91
Posts posted by Numbchux
23 hours ago, 1 Lucky Texan said:
I've also read the gasket must be OEM, metal type - not paper WP gasket.
others will correct me if I'm wrong
Yep, paper gaskets seem to leak.
Stamped metal ones generally do not. Many aftermarket companies have figured this out, and supply a metal gasket, but not all.
I'm assuming that since the incorrect water pump gasket was used, that the incorrect head gaskets were used as well....so just assume those will fail, and they may leave you stranded (OEM coated gaskets tend to just leak oil, OEM MLS gaskets tend to outlast the vehicle).
It sounds like the water pump is getting air in it and cavatating, that easily could just be from your external leak, or it could be a head gasket.
On 11/1/2022 at 8:10 AM, slammo said:
Reinforcing the strut tower tops and converting the GC to GD size is relatively common: https://rally.build/products/subaru-impreza-gc-weld-on-strut-top-reinforcement I like the principal of these being cut to shape and welded to the adjacent sheet metal, should help strengthen a little more.
This is SOP when building a rally car. THICK steel plate on the top of all 4 struts, and tied into the cage.
- 1
No way to know how long it will last. Might be 50k, might be 50.
New fluid will help, but obviously it won't solve the problem. And it will still be a gamble every time you drive it. Make sure your never outside the towing range of your AAA membership....
Whatever you think it's worth (I won't get into that, the market is crazy right now), it will be worth a LOT less with a known major problem like that.
Look at Impreza transmissions. 3.9 is a very common ratio for the Impreza/OBS in that vintage. They will likely have a slightly taller 5th gear than the heavier Legacy, but it's a pretty small change.
Facebook marketplace and brand-specific groups are a great place to buy a transmission. I bought 2 Turbo (FXT and OBXT) 4.444 manual transmissions for $150 through a local group. One has completely unknown history, but still! I bet with a little digging, you could find a nice local transmission for 300 or less. Sure, it's a pain of a job, but if the car is in otherwise good condition, you will add thousands of dollars to its resale value. That's easy math if you ask me. You could probably find a shadetree mechanic doing side work in his garage and pay him to do it, and still come out way ahead.
- 2
No small project to split the cases and replace the bearings, and there's a lot of "while your in there" things to consider on a 235k mile trans. I've had many manuals apart, and put a couple back together and used them. I would definitely not bother, not with how easily a good used transmission can be sourced.
- 1
Could be throwout, but also absolutely could be internal to the transmission. I would get the car up in the air, running in neutral and poke around with a stethoscope. See if the noise is coming from in the bellhousing (listen right on the clutch fork), or from the case itself.
Change the fluid and see what the drain plug looks like.
Well, small update.
She had the fluid changed at a local-to-her independent shop that she frequents, she brought in Subaru CVTF
A few days later, she was driving, and noticed a loss of power on the highway, and when she pulled over, the engine had stalled. She had to navigate across a lane of traffic and an entrance ramp, so she's not sure if it stalled on the move, or when she stopped (like a stuck torque converter). But, after cycling the key, it started back up, and drove normally. My dad read the codes later that day, and found P0700 (AT abnormal) and P0841 again.
She's visiting me again this week. First thing I found out, none of my scan tools will read the live data for that sensor. I have a Carista ELM327 bluetooth adapter that I use with my phone, I have a couple basic apps, but ActiveOBD is a Subaru specific one, with which I can read torque converter lockup, AWD transfer, transmission temp and more. I also have an Innova 3170RS, and FreeSSM.
So, then I was left with the options to buy a better tool to test it. Pay the dealership to test it. Or, just throw the $150 sensor in. The local dealership had it on the shelf, and said they use them in the shop about once a month. If it were my car, and only driven locally, I'd drive it and wait for symptoms to worsen. But it's my mom's, and she drives all over the state, a breakdown in the middle of nowhere would be far more costly.
So, I did what I hate to do, and loaded up the parts cannon. Yesterday I put 5 more quarts of Subaru CVT fluid in (what came out was still pretty brown) and the secondary pressure sensor. With such intermittent symptoms, only time will tell if that was the chicken or the egg. I drove it to work today, and it's showing it's age.
Not sure what the future is for this car, it seems like a pretty nice car, but with a salvage title, considerable oil consumption, and a failing CVT, it's probably not worth much, and not worth fixing.
