Everything posted by blackbart
93-94 Turbo with a non-t auto Trans??
blackbart replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis sounds like you are placeing the turbo 4EAT with a non-turbo 5MT(?)
blackbart replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 93 non-turbo tranny you picked up should be the same ratio as the turbo, a 3.90. In 92-94 all the autos were 3.90, the turbos had a stronger clutch pack but they are interchangeable. The 90-91 non-turbo autos were 4.11 but the 91 turbo was 3.90 just like the 92-94's. If you are certain that the tranny you picked up is from a 92-94 there is no reason to change the rear diff. If it is possible to find the car that it was pulled from just check the tag on the rear diff, it should say 3.90. I am assuming that you are not doing a auto to manual swap, if you are you will have to swap the rear also, the manuals were 4.11.
Legacy Turbo LSD Fluid Q
blackbart replied to carfreak85's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe earlier LSD's (like the 3.70 LSD) used special LSD fluid, the newer VLSD's use regular fluid, the VLSD portion of the diff is sealed.
1990 Legacy Auto transmission problem
blackbart replied to duallegacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid it sound like a shaft broke? Imput shaft or the reduction drive shaft?
overheat, heater has no heat
blackbart replied to rainbow123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1) I used a vice, go slow, put a little alan wrench it the hole to keep it compressed. 2) There is an access hole (with a black rubber plug) to the flywheel. It is located behind the intake manifold. Slide a large screwdriver down into it to stop the flywheel from turning.
blackbart replied to rainbow123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was thinking that if it was a HG or a cracked head, is it worth fixing? If the body and the rest of the car is good I would find a low milage replacement motor. Hummm...now you got me thinking....if you do put in a low milage replacement motor I would change the water pump and belt anyway....disregared my last post.....(unless your car is rusted out or on it's last legs)
blackbart replied to rainbow123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wouldn't spend money and labor on the water pump and belt until I rule out the head gasket. I think the head gasket is blown. The classic 2.2 HG falure is betwen the water jacket and the cylinder, there will be no water in the oil or vise-versa. The engine overheats before the thermostat even gets the hot water to open it. The temp gauge is on top where it is hot and the thermostat is on the bottom where it is still cool. Start the car and look into the overflow bottle, do you see bubbles?
no start
blackbart replied to waltee_d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo signal to the injectors could be the crank sensor.
Needed ASAP - IAC for 90 legacy wagon 2.2l
blackbart replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere did you find the $6 flat rate box? My post office only has $7.70 boxes. Could it have been UPS or FedEX?
no start
blackbart replied to waltee_d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have all the pulleys, idler and gearer. Also have a good used timeing belt, don't know the mileage on it but all the lettering and markings are fresh. Any pulley or the belt, $10 plus shipping.
no start
blackbart replied to waltee_d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah, I saw a manual that told me the ECM (aka ECU) was under the passenger carpet also! In real life it is under the dashboard to the left of the steering wheel. Has yellow harness conecters. The tranny computer, the TCU, is under there also, look similar but does not have the yellow conecters.
blackbart replied to oregonloyale's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGot one, PM sent.
no start
blackbart replied to waltee_d's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have lots of parts you can borrow if you like to "part swap" as part of your troubleshooting. ECU, sensors, MAF, coilpacks....just pay shipping both ways. I can fits lots of stuff into a $7.70 flat rate priority box.
Blew a tire - need to replace all four?
blackbart replied to Rio's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat brand and size tire do you need? This is a long shot but I have several good used tires that I pulled from Subaru's but can't use because I don't have sets of four. Or if I don't have a match, maybe some other pack rat here has one.
Blower Motor!!!1991 legacy - HELP!
I have a good blower motor, I'll PM ya....
Whats the best replacement head gasket for 2.5?
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXEXCELLENT!!! Anyone have a favorite dealer to buy these from?
I am changeing the head gaskets on my 99 2.5 Legacy. I would rather not have to change them again. Did Subaru come up with a better one or do I go aftermarket? I did a search but got overwhelmed by the amout of information on this topic.
WTB: 1999 2.2 timing belt
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHe just replied again, he says it it made in Japan. Anybody use Bando belts?
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFound the one on eBay, brand is Bando, anybody know where it is made? I emailed the seller, he gave me the Bando wed site but avoided telling me where it is made.
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like I am all set, I matched the Subaru part# to the one on eBay, they match. I'm still confused but it looks like I found the correct belt, thanks guys!!!!!!!!
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat was the first year of the interferencce 2.2? Did it start in 95 or 99?
blackbart replied to blackbart's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't understand why 1stsubaruparts, a reputable dealer, says one fits all?
What is the difference, other than price, between the 90-94 timing belts and the one I need now, the 1999? I realize that the 99 is an interference motor, did they put on a bulletproof belt? I have been paying $30 or so for the older belts now the same dealer wants over a hundred for this one. I figured I would try 1stsubaruparts.com for a price, the belt that came up costs $58 and says it is for ALL 2.2's. If anyone bought one recently, what did you pay and where did you get it?
Sparking on 1 & 3 not on 2 and 4
blackbart replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a spare ECU and coil pack, if you would like to borrow them for troubleshooting lemme know.
Rear diff dieing, remove rear drive shaft?
blackbart replied to mtnpat's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you remove the rear diff on a manual car it may not move at all. I am currently parting out a 90 Legacy with a manual tranny. Sold the rear diff and removed the rear axles. I went to drive it out of the way and it didn't move. I can hear the drive shaft flopping around but the car just sits there. I did the same thing with an auto and was able to drive it away. This was yesterday (Sunday) I posted a question about this in the drivetrain section at LegacyCentral.
