				Posts13042
				Days Won136
	P0026 and P0028 codes are for the variable camshaft timing solenoids. Specifically these codes are for the low oil pressure switches located on the solenoids. If the oil level gets low enough these codes may trigger because of a lack of oil. The difference between "Full" on the dipstick, and not showing at all is about 2 quarts. I would guess you're losing closer to 3 quarts of oil based on the codes above. 2 quarts in 2,000 miles could easily be from a bad PCV valve or clogged PCV hoses. You may be losing more due to external leaks such as the separator plate or valve cover gaskets. P0420 can be caused by a clogged PCV valve or hoses since this causes excessive amounts of oil to be forced into the combustion chambers and burned off as you drive. Oil affects the burn rate of the fuel/air mixure and can damage the catalytic converters.
- 7 replies
		- P0420 P0028
- P0026
					(and 1 more)
					Tagged with:
	You connected the EGR to the PCV hose? This is probably the problem. Connect your EGR pipe directly to the intake tube over near the IAC hose. With it connected to the PCV tubing the EGR is pulling vacuum on the PCV which is pulling more vacuum than normal in the crankcase. The PCV system is designed to pull only a certain amount of air through the crankcase. You may have doubled or even tripled the amount of air being sucked through the crankcase and its pulling oil out with it. I have two EJ22s, over 235k miles on each, which I run exclusively on 5w-30 oil.
	Losing signals could either be a loose connection at the DLC or just a firmware glitch in your scanner. If the ECU loses sensor signals there will be misfires or the engine will just stall. 96 EJ22 has three timing covers. The end covers are removeable without removing the crank pulley. I would expect there to be misfires or other problems if the timing is off.
	So the wheel appears to be closer to the body of the car? Make sure all tires are aired up to the correct pressure. Park on level ground and measure from the wheel center to the bottom lip of the fender. Compare left to right. A weak spring will cause one corner to sit the lowest and the opposite corner to sit the highest.
	I think its easier to just pull the trans, but it depends on what equipment you have available. Do you have large jack stands (18" or taller) and a large floor jack? You really can't put a jack under the pan on these transmissions without a transmission adapter. The pans deflect very easily and can damage the solenoids and wiring on the bottom of the valve body. Because of that you need lots of room to roll the trans under while its on top of whatever contraption you find to roll it around on. A furniture dolly works well but they're usually 4-5" tall. A transmission jack adapter is usually taller.
	Checked the FSM. The Parking brake switch and the Low fluid level switch are wired in parallel. Either one will ground the circuit and will turn off the DRLs. If the brake fluid level was not low, the level switch probably isnt the problem. Sometimes they get stuck if the level gets low. Usually a tap on the side of the reservoir with a screwdriver handle will joggle it loose. The parking brake switches are usually open to dirt/dust and the contacts can get dirty and/or sticky from a spilled drink.
	Probably just a loose or poor connection somewhere. The illumination control module is attached to the back of the lower trim panel under the steering column. Two screws to remove and that pops off and you can check the connector on the module. The bulbs in the HVAC head burn out, but are replaceable. You have to remove the unit to get access to the bulbs. Use 7219 bulbs from radio shack.
	Looks the same doesn't mean it is the same. There are two different final drive ratios and that has to match or you'll have problems. What trim model do you have and what model did the trans come from? Why did you remove the front diff housing? Did you try to swap diff housings? Did you fill the front diff with gear oil?
	You can use 2.25-2" reducer and just clamp it.
- 27 replies
		- 1997Legacy
- Outback
					(and 2 more)
					Tagged with:
	These use JRA style valve cores. A standard core tool will not fit over them. A few seconds with a dremel should widen the gap enough to make it work.
- 16 replies
		- a/c
- air conditioning
					(and 2 more)
					Tagged with:
