Everything posted by turbo5speedgl
got a bunch of wrx parts for my ea82
turbo5speedgl replied to turbo5speedgl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not even the ea82 turbo axles? -
Drive shaft as in the cv axle? Do the turbo ea82 axles fit in the wrx hubs? -
Yea I forgot to clarify 02 wrx I just want to use the knuckles and brakes. So I can use wrx for the front and only use xt6 for the rear? But need the xt6 front arms. What do u mean rounded out ea82 arms? -
EA81T starts then dies; video inside
turbo5speedgl replied to 555jay's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do those use a coolant temp sensor. My car did that untill i replaced the CTS but it was an ea82t. -
ea81 failed emissions
they check under the hood. heres a pic or the timing its at 8 degrees btdc and the rotor is pointing at the #1 cyclinder but should it point at the top of the spark plug or no. and the second pic what is the goldish circle thing below the carb opening because its loose and turns both ways. -
It was cold so I'll check it warmed up next time but I think I'm just going to swap a different carb on it and go from there. I'll tell you how that goes -
HC gpm 1.8378 limit 2.500 passed CO gpm 107.2887 limit 20.00 fail CO2 gpm 271.18 limit doesnt say NOx gpm 0.0653 limit 4.500 passed -
The throttle screw was not even touching the lever I had to turn it a full turn to get it to touch and move the lever so I guess it was at the lowest idle and still running at 800 I'm pretty sure I don't have a vacuum leak as I fixed them awhile ago. It will drip a little fuel when I open the throttle is that normal. And they said my cats passed and it has a different carb on it from an auto car cuz the original ones choke didn't seem to open right. -
86 hatch ea81 carb non feedback failed co gpm at 107.2887 limits 20.00. Ive heard its a rich fuel problem but i don't know how to adjust it. my idle is around 800-1000 and the screw that had the pin blocking it is screwed all the way in when i checked it after emissions i backed it out 2 turns but doesn't seem to change idle don't know if driving is different or if it will pass emissions just from backing out the screw. it passed everything else.
+1 on the Nissan alt just did one the other day very easy drops in with minimal work just some grinding of the spacer and drill the wire eyelet out a bit and remove or solder new plug on just be sure the threaded part on the alt fits the bolt good mine stripped out but it could just be that I got bad threads.
If your tires are worn differently or tire pressure could it be binding cuz of the tire size differences?
Awesome you're actually doing it take a bunch of pix. And maybe I can take a ride in it when your done.
ea82t almost no oil pressure
im running 10w30 ive always ran that but just about a few months ago it was ticking on and off then i put a new mickey mouse gasket on but the dealer didnt order me a oring but i got the shaft seal but never put it on cuz it looked hard to do. then after about 2000 miles of ticking (i didnt want to waste the new oil to put the other gaskets on) I did the oil pump oring and shaft seal left the mickey mouse on there still cuz it looked new and put my gtx 10w30 and a pure one oil filter started up nice and quiet till warm then it ticked but not as bad and wasnt getting as much oil pressure as before doing any of the seals. so do i need to run like 20w50 and maybe do my seals again they all looked great when i put them on and it doesnt leak from the pump. or could it be the relief valve spring going bad or stuck open? -
just resealed my oil pump all three seals and now i dont have oil pressure when warm and only goes to about 45 when first started. does the relief valve spring add pressure or is it the 14mm hollow check valve tube in the cam case add pressure. i have a pretty good lifter tick most the time but comes and goes with engine speed and idleing for a bit.
which fan is better
I added a another fan and changed my distributor timing and now it doesnt get hot so i dont even need the other fan now i just need to figure out why it gets bad gas mileage and to see if it will pass emissions now. -
which fan is better
coolant is good and i'll check the fan rotation as i didnt wire it i got it like that. -
thats cool my brother actually just got two 82 700 maxims and got one running and wants to bob it too. post pix when u start doing it.
which fan is better
ok the metal one is on a switch and is always on but still gets hot so i'll try and run both at all times. -
I have an 86 hatchback with the metal case electric fan but is it better then the slim black plastic fan. it gets hot right now with the one so I put the black one on but doesnt come on but it works with direct power just want to run the best fan out of the two cuz I heard the 50 amp alt shouldnt be running two fans.
