Everything posted by THAWA
Yard Run!! Reno Then Carson City!! (5/15/04)
oh thank god
Help choosing exhaust EDIT: Pics added(56k warning)
THAWA replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX3rd cat? I didn't think bg's had that many. Do you have any pics of your setup? If you've still got a joint somewhere you can always get pieces from there back.
please tell me at least one of the legacy's was a manual
THAWA replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you have the pipe made with joints like there were on the standard exhaust? Or is it all one piece?
Quick parts question
THAWA replied to simpreza2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe coolant tank will fit fine though it might have a hose coming off the top of the cap where as the older ones don't have this. the powertrain and stuff didnt really change, some minor things here and there but for the most part its all the same from 90-94
Forester in FWD Mode - bad idea or save $$
THAWA replied to JOEK39's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe reason they suggest you don't do this is it puts duty solenoid C into 100% duty mode. It'll overheat or wear out or something, I don't quite remember what goes wrong with it, but it certainly isn't good for the tranny.
rio red or ruby mica subieman?
Got a legacy, but no skills
THAWA replied to pennink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit could be done in about 10 mins if you know what you're doing. its only 7 bolts for everything
THAWA replied to pennink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI believe he's already got a chiltons
THAWA replied to pennink's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXone of them there's a clip dealie on it, just push that in and pull it back, the other you have to lift the lil rubber boot up and unscrew the bolt and just remove it. It's incredibly easy once you know how to do it
93 legacy "manual" button? & cost opinion
THAWA replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsometime before 97 I would assume since he said he's got a fwd 4eat
Auto tranny woes
THAWA replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhen was the last time it was changed?
Auto tranny woes
THAWA replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere's no overdrive in a subaru 4eat. What you're experiencing is the torque converter locking and unlocking, well in your case unlocking. As far as that chattering thing, sounds like torque bind.
THAWA replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUnless they changed something from the legacy 4eat to the impreza 4eat that isn't true. If I leave my selector in 1 it will shift up to 2nd gear when it hits 6500 rpms. however if I leave it in 1 and slow down to an acceptable speed for 1st gear it will downshift into that.
guess who's got fri and sat off you guys mind if I either follow or ride with one of you? My car is actually doing better than before! No more crazy grinding scratching sounds or anything. Haven't lost drive in a while either, but I need some more parts and i really don't feel like waiting for the dealer to order them. so yeah, lemme know what's up.
THAWA replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe awd part only applys to when it's in 1
THAWA replied to AKIRA's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTo add to that the manual button does work in 1. However it only changes the AWD map.
Sweet Impreza running forever...questions?
THAWA replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhy do you think there's been engine work done? it's not an ej25 Properly cared for you wouldn't have to do anything be preventative maintanence to keep the engine running for 275k miles.
Overheating Issue
THAWA replied to Derek's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell you can be 99% sure it's the hg's, ej25's are notorious for blwoing em
Where to find fuse box?
THAWA replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXright above the kick panel. look where your left foot would be and turn your head to the left. it's black and has writing on it or a sticker with writing.
Coolant Level Rising in Overflow tank
THAWA replied to root4u's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHad this happening to me last year, turned out that both my hg's were blown. I'd go get the coolant sniffed for hydrocarbons.
THAWA replied to simbey1982's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny ej series engine will mate to your tranny and all that ****, wiring will be the issue. Ej series engines include, the ej18, ej20, ej22, ej25, ez30 and eg33, the later two being six cyl's. There is no difference in the engine as far as manual or auto setups. The jy is probably going to be the absolute cheapest.
irregular metalic tapping-rattling noise
THAWA replied to juniorbill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://bbs.legacycentral.org/viewtopic.php?p=34454#34454
THAWA replied to juniorbill's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXcould it have been from the slack or lack of slack in the drive belts? I've heard similar stories about it, lemme see if i can find the link.
Head gasket replacement on 90 legacy
THAWA replied to Brutewrench's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXclose, it was a sedan. I dunno what other stuff you had to remove from the head, do you mean the valve covers and stuff, or are you talking cam sprockets and manifold and stuff? Also brute I dont think it's possible to remove all the bolts or any for that matter without removing the head. As for that screw, it's not supposed to be adjusted. You should try and put it back to where it was set from the factory, should have some paint on it to line it back up.
