Snapped thermostat bolt in 01 Forrester
Fairtax4me replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the threads in the WP housing are crossed or stripped out you can drill it out and run a longer bolt through with a nut on the top side of the housing.
Interesting Transmission Activity
Fairtax4me replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWut he sed. ^ 100% Normal operation. Forgetaboudit!
99 OBW with twitchy handling
Fairtax4me replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXProbably tie rod end. Those are easy to check. YOu can grab it with a large pair of channel lock pliers and try to compress the joint, or jam a pry bar/large screw driver in there and try to expand it. If it moves any (like above) it's bad. Inner tie rod end. http://www.youtube.com/watchv=fUb6LcVcP4g&feature=related Harder to check, but if you pay close attention to the movement of the tie rod in-relation to the rack you can see movement without removing the boot. Lower ball joint. Same applies as the tie rod end. Pliers to compress, prybar to expand, any movement, it's probably bad. Wheel bearing. (these are really bad) If you look at the outer axle housing and it also moves with the wheel, it's the wheel bearing.
98 Forester Front Strut on backwards
Fairtax4me replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow did they get the brake lines connected? Just left them hanging? All the soobs I've seen the struts are oriented the same way.
Fairtax4me replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many miles on this car? Has the water pump ever been replaced? Timing belt?
2004 Imprezza shifting/ clutch problem
Fairtax4me replied to aa8jzdial's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXClutch cylinder failure, or air in the line. Try bleeding it first with Dot 4 brake fluid. How old is the fluid in the trans? 75w-90 synthetic will help with the cold shifts.
Split motor with crank/rod/pistons assembled?
Fairtax4me replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou do have a service manual right? You should remove the pistons before splitting the block. The block halves are sealed together with some type of Three Bond sealer (I don't recall the exact number), and it's tough stuff, so it may take some elbow grease to get it apart. There are also a handful of alignment dowels that often make this type of thing more difficult to separate.
hose and line location question
Fairtax4me replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI do. Or at least I used to. I had to wipe my hard drive, now I don't have Photoshop anymore, thus don't have anywhere to save pics that I would copy from the manual. Just too lazy to reload photoshop. If you have some post away.
Do I need a new crankshaft?
Fairtax4me replied to walczyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat small amount I really wouldn't worry about. But if you want to be a stickler, call your local machine shop and ask about getting it straightened.
Fairtax4me replied to teppichkopf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs there enough bolt sticking out (with the thermostat housing removed) to get a pair of vice grips around to turn it out? I'd try that first. But you need to check those threads, if they are damaged a new bolt may go in and strip the threads out, then you'll be right back in the same boat. If you have a tap kit this is a good time to use it.
how to shift for lowest fuel consumption?
Fairtax4me replied to guyc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot so. It may be the most powerful point in the engine rpm range, but it is almost never the most fuel efficient. With light throttle driving I get the best fuel economy shifting around 2,000 - 2500 rpm. Sometimes going up the hills here I don't have any choice and have to shift at a higher rpm, or the engine will not make enough power to get up the hill in the next higher gear.
98 Leg 5 speed MT in 96 Brighton ?
Fairtax4me replied to outrage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's average for a place that doesn't let you in the yard. Give http://www.car-part.com a look. You may find a better deal on a trans that will work for certain.
Fairtax4me replied to Rooster2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis is typical of Michelin tires and is in no way indicative of a tire problem. I would suspect a bad strut or two. I've never found either to fail sooner or more frequently than the other. I would expect tie rod ends to fail more often since they tend to be smaller. But they do carry less load than a lower ball joint, so it can go either way.
Fairtax4me replied to outrage's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat kind of price are you looking at for this thing? I'd want a warranty even if it was just 30 days so you have time to install it and make sure it's in good shape.
