5
Everything posted by Caboobaroo
well if your GL-10 is a turbo, then the rear diff should be the same ratio (3.70) compared to the non turbo diff which are 3.90. As for the rear swaybar, yes it will fit with no mods at all, plus since its larger, it will make your wagon handle better in turns
Ahhh so you finally got them in eh? Where's the pics?
Brat Tranny questions...
Caboobaroo replied to skapickle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the newer EA81 d/r tannies will fit, the only problem with putting them into a gen 1 is the fact that the shifter mechanisms are in different spots. So A) you can make your own custom shifters for it or search for a needle in a haystack to find an '81 Brat with the d/r in it. I have also heard that you would need a steering rack from an '81 Brat to fit a 1800 into it but then I've also heard that you don't. The steering column will be very close to the axleshaft on the drive side though so watch out for it... -
hi-performance EA71 parts
Caboobaroo replied to captainkettel's topic in Historic Subaru Forum: 50's thru 70's
well if you're looking to spend a little bit of money, try www.deltacam.com for a cam for the EA71. Next, get a Weber 32/36 for it as well and get it jetted right for the engine. Check out more in the offroad forum for jetting of Webers. Swap the disty with an electronic disty from an '83-newer EA81 and add some performance plug wires on it as well. Swap the stock coil with an Accel Super Coil, not the Super Stock, but the huge square one. Should give you a bit of power with these things added up together;) -
New house, New Wheels, couple of new pics
Caboobaroo replied to calebz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
mmmm me want Konigs....... whatcha need for parts and whatnot? -
Converting 78 brat to EA81, new trans too...
depending on what year car the engine is from, it could have had either a vacuum secondary on the carb or be like the carb you have on your EA71 which has a mechanical secondary. I perfer the mechanical secondary myself which can be easier to deal with. You probably won't have to change the jets or anything in it since they're almost identical but the carb from an EA81 I believe flows a little better since there's about 200cc difference between the engines. You should be fine unless you start adding in performance parts like cams and whatnot. -
get a helicoil kit for it. You'll love yourself for buying a kit for it since its also the same kit for the intake manifold bolts and numerous other bolts as well. Its easy to fix in an afternoon. I did it on an XT with the engine in the car. I had to remove the radiator and the fans plus tear apart the front end of the motor but it was easy to fix with the engine in the car.
I found the easiest way to find TDC without any special tools like a compression tester and blah blah blah. First off, pull the #1 sparkplug out and then thread it back in just a couple threads, just enough to let the pressure exscape from the chamber. Then put a ratchet with the correct size socket on it to turn the crank. Slowly listen for the hissing of the air rushing past the loose sparkplug and watch for the timing marks. If the hissing stops and you see no timing marks, keep turning and they might pop up. If they don't, keep turning until it starts hissing again and when it stops, the timing marks should appear. Then static time it by putting it on 8 deg. BTDC.
they're not really alike in any way. I've had an ATX apart *shudders* and its not like a Subaru 4EAT. I don't even think the clutches and steels are the same either since one car is a FWD and the other car is an AWD.
ok well here's a great upgrade for these cars, even if they do have the old style electronic disty in them. Go and find an electronic disty from an '83 to newer 2wd EA81 car. Works wonders for improved mileage, and power as well, plus you'll never have to worry about changing the points in it either since well, i doesn't have any. Its a direct bolt in swap. When I first got my '78 Brat, I did a disty swap and rebuilt the carb and I was getting 30mpg out of it. As for the carb, if you need anything in the FSM about them, maybe one of us with an EA71 FSM can scan them up for you. It came in handy so much when I rebuilt my first EA71 carb....
