Everything posted by Knichol
The True Subaru sound!
Knichol replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou know if that was the race series or street series?
I am just finishing up and EJ in and old EA body swap and am getting the exhaust started. I have heard a couple 2.5's and wrx'x that have a nice throaty exhaust sound and I am wondering what brand muffler gives a good sound to Subaru’s. I don’t want the “Coffee can strung out lawn mower sound”. Anybody have any opinions on what sounds good and what sounds bad?
Dual port or single port EJ22
What years did the EJ22 have a dual port? 90-95? with a switch in 96 to single? or was it mixed throughout the years? I am trying to identify what year motor an EJ22 is that I have. Any suggestions? I broke open the ECU and the chip set is from late 95, so I think its either a 95/96.
Electric Supercharger
I wonder how much power you would pick up from this.... 1,.... 1.5 HP? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7970447925&category=46098
STI Four Wheeler?
I am kinda new here so I don’t know if this is appropriate here. All I can say is a Subaru can do anything, or be turned into anything! http://www.members.optusnet.com.au/~aedennis/Forester/ATV.htm
Headers for an EJ Swap?
Its an EJ22 in a 91 Loyale. I just wanted to see if any or all after market 2.2 headers would interfere with anything on the loyale underside. I am more of a V8 guy so I am used to headers interfering with everything from starters to suspension components. I know on Subs the headers drop out basically on the bottom of the motor (which kills most interference problems) but I didnt want to buy a set have find out the hard way that a different set would fit better.
Does any one know if any after market headers (EJ22) will work on the EA82 series wagon with the an EJ22? I looked at Borla and they have at least four different types, i.e. forester, legacy impreza, etc? Do any work?
Delta Cams for EJ22
Knichol replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow does it compare with the 2.5 that was in it?
Wrong Axle??!!What now?? HELP!
Back in the day there were 4 different front axles. 82AC: 265mm between in and out boots, 1 ring on shaft, w/out cooling grove, 23 spline 87AC: 257mm between in and out boots, 2 ring on shaft, with cooling grove, 23 spline 95AC-23: 242mm between in and out boots, 3 ring on shaft, with cooling grove, 23 spline 95AC-25: 242mm between in and out boots, 3 ring on shaft, with cooling grove, 25 spline 23 spline = 27mm inner diameter where it fits over the transmission stub 25 spline = 30mm inner diameter where it fits over the transmission stub To make a long story short you need the 23 spline or 27mm in/d shaft.
D-Check mode (Checking for Problems)
Does anyone know how to use the D-check mode? All I can find in the manual is have the "Read memory connector" diconnected and the "Test Mode Connector" connected. Later it states "This mode is used by the dealer to check the entire SPFI system and detect faulty parts." Is there more and I am not finding it? Please help if anyone has any more info.
15" Volkswagon Wheels?
Are they a tight fit on the studs? Its hard to believe that the tolerances are that sloppy on either the Subaru side or the VW side, or the combination of both.
loyale wheel question puegeot wheels
Yeah definitly dont get the 390mm wheels, I got a steal of a deal, and thats why I am running them.
I have a 91 loyale with the 390mm puegeot wheels with 190 65 tires with no lift, I had to bend in the front corner of the front fender just a bit. Still looks fine.
Delta Cams for EJ22
Are any of you running Delta Cams? If so what grind and how do you like it? I know its a general question but I am looking at getting a set and want to know from real people what they think of them
Hp and Tq ratings for EJ22
Knichol replied to Knichol's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHey, thanks for that info!
Does anyone know or have a link to what the Hp and Tq ratings are for the EJ22 over the years? I know the EJ22 has stayed pretty much the same but does anyone know what the exact changes are?
Will 130mm spacing work on 140mm spaced studs?