Fairtax4me replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat last one looks like the hose that loops over to the evap purge control solenoid under the passenger intake runners. The vacuum hose routing diagram on the bottom of the hood should at least give you a general idea. The first 3 are for the PCV system. I can't find a good pic of the whole setup. Mike (mdjdc) will hook you up though.
engine size
Fairtax4me replied to General chaos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLook on the block. Examples: http://s23.photobucket.com/albums/b372/dunebuggyarchives/Engine%20Id%20Photos/
Bugged About The Gas Milage
Fairtax4me replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIgnition timing is entirely controlled by the ECU and there is no way to manually change it. There are some performance "tuners" out there who can play around with ECU programming and probably change ignition timing, but I doubt there are any that support a vehicle that new. The dealer might be able to, but they won't unless Subaru tells them they need to. That does seem a bit low. But it's spot on the EPA estimated 24 highway. http://www.fueleconomy.gov/feg/findacar.htm
Towing
Fairtax4me replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell there are several different contraptions that are all called "dollies". I was just speaking of one type in particular and wanted to be clear so others who may stumble across this in a search won't get conflicting information. Any tow, of any distance more than a few feet, with 2 wheels on the ground = bad news for an AWD car.
Towing
Fairtax4me replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLet me straighten out what I meant by "Dolly". I get the idea you guys are thinking the thing you tow behind your pickup or motor home that you drive the front wheels onto so you can drag your car around. http://www.truckntow.com/pc-10126-147375-aluminum-steel-axle-wheel-dollies.aspx You often see these on the side of tow trucks, but most people have no clue what they are there for. Sometimes the tow operator doesn't even know. http://www.coolsprings.com/wp-content/uploads/2010/12/tow-truck.jpg
Towing
Fairtax4me replied to subsince77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe simple answer is ABSOLUTELY NOT! AWD of any kind should always be towed on a flatbed or with dollies.
Clutch Interlock Switch Problem???
Fairtax4me replied to Hoshwa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe clutch switch prevents power from reaching the starter solenoid when the clutch pedal is not depressed. This means the starter will not turn if you don't push the pedal down. The car is 5 years old at this point, even if it hasn't driven far there are still some things that could use attention. Spark plugs could be worn. Fuel and air filter could need to be changed if they haven't been. Run a tank or two of premium gas or a bottle of strong fuel system cleaner such as BG 44K to clean fuel injectors. A can of Seafoam in the gas tank works for that also. Cars with such low mileage often can have mouse nests under the hood. Tight spaces and good shelter form the elements make perfect hiding places for rodents. Check for wires or vacuum hoses that might be chewed on.
Looking to buy a new Subie, is this the wrong way?
Fairtax4me replied to CaptainNemo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTiming belt, or some other internal issue, such as head gasket, this is the only option to choose. Broken TB on the 2.5 means bent valves. Way too much work on that engine with that many miles. If it isn't a simple fix, like a sensor or blown fuse or out of gas. Drop a 2.2 in it. As Fuz said, if the tires are good, flash them $500 and see if they'll take it.
PO440--Solenoid loci??
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXP0446 Subaru Evaporative Emission System Vent Control Circuit Guess you know which one it is now. The evap system only collects fuel vapor from the gas tank and routes it into the engine to be burned off, rather than venting it to the atmosphere. The engine will run the same regardless, but your car might smell like you just went to the gas station all the time.
engine swap
Fairtax4me replied to swilde20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you do any work to the engine before installation? Timing belt, water pump, oil pump reseal? Did you put new oil in the engine? What kind? P0106 One of the hoses on the passenger side of the engine isn't in the right place. There are two and they need to be routed to the correct parts or you get that code. P0122 TPS might need adjustment. Make sure your throttle and cruise control cables are not too tight before adjusting the TPS.
Fairtax4me replied to Legback's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI imagine eventually the filter might get plugged up with dirt. I haven't ever seen a thread about anybody needing one though. I'd just leave the metal line in place unless it's rusted out. That type of stuff is generally in place to minimize stress on certain components, or guide hoses/wiring around obstacles that might rub or cut.