30 minutes ago, el_freddo said:
Good question mate! The early engines had two temp sensors - a single wire sensor for the gauge and a two wire sensor for the ECU. I believe at some point, or with the phase two engines, they moved to only having the two wire sensor for the ECU.
small clarification
In the late '90s, they transitioned to a single 3-wire sensor, which still performed like 2 separate sensors (2 wires for the ECU, single wire resistance-to-ground for the gauge). And then around 2008, they transitioned to a single 2-wire sensor only feeding the ECU, which then outputted a signal via CAN to the gauge cluster.
Yep, you can use your EA81 sending unit with a little modification. Or you can wire a resistor in to modify the EJ signal for the EA dash (I know this works on the EA82s, I think the EA81s as well). That's in my write-up. Or, just wire the EJ sensor to the EA gauge, and it will read about 1/2 what it used to, but will still give you some information.
- 1
http://opposedforces.com/parts/info/11044AA483/
https://www.ebay.com/itm/192453951693
both list SOHC non turbo and turbo 2.0 applications. That's what I would use.
USDM source, lists WRX EJ205 https://www.subarupartsdeal.com/parts/subaru-gasket-cylinder-head~11044aa483.html
I know STi turbo head gaskets are used on the SOHC 2.5 all the time, I would think WRX would be the same.
Timing change would be negligible, compression might be noticeable.
WRX 2.0 head gasket should work just fine.
Everything else is the same as SOHC 2.5.
Very easy to get parts with that little bit of information.
- 1
use your VIN on the parts site, it'll only give you one option.
Or, look at the plate on the LH strut tower in the engine bay for the original complete engine code.
If anyone has any insight, or, I'll just document what I find in case someone is looking in the future.
My mom's 2012 Impreza 2.0i Premium. 216k miles, original engine and CVT. Had the torque converter solenoid fail last summer, and the fluid was a bit brown, so I did a drain and fill then (probably 190k miles), and we did another at about 80k, when I was working at a dealership.
The AT Oil Temp light was flashing one day, I scanned it about 2 days later (no lights on) and it had a stored P0841, as well as a U0100 (CAN signal error), C1431 (AT abnormal), and C1422 (VDC Interrupted).
From the Subaru FSM:
QuoteJ: DTC P0841 SECONDARY OIL PRESSURE SENSOR PERFORMANCE
DTC DETECTING CONDITION: • Control valve hydraulic circuit malfunction • Secondary pressure sensor fault or characteristics malfunction
TROUBLE SYMPTOM: • Acceleration is poor during standing start. • Shift control malfunction • Engine speed increases abruptly.
First 2 steps in the diagnostic procedure is to check the condition and level of the CVT fluid. I think she's going to have another drain and fill done (she does not live locally to me, so I probably won't see the car for another couple weeks). And then there are a few tests using the SSM to check the pressure readings from the sensor under a few conditions (Idle in park, 3k rpm in park, torque convert stall at WOT).
Beyond a fluid related issue, the procedure basically ends with the sensor, wiring, or transmission causing the fault.
The secondary pressure sensor is externally mounted, threaded in towards the rear of the left side of the transmission. By her VIN, part #31878AA020, with an MSRP of $148.17
I don't quite follow what you're doing.
But, the low range gearset is on the input shaft of the transmission. The EJ cases are cast with the cavity for the gears, but they are not machined out for the bearings and such. It would take quite a bit of precision machining to convert a single range case to dual.
The 4WD versions have a very different output shaft/front pinion arrangement. You could use a FT4WD front pinion gear in an EJ output shaft, and then have the locking center. But if you don't care about unlocking, it would be far easier to just weld the EJ center.
The fact that it's felt in the steering wheel has me thinking it's not the transmission. I just replaced a CV axle with a completely failed inner joint, and it could not be felt in the steering wheel any more than anything else (it shook the whole car....). I've been chasing this vibration for years, and because it wasn't felt in the steering wheel, didn't even occur to check the front axles. Boot was fine, and it only happened once driven at least a few miles.
Does it change at all when on or off throttle? Brakes? Pull to one side more than the other?
That's puurrrrdy
- 1
22 hours ago, yoyo7015 said:
I have a ej253 that im putting into my 04 impreza 2.5ts (ej251). The ej253 has a egr pipe that can't connect to the ej251 intake manifold. when you plugged up the hole did it throw any codes? I've seen others post about doing EGR deletes and it threw codes for them. That being said I have a stock ECU for an engine that doesn't have an EGR pipe.
