Everything posted by svxpert
those 4 digits are not part numbers in the diagram, they are month 00 and year 00 codes. if you call a subaru part department they will be able to give you the part number. its been superceeded a few times and as far as I know, the rear main seal is the same for all pre2009 subaru 4 cyl engines back to the ej22.
Oil Pan Leak
svxpert replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
well, depending on where the dent is located on the pan, you may want to replace. if the pickup tube is damaged, you could have a nasty oil starvation problem. just ask some of the 2004-2008 EJ255/257 owners! -
cork gaskets were phased out by subaru back in the ole' ea82 days. back in the day I would use a torch to burn off the old cork gasket and then a wire wheel to finish it off. what a P.I.T.A. silicone is used for oil pan gaskets now. silicone oil pan gaskets done correctly will last the life of the car. i have never had any problems with the ones I do in my shop.
<<I asked the service guy "Am I making too big of a deal about this? Would you buy one that hadn't already had the headgasket replaced?" His answer: an emphatic "NO.">> <<Please don't take this as a sign of disrespect, but when you have access to a factory trained mechanic who has worked on literally hundreds of these things, you'd be wise to follow his advice.>> wait, did you say you asked the service guy or the factory trained mechanic? im confused?
you cant just "turn" the cams. if he does, and the pistons arent in the correct spot, he will bend valves. lets not give bad info out here and try to help this guy out. how was the crank sproket out of time? what did you do to put it in time in relation to the cams? i wouldnt attempt to start it anymore without some good help. all you will do is shatter a piston or damage a cam pulley.
