Everything posted by subaru360
Superoo 72 GL racecar
subaru360 replied to subaru360's topic in Historic Subaru Forum: 50's thru 70's
Midcoast or Downeast. I've looked at a few houses in or near Belfast so far. -
Hopefully Maine. The house I really wanted half a block from the ocean sold recently before I got enough money together. -
I haven't posted here a lot lately. This car was a lot of fun to work on. I only drove it around the block a few times but I recall it handling like a go kart. -
Documented: The 1970 FF-1 Project car...
subaru360 replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
The only way to fix that is to have the block sleeved on that cylinder. You could tap and plug the hole on the outside of the block. -
I would put a nice aftermarket electric pump back by the tank, below the fuel level or as low as you can. Then run new steel lines up to the front and put a pressure regulator under the hood. I would just vent the evap to the atmosphere somwhere back by the tank. I usually just run a hose with a loop in it along the filler neck and vent it there as high as possible. -
You need to pull the crossmember out. You can try to press them out on a press. They usuually won't come out. Easiest way to get them out is burn all the rubber out with a torch. Then cut the shell with a sawzall and you can get the shell out with a hammer and chisel. The new ones need to be pressed back in. It's probably cheaper and easier to find a used crossmember with good bushings.
