out on a press. They usuually won't come out. Easiest way to get them out is burn all the rubber out with a torch. Then cut the shell with a sawzall and you can get the shell out with a hammer and chisel. The new ones need to be pressed back in. It's probably cheaper and easier to find a used crossmember with good bushings.
New Shoes!
subaru360 replied to SubiDemon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the body side. The bracket mounting the arm to the body in front of the tire.
New Shoes!
subaru360 replied to SubiDemon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry Forester or Outback trailing arm brackets before you cut the quarters. They will center the wheel in the wheel well so it doesn't rub the front.
03 wrx wagon 122K - needs shocks.. or?
subaru360 replied to bblossom57's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKYB AGX or Tokico D spec struts will do what you want.
