Everything posted by THAWA
I think he means 4x140 bolt pattern
dont be afraid of the ground clearance. there's plenty to get you out of most situations. Like ralllyruss said rally cars dont have huge ground clearance. they just have ultra stiff shocks/struts and springs. You'd be better off spending that money on a good set of DMS coil overs or something.
2005 To 1992
THAWA replied to BC_Grown's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
if you insist: nOOb -
Dohc Ej22???
THAWA replied to GLCraig's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
there's no need, listen to someone who has seen the inside of an EJ22E, instead of corky -
Dohc Ej22???
There isn't the correct smilie to show you just how i feel while reading this post. It's obvious to me that you've 1 never taking the heads off an EJ22E, and that 2 you'll just say whatever you want without finding information to back up your claims. You're talking to someone that has replaced his headgaskets on his ej22e. I'm 100% positive it's an open deck engine. I'm also 100% positive the only closed deck EJ22's sold (not imported) in america were from 91-94. Really you need to try to learn about a topic/idea/arguement before you start spouting out information that you don't know about. So now I need to ask you, where did you get the idea that EJ22E's were closed deck? It also doesn't take away from the fact that we didn't have any MY89 legacys! I don't have any official links to the subaru code thing. Really though, your last post just put a HUGE smile on my face -
Dohc Ej22???
I believe what you say when I don't know for a fact there's something different that is true. I do believe the passages are different, but what I'm wonder is if someone has had a real life problem with them mixing. Yes it would be ideal to use the same heads with the same block, but just because the two things dont line up identically doesnt mean you cant use em. Just trying to find the truth is all. -
Dohc Ej22???
A range for ej22 closed decks? There are only two closed deck ej22's the EJ22T and the EJ22G one from 91-94 and the other in 98 or whatever year the 22b was made, so now please explain to me how a range of closed deck ej22's from 89-94 is an accurate thing to say? By your logic I could say a rance of closed deck ej25's from 1976-2005 and be correct. It just doesnt make sense to add irrelavnt years. Sevral people? Try one who is incorrect. FHI Has never stamped an engine with more than 4 chars to my knowledge. There's no reason for them to. If they did the blocks would HAVE to have the same Heads all the time, but look at the ej255 and ej257, same block but different heads, yet the block is only stamped with EJ25. Please find me an ej block with more than 4 characters stamped in it. Now if you'd actually tak th time to look at the engine code on the placard in a legacy turbo engine bay you'd see it says EJ22T insead of just thinking you're right. -
Dohc Ej22???
you were saying ej22g models (actually ej22t) and they didnt exist until 91. I didnt say anything about the casting. All the blocks are only case with teh first 4 digits of the engine code. Go look at the placard in a legacy turbo engine bay like I said before, or read the thread I just linked to that shows people reading their placard and indisputable evidence that the EJ22G and EJ22T blocks are different (yes someone disassembled a 22b motor. G doesn't mean closed deck, G means DOHC MPFI Turbo, like matt said that you didnt read. So explain to me how a usdm 91-94 legacy turbo engine can have the engine code EJ22G? And can you PLEASE answer my question about anyone having problems with oil and coolant mixing? WJM what matt monson said was true. -
Dohc Ej22???
I was talking only in america since the subject was in reference to turbo EJ22's, we don't have MY89 legacy's here and we dont have MY89-MY90 Turbo's here The Legacy RS-R and Legacy RS-RA weren't actually Legacy STi's, since STi didnt exist back then, or it wasn't an actual company. They were highly tuned machines but weren't called STi's -
Dohc Ej22???
that's quite possible, I should've said I'd never heard of any -
Wow!
