Everything posted by svxpert
part number for rear oil seal?
svxpert replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthose 4 digits are not part numbers in the diagram, they are month 00 and year 00 codes. if you call a subaru part department they will be able to give you the part number. its been superceeded a few times and as far as I know, the rear main seal is the same for all pre2009 subaru 4 cyl engines back to the ej22.
location fuel pump 2000 legacy wagon
svxpert replied to 86subaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXremove rear (bottom) passenger seat. remove plastic retainer clip remove door sill cover pull black rubber mat toward drivers side football shaped metal cover with four phillips screws
Pull engine or transmission?
svxpert replied to tidd1340's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXif your only putting in a clutch fork, you can split the trans from the engine a few inches and do it that way. no need to totally remove either of them.
Smashed oil pan....possible problems?
svxpert replied to NameTaken's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyour not going to be able to "hammer" those dents out. there are baffles in the bottom of the pan that will keep you from getting to the dents. pick up a used one from somewhere. heck, i have 3-4 laying around in my shop if you need one.
Oil Pan Leak
svxpert replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell, depending on where the dent is located on the pan, you may want to replace. if the pickup tube is damaged, you could have a nasty oil starvation problem. just ask some of the 2004-2008 EJ255/257 owners!
Question for 2010/11 Legacy Owners
svxpert replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXleather, cloth, power or manual?
Making oil pan gasket
svxpert replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcork gaskets were phased out by subaru back in the ole' ea82 days. back in the day I would use a torch to burn off the old cork gasket and then a wire wheel to finish it off. what a P.I.T.A. silicone is used for oil pan gaskets now. silicone oil pan gaskets done correctly will last the life of the car. i have never had any problems with the ones I do in my shop.
Phase 2 2.5L head removal pictures.
svxpert replied to dennis111's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen you had the engine apart did you do the water pump, pcv and any idlers? did the felpro kit come with the oil pump seal and cam seals?
2.5L headgasket redux
svxpert replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX<<I asked the service guy "Am I making too big of a deal about this? Would you buy one that hadn't already had the headgasket replaced?" His answer: an emphatic "NO.">> <<Please don't take this as a sign of disrespect, but when you have access to a factory trained mechanic who has worked on literally hundreds of these things, you'd be wise to follow his advice.>> wait, did you say you asked the service guy or the factory trained mechanic? im confused?
Do I replace the rear main seal?
svxpert replied to HankG's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi cant see anything in that pic other than some type of sealant hack job someone put on the rear main seal. the seal goes on with a touch of oil only.
Nav in a 2008 OBW - worth it?
svxpert replied to J A Blazer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha, have it in my spec b, only because it standard. i hate it. we opted out of it in my wifes tribeca and outback. get a stand alone like mentioned above.
So...what IS the new OutBAck really!? Reskinned Tribecca?
svxpert replied to SubeeTed's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXV what? this is a Subaru were talking about. H
2005 EJ25 Block w/Phase 1 EJ25D heads? Bent valve damage piston?
svxpert replied to wtdash's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe 2005 engine is most likely SOHC unless it a turbo (STi) if it is a SOHC engine you would be putting DOHC heads on it. you would at the very least need the intake manifold and exhaust from the DOHC engine, plus other parts.
Legacy GT 2.5 vs Outback 2.5 engines
svxpert replied to jetpackboy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXall subaru 2.5 engines are interference.
oil cooler in a soob
svxpert replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthey came stock on the forester and now come on every turbo subaru puts out. i dont know about the n/a newer ones. shoudnt be a problem if you let the car warm up as per owners manual.
99 Outback driveshaft assembly
svxpert replied to SwimShady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX"hey, i'm in NJ and looking for a new driveshaft for my 2000 Outback MT. Where are you?" 08080
Of my timing belt, pulleys, and Orbach's
svxpert replied to The Chad's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX+1 i cant agree that they would'nt need replaced at 173,000. for the extra $200 or less i would have had them replaced. how much was it for the timing belt install? did they do anything else like valve cover gaskets?
bent valves question
svxpert replied to Scotty1419's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyou cant just "turn" the cams. if he does, and the pistons arent in the correct spot, he will bend valves. lets not give bad info out here and try to help this guy out. how was the crank sproket out of time? what did you do to put it in time in relation to the cams? i wouldnt attempt to start it anymore without some good help. all you will do is shatter a piston or damage a cam pulley.
Just bought an '09 Legacy...
svxpert replied to mrbucket's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhow many miles on the legacy and is it a turbo?
svxpert replied to SwimShady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhere are you located? i have a few new ones (less than 1000 miles) in my shop in NJ.
phase 2 timing belt question
svxpert replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXive never seen a 2001 or a 2002 legacy DOHC engine. i dont think they exist. DOHC stopped in 1999 and started back with the turbo legacy in 2005
Chilton manual
svxpert replied to Roger Stokes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXis it that hard to find a qualified subaru mechanic in your area? im sure someone can recommend one for you. just thinking it will save you from headaches laters especially if your gonna give the guy a chilton manual.
Dealership trouble
svxpert replied to Scoobywagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwait, am i missing something here? you were more worried about the headgasket leaking externally rather then a timing belt that was (lets just say 30,000 miles overdue) unless you put 60,000 miles on the car after you bought it. (which is possible)
95 ej22 with siezed / busted cam shaft
svxpert replied to johnceggleston's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhaha, i hope the pic of the oil pump on the first page isnt going on an engine like that! one thing i have learned having my own shop is there are alot of hacked up repair jobs out there.
Locking flex plate
svxpert replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXits so much easier to remove the engine and put it on a stand to do headgaskets. that way you can use airtools to crank the crank bolt down. how did you do the correct torque sequence when u need to turn it in degrees?
