Everything posted by Don_Quixpunch
81 Brat GL clutch cable.
Don_Quixpunch replied to Don_Quixpunch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, I went to the dealership first. They say the part has been discontinued. -
Remanufactured Engines
Don_Quixpunch replied to Jake DMC's topic in Historic Subaru Forum: 50's thru 70's
A friend of mine owns a place called Metric Motors and he's all about the JDM engines. As I recall, he gives a one year warranty with them and while he does once in a while get a dud, you just can't rebuild an engine right and compete with the price. Plus, most of the JDM stuff is built to a higher standard than the crap they send to the states. If I were going to buy an import recycled engine, my biggest worry would be the reputation of the shop that's importing the engine. If you've heard good things about them standing behind their product, I say go that route. -
So my clutch peddle bracket folded and while getting it apart I see that my cable is pretty frayed and probably on its last legs. Does anybody have any suggestions on where I might find a new one? I've already tried Pep Boys, Napa, Subaru, and Rock Auto with no luck. Or maybe can I use one from a more recent car?
Cool to see an EA drivetrain standing up to that sort of use. Gives me hope for my Brat. And a great endorsement for welded diffs.
EJ Swap - now noise in my speakers
Don_Quixpunch replied to jrettenmayer's topic in Subaru Retrofitting
If I were having that problem, the next thing I would look at is how clean and tight the ground for the stereo is. If it's too hard to get to, I'd just cut the wire and splice in a new ground. As long as you hit the body, it doesn't matter where it is. When I put my head unit in, I just ran a new ground wire. But the PO committed some pretty severe *********************ery in my cars electrical system. -
79 Wagon fenders on an 81 Brat?
Don_Quixpunch replied to Don_Quixpunch's topic in Historic Subaru Forum: 50's thru 70's
Yay! That's just the answer I was hoping for. Thanks. -
I'm not incredibly knowledgeable with the Subie wiring, but I've been tinkering with stereos for years. I still have an EA engine in my Brat, but I upgraded to a 100 amp alternator. I changed to larger ground cables along with the larger power cable. No noise at all. Historically, my main cause of interference has been dirty and loose grounds. -
My new Brat AKA The Turd AKA LIL' BASTARD
Great score! I paid nearly twice as much for mine and it's rusty as hell. -
1st Brat 7th Roo
Don_Quixpunch replied to roosofallevil's topic in Old Gen.: 80's GL/DL/XT/Loyales...
@Sonicfrog. If you really want one, there's a first gen in SF that's about to get parted simply because the guy can't get it through emissions. -
You haven't mentioned what you've got in the way of amplifiers and such. But one thing that commonly gets overlooked is induction noise. If you have input level wires running alongside your main harness or a large power wire you can pick up a lot of noise through them. That's why the pros run power on one side of the car and signal on the other side. If that's not it, try looking at existing ground points for dirt and loose connections. Especially the ground for the head unit itself. -
@91Loyale, Things might have changed by now, it's been a long time. But when I made that trip, we usually got a few days in Christchurch then flew commercial to LAX. I'm guessing the flying down there is done by Air Force guys these days. If your friends are air crew, they would be able to bring damned near anything you want. But if they're just passengers, it'll probably be cheaper to ship UPS.
I need a new carb.
Don_Quixpunch replied to justaquestion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the input. Sounds like the simple regulator is the way for me to go. Hope this helps other people having the same problem too. -
I need a new carb.
Oops. Forgot to include the URL. http://www.aircooled.net/gnrlsite/resource/articles/carbs101.htm -
I need a new carb.
I just found this article about tuning carbs. This is the guy who jetted my Weber, and he's very respected in the VeeDub community. I got the Redline kit and jetting made it run so much better. Anyway, I've been wondering about the gasket at the top of my carb being gas soaked. The article mentions the need to check and possibly regulate fuel pressure. I've seen no mention of it here on the board, but there are people getting lots better mileage from their Weber equipped EA81s than the mid 20s I get. Hopefully, this will help others with the Weber upgrade as well. Could I swap out my aftermarket pump that shoots too much pressure for a factory pump and solve the problem? Or do I need to pony up the cash and install a pressure regulator? If I use a regulator, will it simply hold the built up pressure in the line behind it? Or does it need a return line? While I'm at it, did I mess up by not installing a return line to the carb? -
I finally started patching the holes rusted through my inner fenders! In the summer, the extra airflow coming through the edges of the firewall was kind of nice. But in the winter, the heater can't even keep up with that much cold air. I started by ripping out all the rotted metal, then wire wheeled till I had bare metal quite a way past the hole in all directions. Then I filled behind the hole with Great Stuff spray foam. After cutting the foam to match the contour of the original inner fender, I sprayed 3M spray adhesive over the foam and just barely onto the metal, then covered the hole with aluminum foil so the fiberglass resin couldn't eat away the foam. Finally, I layed in a single ply of 1200 weight glass with a generous overlap onto the metal. I'm giving the patch a couple of days to fully cure before I go back and sand the spots where the peel ply didn't stick, then feather the edges just a bit, drill some holes and rivet the patch in, then finally goop some undercoating over the whole mess. I know, fiberglass isn't the best way to repair steel panels, the consensus seems to be for a max life of 3 years for such a repair. But if I had a donor car for those inner fenders, I'd probably fix it up instead. Once this project is all the way done, maybe I'll get brave and start poking at the rest of the rust underneath to see just how bad it is. Somebody please hold my hand, I'm scared.
A question for the EA81 guys out there
Don_Quixpunch replied to xoomer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When I blew the head gasket in my Brat, instead of replacing the gaskets, I found a hydro lifter engine for 20 bucks. These engines seem close to bomb proof, you might be able to swing a similar deal. -
I want to trade this for this
Don_Quixpunch replied to Subieguy's topic in Historic Subaru Forum: 50's thru 70's
I'd pounce on it. But then, I'm not a huge Camaro fan and I do so love the first gen Brats.
