Everything posted by shortlid
My '98 Legacy L wagon with EJ22 and 4EAT has 141k on it now. Now that we have 2 FEET of snow here in New Hampshire I have been noticing that the rear axle does not engage till teh front wheels have made a few full rotations, then it hits hard on lock-up. This car had the tailcone replaced becouse of the tourque bind problem at 45k, I don't know if that could have a affect on teh delay. It just seems that it taking longer and longer for the clutch to engage the rear wheels in slipery situations?? Anyone with AT experincing this with 100k+ Roos???
Has anyone on the group found a good replacement for the SOA crush washers? I replace them everytime i chnage the oil or ATF but I don't like throwing anything more than I have to away and they ar $1.25 EACH from the local stealership!!! I found a aftermarket drain plug that came with the right size rubber gasket???
Ya, any autoparts store in VT should be able to test the output of the alternator. But if a new battery is not starting the car the alternator is not up to snuff. I live in Nashua, NH and I know how cold it has been in Norther New England the past two weeks. All my family lives in Woodstoock, VT lots of good Subaru mechanics in the Northern Northeast!!
My '98 Legacy L wagon with the EJ22 has 140k with only the tourque bind problem with the Automatic Tranny and my heatercore leaking? There is some early 4WD/AWD imports out there. The early '90's 4WD Honda Civic Wagons were good so were the '89-'92 Toyota Corolla 4WD wagons. But both are harder to come by?
I have a '98 Legacy L wagon with the EJ22, AT and 140k on the clock. My Check Engine light just came on. I got it checked for free at Advanced Autoparts and the code was O2 sensor out of perimeters? I know they should be replaced they do have 140k on them. Anyone done this on a California emissions car? What brand O2 sensor you use. I can get a Borg Warner without a connector for $48? Stock is $150!!
Brakes and tires are not THAT specialized on a Roo. You can take your car to a place like Costco for tires. You just need to make sure you replace all four at once, since we have AWD and diff. circumfrance tires mess with the AWD system. Also any good import shop should be able to put a set of pads and rotors on you car. I went with Brembo replacement rotors, and Raysbestos Import Quiet pads on the front of my '98 Legacy L wagon and I love them. The Stealership will do just that steal from you!
