Everything posted by 1-3-2-4
Cracked transmission case
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuestion I was under my car a few min ago and I was looking at the shifter linkage.. the part that goes to the shift is the one that connects to the round part with the two blue bushings right? How is it held in? Check the amount of play I get.. cheap sub $90 cam too cheap to upgrade right now 1:16 shows how crazy it is lol being in first gear is still easy to mistake as being in neutral. nevermind found it! ordered a 1/8" and 5/16" center punch both 8" long looks like my others walked off
The Awesome *NEWER* Generation Picture Thread
1-3-2-4 replied to Red92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubscribe! i will post mine a bit later
Uses for Ultra Grey/Black?
1-3-2-4 replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah I did the oil pump water pump and cams and I have enough left for a good while
1-3-2-4 replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRemember about a year ago I had a hard time finding that stuff? In the end I found it at Napa but Like those 4 weeks before none of the auto stores like Autozone and Advance had it.. Not soon after I pull my motor Advance got it in.. I still have a bunch of anaerobic left.. Was I the only one who thought it was going to come out real easy out of the tube? haha
1-3-2-4 replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just have the normal Permatex anerobic I used it on the oil and water pump and rear separator plate
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh yeah I forgot about that.. maybe just to be sure I will swing by the dealership to get the new roll pins, I might hit the linkage today with some kroil to get a head start.
1-3-2-4 replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI never heard of anearobic being used on a transmission case.. if I'm right it would never seal because it's not 100% sealed off with the two halfs?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI "Should" be getting the transmission this Friday 2 hours sounds about right for a swap right? lol my family members have been talking.. blah blah should of got a newer car.. what difference does it make? I already did the hardest part (pulled engine for HG) the transmission is like so much easier to deal with as far as going in and out. *sigh they will never understand.. Mind you one of my family member's owns a 95 ford tarus who has 95K miles on it and has spent about $10K in repairs so far including a replacement transmission!
1-3-2-4 replied to 1997reduxe's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou can use ultra grey on the tranny case too right?
My '83 GL: The Ski Wagon
lol where did you get that R/C brat from?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXnope mine was the twisted up metal stuff like in your picture.. I did not bother taking a picture of it before I threw it out
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had that same sheet metal stuff on mine.. matter of fact when i drained the tranny last year during the summer I saw bits of those as well. I too can't figure out where it's from because it feels pretty thick, thanks for the confirm on the starter hole hah I just need to lift it from the trunk and just get it on the ground. hopefully with the replacement trans in I wont be doing 3500 rpms at 60 mph
Is the head gasket problem fixed?
1-3-2-4 replied to Geoff77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know this is a old thread but the best way I found for removing plugs on the DOHC is to pull them from under the car then from above.
wow good work so far!
Shifter Linkage Replacement
1-3-2-4 replied to doc526's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI finally have the shifter linkage in hand after my tranny took a dump.. quick question is it really needed to replace the roll pins? because I did not get those when i went to pick up my order. The shifter rattle and sloppy feeling was bugging me. Going to get the new pins
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI guess it did not take 3 days to get here picked it up same day
Sloppy shifter questions: Just bushings, or linkage too?
1-3-2-4 replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got subarupartsforyou.com AKA (Dan perkins Subaru) to make a link for this shifter part # 35047AC010 it's under ZZ special order, shows as a impreza part number and that it's not in stock but to my surprise they just sent me a email that it's ready to be picked up so I'm going to head out to go get it.
1-3-2-4 replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwell I hope so I have lots of koil here.
1-3-2-4 replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXto take off the whole linkage the pins I'm not too concerned about it's about getting the linkage off
1-3-2-4 replied to tehP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXQuestion is it room enough to use a air hammer on the linkage? my car has a spring return so mine should be the part number 35047AC030.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds good, So let me ask you a 6 ton jack stand with a 24" max lift should be more then enough to get the transmission out while on the transmission jack right?
P0136 on '02 forester
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe scanner is new enough I guess that's why it was throwing the code?
My friend just drove by to check on how I was doing and also because he had a code the code reading was saying the code and circuit malfunction Bank 1 Sensor 1 if I remember right.. I know I went into live data and I only saw the rear o2 sensor. the car has about 90K on it bad sensor or really a circuit issue?
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXah finally found the thread.. never knew we could search by now many reply's per thread made it that much quicker to find So but say on a used transmission with like 86K I should be just good replacing the front seal, no? Do you know if the hole where the stater motor goes is enough to support the weight of the transmission to get it out of a car's trunk? I can't find what part number 35047AC030 goes under at subarupartsforyou.com I wished you can search by part number, I'm going to ask.
1-3-2-4 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was thinking that too but the main bearing is at the rear of the case right? That's a long way for travel.. And for the seals if i can remember it has a total of 4? Rear driveshaft 2 drive axles input shaft