The ECU, and emissions system in the car is not expecting an EGR. So you are just keeping it factory.
Blocking off EGR on a system that had it is different.
- 1
On 8/4/2022 at 9:53 AM, sirtokesalot said:
so when u did the hot wire thing how did u wire it? in my car i left the stock wiring there and simply added a second system to help the factory setup work. my system is just wired in along side the factory wiring. relay trigger is the key to start position relay gets power from battery and is passed through right to the starter spade post. i left the factory wire attached there as well. my wire is actually attached simply by holding it over the post and plugging the factory wire in so it folded my wire around the tab and is held there just by the fact that the factory wire is plugged in.
Yep, Take the wire off the starter solenoid and run it to trigger the relay.
I've put a hot shot relay in a couple subarus with no trouble. As long as it's triggered by the factory switch, it should all be fine. The system doesn't know if it's directly triggering the starter solenoid, or a relay.
It's possible that the original problem was a failing neutral/range switch or wiring to it, and you are now getting a second symptom.
Should be a yellow tag on a battery cable with instructions.
But yes, if the battery is disconnected, the parking lights will flash. Ignition "ON" and press that button for 1 second resets it.
A lot of variables. Be more specific with your questions, and you will get more specific answers.
All EJ engines share essentially the same basic dimensions. So they will all physically fit almost identically (with the exception of the last few years of the EJ253, 2010-2012 or so, where the motor mount configuration changed a bit). 2.2s were made 1990-2001.
So the difference comes in the electronics, which can be changed. But ASSuming you want to use the ECU and wiring from your donor car (cheapest option), the rule of thumb, is the older ones are simpler, and the newer ones are more complex. 1995 (for the 2.2) added OBDII, which makes them far more easy to diagnose, as any off the shelf code reader can connect to it. But much newer than that adds fuel tank sensors and stuff that will be hard to replicate/bypass in the new chassis, so you will likely always have trouble codes.
IIRC. The viscous LSD unit is separate from the spider gears. If you were to cut that shaft in half, it would be like an open diff.
- 1
Yes, both fans should cycle in test mode. I would use a test light or multimeter to backpin the fan connector while in test mode and see if it's getting power. Might just be a failed fan.
The fans really only make a difference under 15-20mph. So with those symptoms, I would question the gauge reading. Might be worth plugging a code reader in and seeing what temp the ECU sees (separate sensor), and/or using an infrared thermometer to test.
Might be a grounding issue causing both problems....
- 1
On 7/10/2022 at 8:55 AM, el_freddo said:
@Numbchux- can you describe what a dropped valve guide looks like with inspection from the exhaust port for us? I’ve never encountered this issue and would be guessing as to what to look for.
Cheers
Bennie
quick google search turned up this
- 1
1 hour ago, 1 Lucky Texan said:
I've seen pics online of 'dropped' (shifted) valve guide inspection after dropping the exhaust. I think it is most common on neglected vehicles.
We saw many at the dealership. Causes a misfire. Wasn't uncommon to have cars towed in from other shops that had thrown a coil, injector and more at it trying to "diagnose"/repair a misfire, and it was a dropped guide. Never heard one make a noise.
Electric Fuel Pump Fix for my 87 DL
Posted
Most cars in the last 20-30 years do that from the factory, using a controller to vary pump duty. And actually take it further, to vary it based on engine load. I'm in the middle of swapping a 1994 Lexus 4.0 V8 into my 4Runner, and in one of my test runs, I pulled the return hose out of my fuel bucket, and it was just a dribble coming out, even at idle. This helps fight overheating of the fuel, and probably reduced wear on the fuel filters, as it cuts down on the volume of fuel going through them.
When I worked at AutoZone, the fuel pump companies said (grain of salt....but it makes sense) that the vast majority of fuel pump warranty claims were caused by debris, which is why you should always replace the prefilter when replacing a pump. I don't believe such a thing exists on the EA Subarus, so it might be worth putting an inline filter between the tank and pump.
The nice thing about the inline filter design on the EAs, is that you can get one anywhere. I've used ones for Ford trucks, and several other things. Can't get a $40 fuel pump for anything I drive, now.
