Everything posted by 952.2LX
Just wanted to replace a ball joint, but the axle pulled out!?!
952.2LX replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe axle came out of the inside hub without removing the outside axle nut. The steering locked up, so had to turn key on and then I aligned the axle back into (outboard CV joint)bearing housing. and added grease and rebooted. It went well except for breaking a separater. The ball joint came out with the wedge and the new one went in fine. The other side went smooth as butter. I test drove her and she is TIGHT!!!:banana: thanks all.
952.2LX replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyea i just got it back in. Thanks for the info. So there is no clip holding the axle into the wheel hub? oh well it looks like its all back in. Now for the other side.
I am (was) trying to replace the ball joints on my 95 impreza. Thought it was gonna be easy but some how the axle pulled out of the hub and the steering is now locked up. ... I was following the instructions and when i separated the ball joint the whole axle just like pushed out towards me ..and the wheel was turned towards me i guess from getting the joint loose....now what do i do? I put the new ball joint in....now do i need to pull the hub i guess and re clip the axle back in?....or should i dissconnect the steering linkage and then get the ball joint in and then the axle? any help would be most appreciated. update: ok i turned the key on to turn the wheels back straight.
Still need help with wheel noise
More info: Type of car? Milage? Maintenance history? Would help. I'm guessing the sound is from wheel bearings and the movement probably ball joints. There are others on here though who can diagnose a lot better than I.
98 Legacy: How to replace the leaking crankshaft seal
952.2LX replied to etc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHold on a sec.... I am just about done with a detailed instruction of doing what is called a "nose job" on a 2.2 liter engine. Which includes replaceing all the seals. I did mine a couple of months ago and have documented the entire process. Its in a .doc right now and i am unsure as how to share it best. but i'll try to finish it up tonight and if anyone wants i'll e-mail it to them for now. Its a guide by a novice for a novice...i'm sure there are lots of areas that can be improved on or done differently....I just know that the work i did seems to have been successfull.
Time for new shocks/struts?
952.2LX replied to davis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcool thanks for the response mssmith.
952.2LX replied to davis's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm shopping for some struts for my 95 Impreza LX. I have oem's on with 250+k miles on them. The backs are a little bouncey not bad, but I figure with the age of the car, all four should be replaced. Especially with my driving style. So the questions I have are. 1. KYB's or monroes or brand X ? 2. Should I replace the springs and mounts also? If so, where to get springs? 3. What about suspension bushings? should these be replaced at some point? 4. What about Body bushings? 5 Wheres a good place to shop for these parts?
how many miles does your Ej22 have??
952.2LX replied to felixwankel88's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1995 Impreza 2.2 ; 252,000 miles on her. replaced tranny at around 240,000, with one 100,000 miles younger. changed oil and filters every 3-5k. Use Lucas oil stabilizer. Replaced steering rack and pump (which was leaking bad). Just did a nose job on her. First time for me and it was soo easy.(except getting the crank bolt loose.) Gotta keep up the maintenace. Running great! needs struts. and suspension bushing wouldn't hurt.
opinions on a 96 outback
952.2LX replied to mdjdc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCould be a bad WP gasket. Thats whats going on with mine... a small leak on the WP gasket....loses a little coolant ...radiator a little low...overflow not filling up.
Subarus racing on ICE made the news!
cool Danny! you got National exposure! LOL . yea joining my local SCCA this weekend and gonna start gettin into rallying more. I have a need for speed!
Dumb first timing belt question...
952.2LX replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1997 i'm getting ready to do the same thing on my 1995 2.2 AT. Luckily I have the non-interference 2.2. It's great reading so many post on doing a "nose job" on these. Lots of info. Keep posting. I am gonna try and take pics as I go when I get started.
Subaru Powered Rockcrawling Buggy
If ya need any assistance with autoCAD let me know. I think cobcob also knows a thing or two about CAD.
95 Legacy intermittently runs rough
952.2LX replied to reeze's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've had no problems with aftermarket plugs and wires on my 95 Impreza with 250k miles. I've replaced them several times and To me its just not worth the extra 50 bucks everytime to use OEM wires. Now if I had a newer soob with maybe 50k miles, yea I might consider OEM wires. Just my 2 cents worth.
93 impreze 2.2 timing question
952.2LX replied to coppermtn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, I now have all the parts except for a new set of tb covers. Waiting on that....and then the weekend will happen. Probably also gonna help cobcob with a couple of 2.2 hg's he needs to replace. So that'd be a good experience.
100 Acre Wood 27-28th...
Well the weather looks like snow and a high of only 35...brrrr...it'll still be a blast though.
oil pump o-rings ?
Yea the dealer had the O-ring and crank seal for my ej22...I guess I didn't ask for the right part.
oil pump o-rings ?
Ok, thanks Rx I'll ask again at the dealer. I'll ask for the "pressure port o-ring". Does anyone know of a good exploded view drawing of the ej22 oil pump? In addition the chiltons is asking to measure the distance between the rotor and walls and some other measurement. It states that if this is OT then replace them. Is this really necessary? I have to add that I have 250xxx miles on my ej22 and i'm doing this nose job, 1). for experience 2). cuz its my daily driver and I want to continue driving it for awhile. Still need a set of TB covers also, if anyone knows of a good set with bolts.
oil pump o-rings ?
Ok, I will give Jason a call. I dunno its just conflicting information. The chiltons says there is one, but doesn't show it on a exploded view of the pump? The dealer here in Springbilly says there isn't an O-ring? But here on the forms I've heard there is an O-ring to replace when doing a nose job on an ej22.???
Yeah this will be a blast, hopefully we'll have nice weather.
oil pump o-rings ?
speaking of oil pump o-rings. I asked the dealer for this part and they said my engine doesn't have an "oil pum oring"...it just seals to the block? Anyway is this correct? I have an ej22 engine 1994 aug. build.
Need advice: Looking at a 1996 Outback to buy
952.2LX replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSo I saw this car at another lot. A consignment lot..lol and they wanted 4950 ! ! ! I couldn't get the money anyway. I'd only give 3200 for it.
Coolant overflow tank full??
952.2LX replied to 952.2LX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUpdate: gonna replace water pump, timing belt and pulleys, and oil pump seal and reseat, cam seals. Need new Timing belt covers. So its running fine now. I 'm just keeping an eye on it until i can get some covers.
Pulled the trigger...
Well if work picks up maybe. And if the banks start letting go of some money, mabye. I have just always liked that style of Impreza.
ok so I found a 2000 rs 4dr. Has some minor scratch's and some interior damage, drivers seat torn some tears in the pass. side door panel (look like finger nail marks..) they're askin 4900....what did everyone give for their rs?
Bad power steering pump?
952.2LX replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell yes and no. the yard pump didn't have the same back plate as my oem pump which had the back mounting bracket holes. So, I switched them out and put a new seal on the sy pump. That seemed to work. Although after thinking about it I don't know for sure that the back support bracket is really necessary. Yes It worked for what I wanted, which was to stop the leaking. Just make sure to bleed the system good after all is hooked up. Oh, and last fall cobcob and I put a new rack in my car also. Rack was about 175.00 from a salvage yard. I was told from the soob dealership that it was worn out really bad and they wouldn't even pass it in an inspection. So, Basically I have replaced the whole system minus the lines. The only difference between the newer rack and the bad one that I noticed was ease of turning. before I could feel some weird resistance when turning and now its a breeze, one finger wheel turning.
