Everything posted by sario
first subaru!
Nice looking clean car!
- Anyone have experience driving the Coos Bay North Jetty road in Oregon ?
Ned goes to the beach...
Looks fun!
Aftermarket Drive Line
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was wrong, it does still do it with the FWD fuse in. I just didn't have enough of a load on the car when i tried.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe problem is still there with the FWD in. I'll check over the rear axles a little more, they are orginal. EDIT: I was wrong, it does still do it with the FWD fuse in. I just didn't have enough of a load on the car when i tried.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBummer, I guess I still don't have a lead on the problem then.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe drive line does appear to be flat. But while i was down there i noticed a loose nut on the transmission mount. I don't know if this could be causing the problem, or caused by it. But when i try to tighten the nut the stud just spins.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm told they are, but I didn't pull the drive shafts myself.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wish it had lifting blocks. But no it doesn't
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX1997 Outback Auto 270,700 The struts have around 50k and the rest of suspension components appear fine to my armature eye. The car is no where near bottomed out, i have king springs on which really help with that.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI couldn't get it to do it in reverse. But i didn't have it loaded down either.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've never tried. I'll find a big hill tomorrow afternoon and give it a shot.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt will do it going straight. But only with some extra weight and starting off on a hill. 4Eat
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen accelerating from a stop with a semi-heavy load, like towing a trailer, there's a thumping sound, maybe from somewhere in the middle of the car. It last for only 2-3 seconds during accelerating. No noise or problems once the car is moving. It also happens with just me in the car if I floor it from a stop while making a hard turn.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep I'm sure. It's the original drive train. well minus the propeller shaft.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe shop said that tires were coming apart at highway speeds, yes. The U-joints broke and a transmission mount broke as well. The bearings do not feel crunchy when i spin the driveline by hand. There is some play went i change direction of the drive line, maybe one or two degrees. I'm not sure I understand how different sized tires would cause this, but the vibrations went away with new tires.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI took the car to a shop for their opinion. They want to rebuild the rear diff, but I’m not convinced that’s the problem. I'm going to do some research and see if any LSD differentials from newer outback’s are a direct bolt in replacement. If they are, I'll use this an excuse to get do a bit of an upgrade.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey tire tread was separating at speed. . All the tread measure the same depth, but would actually go out of round at highway speeds. The first two that failed baffled me. I even took to a private garage that specializes in subarus, and they couldn't figure it out either. The third drive line broke at about 45 MPH, and broke the transmission mounts. I ended up having the car towed to a second garage, and they figured it for me.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI Pulled the drive line out today, but it actually seems fine. I'm really not sure whats wrong. I guess I'll have wait until the problem gets worse.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info, but i don't really have the time to rebuild one myself right now.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do have king springs on the car, so it sits about an 1.5" taller than normal. That might have something to do with my problem. Also I'm pretty sure the first two drive lines failed because i had tires that were having tread separation issues at speed. Do you think there is something else i should be checking for?
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt would definitely save me some money, but I've tired of replacing this drive line. I've boughten four used drive lines for this car so fair. Two of the failures were actually tire related problems, but the other two were just worn out drive lines. I'm hoping these aftermarket rebuilt drive lines will be a little more robust.
sario replied to sario's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHere's some a couple links to places i've found that sell them. http://www.drivetrain.com/parts_catalog/drivetrain/subaru_driveline_and_driveshafts_replacements.html http://www.rmdriveline.com/products-services/
