Everything posted by harpua
Once more...please help
Sounds too me like you ended up with the wrong alternator. I had this exact same problem with my 1980 wagon. I ended up wireing my fuel pump direct to the battery to get it to stay running for more than a few seconds before i figured out that i had the wrong alternator on the motor. the difference between alternators is that there is one that is internally regulated, and one that is not. If your car has an external voltage regulator, and you put in an internally regulated alternator then you get less than desireable results. Try to figure out if your car is externally regulated, and find out if that alternator is internally regulated. That is where i am putting my money....hope it helps.
Really cold weather, and my heater doesn't blow warm air.
well i finally got it working again.....it was frozen solid. I had to let it idle for about an hour, didn't work, so i went driving...after about 20 minutes of driving around, the heat started pouring out.... so now my question is, is 50/50 water and antifreeze not a good combination for winter? what else can i do to prevent this from happening again?
yes, the flapper is moving correctly. I had heat 2 days ago, so i am pretty sure that it is directly related to the cold weather we have had. I am going out to tinker with it right now, so ill keep you all updated.
will do GD....
My temp gauge is going up a bit higher than 1/2...where it usally doesn't go above the half way point. The heater isn't blowing any warm air at all, it is cold as can be. archemitis, how did you fix your problem? Or have you yet. I am thinking that i have the same problem as you. Flow, i think my belts may be slipping as well because my voltmeter is reading low as well.....how do i fix that problem?
We have had some sub-zero temp. nights here in central oregon, and now my heater doesn't blow warm air. Did the lines going into the heater core freeze? or is my thermostat not working properly? any and all suggestions are welcome here. im hoping one of you guys has a good trick to jump start the heat again. thanks donny oh yea, make and model is a 1981 hatchback.... One more thing. Before my heat quit pumping hot air, i had that gurgleing sound on the drivers side near the firewall everytime i would downshift, or get into higher RPMS....That is the reason i think something is frozen. and yes i have antifreeze in the car....
muffed tire....wintermaster plus....attention EDRACH
nope, i screwed it up the day after....good thing too, cause i didn't want to drive on the spare too far. tree lasted the trip in great condidtion. i little wet, but no biggie. i cut off about 2 feet to make it fit in the house just perfect. i even had some people asking where i got it when it was still on the car....i have to admit, we did find some good ones.
Well right freakin on! Les Schwab found the tire i need (after some serious searching) for only $19.00 The tire that i needed is a discontinued tire, so it was especially hard to get hold of. Ed, thanks for the help, i really appreciate it. a muffed tire is like a f***ed up tire, just the edited version.....muff diving = good ..... muffed driving = bad
I am in need of a 185/70/13 WinterMaster Plus tire.... does anyone happen to have one? or...Ed where did you purchase the tire I bought from you? Hopefully i can just run out and pick one up... thanks for reading
down the road.....
hehe, if he had a computer, he would have been all over it. i told him all about us, and told him that if he had a question that i could post it up for him. We need to make USMB business cards or something to that effect. Something we can hand out to people.....
down the road.....
My first subaru, the subaru that started my addiction, has just driven away with a new owner. It went to a good home. The new owner is a subaru lover who was invovled in an accident in his 88 gl wagon about 3 months ago. He was T-boned by a drunk doing 60. Anyway, he wanted a subaru that was identical to his old one, and he found mine. I guess i just have to find other subaru's to fill the void (wait i already did....mmmmm RX:D ) its kind of hard watching them drive away....
Going on a Road trip Monday.......Need Emergency Contacts..?
Hey John, i suppose you may be coming through Bend on your return trip....if i can be of any help, just let me know....you are more than welcome to stop on by for a little break after that gnarly eastern oregon haul. later donny
Oregon Off-Road Subaru Club's Anual X-Mas Tree Run
yes oregon does require a tree permit to get an xmas tree. here is a link that may be helpful. i know that im my area the permits are 5 bucks and you get them at the Forest Service office. link http://159.121.125.11/swo/notree.htm
it sounds good to me. i may have some trouble finding a CB, but im on the look out.
hey john, i think i may be coming. Where are you guys planning on going?
problems with brakes '81 hatch (man who cursed me?)
thanks miles, isn't the brake line going into the caliper at pretty close to the same hight as the bleeder valve? Which would put it above the fluid and should be able to leave the caliper in place to bleed the brakes right? i am thinking i will go buy another caliper as soon as i can (hopefully by the beginning of the year) but until then i need to get this working i think...
Alright, so i go to bleed my brakes, and i instantly break the bleeder valve off. I take it to a friends shop, and break an easy out in the hole. After many failed tries to get the ********** out of the hole, we give up. I now have that hole completly sealed off. no longer usable. my question is, should i try to bleed the brakes by undoing the main brake line? would this be an effective way to bleed my brakes, or should i just give in and go buy another caliper. by the way this happened to the drivers side front caliper on my 1981 hatch. thanks for reading donny
AT Soobs are definatly gutless!!!
*IDEA* Pull the axle out of the car. Put it on a hard flat surface. Go get a big sledge hammer. Proceed to beat the living hell out of the axle. Put the sledge down. Confirm death of axle. Continue to put a new axle into the car. When done stop and think about how much fun it was to beat the bearings out of the axle. Proceed with your day. Hope this helps....its what i would do anyway.... later
do owr subees have Rain gutters?
As far as i know the rain gutter ones will work.... and if you are interested there is a used sports equipment place here that sells all sorts of roof racks for pretty reasonable prices. Let me know if you want me to help you get something. later donny
Body lift on uni-body car¿¿¿¿
Hey Zap, i have spent some time in Star Valley.....lets see like 18 years of my life...... Zap isn't lying when he says it sucks, cause it does. But strangly i miss it still. Well the fishing and mountains anyway. Not the people by any means. Where in Star valley did you stay zap? And why in the hell where you so far from home? sorry for the hijack....now back to your regularly schedualed program....
Snow!!!
ok, here are some pics of central oregon...... http://usmb.net/gallery/view_album.php?set_albumName=albuo92 p.s. IM GOING TO GO PLAY NOW
First Tracks in the Snow for the Suby
Well it started snowing today at about 2 p.m. So after work i took the long way home through the mountains....Got to play in about 3 or 4 inches of freshly fallen snow. My suby loves the snow, and there is more coming in the morning (or so the weather man says) Anyone else treating their subaru with snow yet?
*more* Video of my Wagon off-road in Oregon
Very nice movies....more are always welcome on the board!!!! thanks brian. donny
Attn Mudrat
I heard through the grapevine that John is pretty busy of late. I guess he is moving his family into a new dwelling. Be patient with John for the next little bit. donny tyler
October 12th Hillsboro Rallycross
Results are up: http://www.oregonrally.com/?page=results Nice work everyone!
