Everything posted by CNY_Dave
Clunk Noise on front left wheel - Legacy
CNY_Dave replied to gciriani's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf a wheel bearing is bad enough to clunk, it should show up in a wiggle test pretty easily. If it doesn't get hot, doesn't hum, and isn't loose, it's good. Telling you have a bad wheel wheel bearing is usually easy, on this it's figuring out which one that's tough.
Advice on changing clutch
CNY_Dave replied to aartod's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the clutch fork for signs of cracking, bending, and having the ball wear through.
Inner CV Axle DOJ came apart - can I just put it back in and go?
CNY_Dave replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh jeez, how'd I miss that in that pic? I didn't trigger on it because mine was circular, not like the one depicted, I think.
CNY_Dave replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI can't find a pic that shows it... it is big and goes around the inside edge of the housing. In the pic you show of your joint you can see the groove it goes into just inside the housing.
2000 Outback Fuel pump assembly metal cap is broken
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf that deep cap works with or without the in-tank filter LET US KNOW!!
CNY_Dave replied to 7Wayne7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think this is the first H4 pump doing this I have heard of. I need to hit the junkyard and get a pump so I'm ready for this...
CNY_Dave replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the spring clip is AWOL I may have one to mail (if you have the time to wait...)
2003 H6 wagon - Steps for getting A/C working again
CNY_Dave replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCome to think of it, when I bought my '03 H6 used from the dealer they replaced an AC part free because there was a recall. Not sure what part it was.
Parking brake tightening / adjustment help
CNY_Dave replied to greenleg88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am 99% sure if on one side the wheel goes 'up' to tighten it, the other side is the same. They could use the same part and just swap which end points forwards.
CNY_Dave replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt is most likely simply low on refrigerant, my 03 H6 needed a can at 160,000 or so. If it doesn't last a season or two I'll chase down where the leak is. It could be other problems, such as the rev sensor or even the clutch itself. First step is to get a gauge on the low-pressure side, I have to imagine you could get a garage to just check that and then do nothing more for not much money. If it has enough pressure that it should be running, try pressing on the A/C clutch/pulley with a stick of wood, try to force the plates together. If it runs when you apply pressure the clutch needs to be maybe cleaned, maybe needs to have a shim removed.
420 420 420
CNY_Dave replied to ivans imports's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't seen the possible cause of a heat shield or retarded timing before, will have to keep those in mind.
Control arm bushing questions
CNY_Dave replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's the way it's normally done with a bushing like this, if you can get a socket on the nut.
CNY_Dave replied to 1 Lucky Texan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy legacy/outback manual says the nut (which is supposed to be replaced) is 137 ft lbs, the bolts are 181 ft lbs. It also says there is supposed to be a gap on both sides of the bushing, 1.5mm in front and 1mm in back, gap adjusted by moving the bushing on the arm and using the oval holes in the bushing mount. It also says to scribe a line across the old bushing onto the control arm, then align the marks on re-assembly. For a new bushing I guess you have to transfer the mark from the old to the new bushing.
Parking brake doesn't work after rear brake/rotor change
CNY_Dave replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are probably just spinning the wheel on the lift by hand, then seeing if it's tight enough they can't.
CNY_Dave replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost certainly. They need to make it right- assuming they are capable. The E-brake drums are just like any rear drum brake e-brakes, there are just no wheel cylinders.
CNY_Dave replied to ibroad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be they didn't adjust them enough, does the lever show some resistance when you yank it up? How many clicks? Could be the shoes or the drum are contaminated, you might try driving slowly, holding the button down, and pulling the lever up to where it has some resistance to scuff the shoes and drum a bit.
Hit a mattress on the highway !
CNY_Dave replied to subaruplatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have seen brake rotors that according to the customer 'just started making noise' worn to the point where there was 'rotor' on one side of the rotor and nothing but the cooling vanes on the other.
Wheel Locks But No Key
CNY_Dave replied to ergo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSomething I learned when getting some rims from tire rack- some wheels have lug nuts with a different cone angle, make sure to get the correct lug nuts.
2004 Outback 3.0L 6 Cylinder Jerking/Losing Power
CNY_Dave replied to FellFromStars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHit autozone or the like and have them pull codes. I think the '04 is throttle-by-wire, on my ;03 similar symptoms were caused by the throttle position sensor, but if you have TBW, you don't have a TPS.
Legacy A/C Dryer Question.
CNY_Dave replied to BrokenSubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAC rookie here, but how long did you pull vacuum? May have stopped too soon and you are seeing some moisture or other volatiles boiling off.
Start and Stall
CNY_Dave replied to mccracken's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWonder what criteria the ECU uses to determine that? Anyway, a test light/ear on the tank will tell if the pump continues to run.
How do you know when the hub is fully seated (wheel bearings)?
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's a pic from the manual I colorized. It shows the pressing operation partway through. There are no instructions on how far to press the parts together, and the only way the pressing operation will stop is if a) ST2 hits the hub (green) when the orange race is flush with the hub or the bearing race (purple) bottoms on the flaring part of the hub. Now, if the hub were to bottom against ST2 then there would be no preload on the bearings because ST2 is just a stand-in for the axle, so it stands to reason yuo keep on pressing until you achieve (. The oil seal is colored red.
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis shows what I mean even though it's for a bimmer, and shows ball bearings not rollers. For the preload to be set, the outboard inner race "1b" must contact the lip on the hub, and the inboard inner race "1a" gets pressed against it by the axle itself, until the inner races touch. If you don't drive the outboard inner race "1b" all the way to the lip where the hub widens, it'll happen when you tighten the axle nut, assuming the race slides on the hub before you reach full torque on the axle nut. So I believe the correct answer to 'how far' is 'till it won't go no more'.
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMaybe this explains it- the part of the race that 'grips' the hub then flares out a bit, and that part fetches up against the wide part of the hub. http://imageshack.us/photo/my-images/87/dsc04785s.jpg imageshack.us/f/87/dsc04785s.jpg from http://legacygt.com/forums/showthread.php/front-wheel-bearing-diy-walkthrough-86994.html?p=3240125
CNY_Dave replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlthough this pic makes it look like the race does not bottom against the larger part of the hub? Then how the heck is the preload actually set? This was on a '97 http://forums.nasioc.com/forums/showthread.php?t=832596
