Everything posted by MSSLGECKO
A little project I like to call Gloria (GL+RE+EA)
Can we get an update? This project sounds too great to die!
Bump for more awesomeness! Can I have your car?
Custom 3.9 RX FT Trans Question
I want this transmission. The best gear shift out there is the 1.59 D/R down shift in second gear (on snow of course). I used to have a BRAT w/only rear axles installed using a custom trim piece to prevent shifting into 2WD inadvertently; the quick throw b/w Hi & Lo ranges was phenomenal. The fact is that having that 'halving' effect of the 1.59 Lo range allows you to put your (low hp/tq) engine in the power band at any speed. I like it most for the 2nd Hi to 2nd Lo shift, it gives the lower-speed torque like first gear w/o out the hesitation from the 1st gear synchros. Build me one?? (I like the 23-spline mod, EA81 FTW!)
Electric quarter window in my EA81 Hardtop
Thanks for the suggestion. I am looking for new motors all around (4), but in the meantime I am hoping to figure a way to raise the glass by hand. It seems like a hassel to get the pannel off & I need a temporary fix. As far as sourcing the replacement regulator, any suggestion helps. I'm not sure where to buy a new one so I was thinking the local dc electric repAir shop could rebuild the old ones. - Noah
Hi, so it's getting colder & my rear window is part way up with a dead motor. Can someone suggest a method or tool to force it up fully? I will replace the window regulator sometime when it is more convenient, but for now I want it rolled up. Also, I tried to force it up by hand to no avail. Thanks for the input!
EA81T serpentine belt reinstall HELP
I posted prematurely . . . I got the belts on with the help of two beers. GD, I mis-spoke calling these belts serpentine; my bad, thanks for your attention and the correction! Cheers, - Noah
I'm installing both serp. belts on my turbo and cannot get the 'idler' belt on (closest to engine). The idler pulley itself is adjusted up, but the belt will NOT go on. its slightly too short to get onto the idler pulley. The PROBLEM is that this new belt measures up to the one its replacing. It seems odd that it's a fight to get it on the adjuster/idler pulley (which adjusts a significant amount) . . . I'm at a loss at the moment and normally I'd blame the parts store for the wrong length but this is the size that came off!
How much does it cost to rebuild a transmission?
^Thanks Randy, I'm discussing this with Robert currently. I would like to change topic here and pose a question: What are some 'recipe' suggestions for a custom FT4WD D/R build? Firstly, the application would be auto-x and rally-x in my 84 turbo hardtop. Secondly, I'm trying to decide on the center differential, lockable or EJ . . . And of course I need to figure out what final drive ratio to go with and what gearset to use. Input appreciated.
EA81 Struts: KYB Gas-a-just
So, it's pretty standard around here to run GR2's front and Gas-a-just's rear? Will this setup retain the stock ride-height adjustment?
I'm considering these upgrade struts for my hardtop and have a couple questions for members who have used gas-a-just replacements: - KYB lists only Rear struts for the Brat application, is this the strut being installed on all four corners? - Performance: Please describe the driving characteristics. Is there a significant reduction of body roll? How does it autocross? - Bushings: Where can I source stock and/or stiffer bushings? . . I'm thinking autocross campaign with my t-coupe in rwd . .
Thanks for the helpful comments! I had a hunch that it was preventatively expensive, but worth double checking with the resident experts.
Can someone guesstimate how much a transmission shop would charge me to rebuild a FT4WD D/R with swapped gears? I'm just looking for a ballpark estimate.
EA81T Hardtop Decisions
What are other people's opinions? Will it decrease the value of this car to do some light modifying? Also, I'm starting to think about performance struts with the stock hight adjustment, any suggestions?
I'm trying to decide what I should do with my 84 T-Coupe. Its got 58,xxx miles on it and runs perfectly. There are two minor body dings that need attention and it's about to get new alloys. The interior needs a new rear seat, and I'm planning to magically resurrect the digi-dash. The question that I've been mulling over is whether or not I should restore the vehicle for resale or for my personal pleasure. I'm very curious what resale value of this car would be in near-mint condition. The reason that I'm torn on this issue is the simple fact that this car is highly upgradeable and has a lot of potential and cool factor. As an example, a 4- or 5-speed and rear disks would improve driving qualities and fun, but might devalue the vehicle in terms of resale. So, my question to you who have a gauge on the rare EA market is: tell me what this car might be worth.
Older Soob's
Keep us advised on this; and definitely snap as many pictures as you can when you find the subie-stash!
It happened
Joy Ride my EA81T. The last piece of the puzzle came in the mail yesterday; so, after work today I finished the replacement turbo install in my 84 Hardtop GL Turbo. Previously, I've driven this car a cumulative one mile or so since I purchased this car a couple of months ago and this was the first time it has made boost properly. I can't be more stoked about it!!
Seized Drum Brake Adjuster Screw . . .
Thanks! That was inspirational.
What do you guys do?? This is on an EA81 and for all I know these original drums are shot anyways, but I'd like to try adjusting before scrapping them. . . I've been soaking w/ penetrating oil, but nothing's happening. Advice? Thanks!
Turbo Traction Coupe !!
So, you're saying that it's not totally abnormal to see smoke coming from a dead valve cover gasket? Thanks, I'll do the switch on that. I seem to recall you (GD) mentioning that coating the cork gasket in permatex black and letting it sit overnight is your preferred method, right?
So I put it all together and ran the engine until it was warm. Once it is warmed up it smokes from the turbo (not a surprise) and from the bottom of the pass. side valve cover which is my concern. The turbo definitely is leaking oil internally b/c there IS a little oil in the intake. I'm not sure what the deal might be with the valve cover leak, never seen that before. Can anyone suggest what the problem might be? I DO have new valve cover gaskets somewhere that wouldn't be hard to install, but I'm not sure that seems like the culprit here. Should I be looking for a replacement EA81T and/or a wrecked wrx here?
Quick question on EA81T
Does the EA81T have just ONE fuel filter which is a canister in the engine compartment, and NO fuel filter in the rear? Thanks in advance!
@#$%)*))&@#!!! ea82 front breaks :/
Can you not just use a c-clamp to compress the piston? I haven't done EA82 brakes, but that's the way I learned to do it. . . .
Roll Call for UNcracked EA81 Dash
I'm in. '84 EA81T Coupe:
Direct bolt on turbo?: ea82T -> ea81T
Solid, I thought I might be going crazy . . All I seem to find are '84 turbo's w/o water cooling. My original unit is that way and unfortunately this CL-Seattle one is the same. I appreciate the help!