Rear sway bar pic compair 16mm to 20mm
Caboobaroo replied to Subi81's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've driven a '87 turbowagon that had XT6 swaybars front and rear and it felt like it handled on rails. But then of course I also had a great feel for the car as well;) -
I modified a 3 gauge a-pillar pod for a '02 WRX to fit into my RX. Was pretty easy actually since all I needed was a hacksaw and about 30 minutes of time for test fitting and whatnot. I cut some off and used a file to make it look nice and then I mounted it... http://community.webshots.com/photo/302403464/389939708mtzKpQ
what models had the Limited slip rear?
Caboobaroo replied to subarubuddy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there's a BIG tag on the diff that says 3.70 LSD. Here's a pic of the one under my RX and its the same for all of them... Rear diff tag -
Ugh, I'm about to give up...
Caboobaroo replied to Caboobaroo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
no I'm just getting frustrated with the fact that I can't seem to get it running... I still want the wagon and the RX but I do want my RX to run as well... -
Need some pics of spyder intakes with WRX TMIC
Hmm that wagon looks like the one I'm getting... oh wait it IS!!! Thanks for the pics Stan, now I can think about what has to be done as far as plumbing on the RX for my spyder intake and TMIC... -
Custom AEM cold air intake
eh I'm still working on that. I'll probably relocate it to the other side or something... -
So I'm kinda thinking when I get back from Steamboat Springs, CO in a couple months, maybe havin a work party at my house where I'll also have a couple cars that need to get parted out, plus doing some work on my RX. Just testing the waters on who might be interested in doing it. Maybe some of you from Colorado could come up for the day and we can work out which day it is. I will be however, in Oregon for a week over my birthday to part with my beloved '79 wagon but I need it to go. Anyways, I'm leaving tomorrow afternoon and I won't be getting back except to visit, until the end of Sept. So who might be up for it? It would be a BYOB (bring yor own beer) and maybe a side dish but I would supply the burgers and hotdogs as well...
Interesting find on cardomain...
Caboobaroo replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmm he has a fart can and that gives him 285 hp? What a mod!!! I need to do it as well:lol: -
ok so I'll try bleeding the brakes myself. Hopefully I can find a spare one way valve since I have like a million spare intakes. As far as the parts I owe a couple people, I still haven't forgotten about you, I just have been working a lot between Wal-Mart and helping my friends get their rigs back up to par for trips and whatnot. So I've helped all these people out with nothing in return except for the pure satisfaction of making myself feel better I guess. So I'll get the parts out, I just gotta find time when UPS is open and I can get them there (Will, your box is like a million pounds so I can't take it there on my bicycle lol) -
I can't seem to get my car on the road. I've done a lot of work and put a lot of money into her but its really starting to get to me. No one in the area (you know who you are) are willing to come over and give me a hand and the only other people who would be willing to help are friends that work weird schedules or are just plain tired to help me. I look at it everyday and think of how I have over $2500 into a big pile of crap in my driveway and I'm getting tired of it. I'm about to get rid of it if it means either parting it or just selling it as a whole. I've given parts to people to help me get her running but they feel like they have to be at home with their significant other(s) to please them all day, everyday. I'm about to actually get rid of all of my Subarus and go get my Camaro since I know there are more people who would be willing to help me on that then my RX (like in physical help, not internet help). As it is, it'll sit for the next 2 months while I'm working so then when I get back, I can HOPEFULLY get it closer to being running but I can't bleed brakes by myself since I don't have the resources to do it myself. I love friends who say they'll help me over and over again but never do. Makes me think they're not much of a friend as I thought they were... Sorry for the rant....
I still don't see how you're gonna make that happen unless you get an LSD carrier swapped into it and only one person has done such a feat and that was Mudrat79 IIRC. There was never an "AWD" in these bodystyled Subarus, only the FT4WD which came in later '80's GL-10s, XT6's (for the single range) and the RX which had the dual range
IIRC, Calebz isn't running with a spyder intake. He's running with a normal EA82T intake with his TMIC... I know WJM had a few pics of his wagon eons ago but I cannot find any. Also I know SubaruTex has a few in his old RX but I cannot access his pics on his website... -
sheesh movin fast....
