136
Especially at wholesale bulk discount price.
Subi #2
Fairtax4me replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Cha-ching! I might be able to say that about mine too after this weekend! -
You can move it by hand. This pic: \ Is one of the shift forks. It either jammed or someone forced the trans into gear and bent it. I don't think it's worth trying to speculate what happened. If the car is a good deal buy it and put another trans in. Figure out why the old one locked up after you get it out where you can see what you're doing with it.
If engine load affects your sound, yours is something different from what I have. My noise has no correlation to engine speed or load. Wheel speed is the only factor. Load on the diff due to acceleration/deceleration change the pitch very slightly, but the noise is constant whether in gear or not, at any speed over ~ 20 mph. I'm going to stick a chassis ear on the side of the trans and see if it picks up the noise. I can try to record it and let you listen to see if it's the same kind of noise you have.
These guys are killin' me with this wrong part stuff!!! Got the new idlers yesterday, one of the smooth idlers is the wrong kind. The boxes that the two smooth idlers were packaged in have the same stock number printed on the outside. Just different brand parts inside. Double-yoo tee eff. They're shipping me the correct part, along with a pre-paid return label for the incorrect one. I'm starting to wonder now if this is an omen of things to come with this car!?!?! I'll have to try that. I did try to compare the TIE belt with the old belt. Couldn't really tell a difference by feel. I didn't try too hard though.
92 Loyale "Clunking" on acceleration
Fairtax4me replied to Dallasooby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not familiar with the Loyale suspension, but the Legacy and Impreza have a large grease filled bushing at the rear of the control arms that will clunk when acceleration/braking and when turning if the bushing splits and all the grease leaks out. A wheel bearing will generally not make a clunking noise unless it's in really bad shape. It would have been obvious if it was bad. Inner cv axle joints can clunk, but it's not common. I'd almost bet on it being a bad replacement axle though. What brand did you get? -
I have a loose bushing in the rack that clunks from time to time. I've also had an inner end loosen up and clunk around. The boots are not hard to remove to check the condition of the inner end. Clean the tie rod off and hit it with some silicone spray and the boot will slide right over it. A shot of silicone spray helps with getting the boot back over the lip on the rack as well.
Shouldn't be foreign. They're both made in Japan. The sunroof assembly is a PITA to work on in any car. It sounds like one of the cables broke, which is not possible to fix. Sunroofs are not sealed though. They always leak, even when brand new. They have a drain tray around the edge of the track assembly that catches the water and routes it to drain hoses that are at each corner of the sunroof. You can see where they are if you look from above the car. It's just a small hole, maybe 1/4" across in each corner. If there are any leaves/sticks/dirt in there it should be cleaned out to keep it form clogging the holes. Those hoses can clog or slip off and the water will leak into the headliner. The front hoses can be accessed by removing the A pillar trim, and the sun visor, and the door jamb edge moulding. You can then pull down the corner of the head liner enough to get hands in there to pop the drain hose back on if it has slipped off. Put it back on with a zip tie to hold it. If the hoses are clogged a piece of stiff wire or an old cable such as a brake cable can be run through them to push dirt out the other end. Then a good flush with water should get them flowing freely again.
Subaru axles rarely fail unless the boots are ripped and the joints get full of rocks/debris from the road. If you bought cheap axles the replacement may be faulty. Check all the bushings and joints on the front end for play. As TC suggested the control arm bushing will clunk if it goes bad. There will be grey grease all over the bushing if it is bad.
Might be a bad replacement. Did you check the front suspension for anything loose? Tie rod, ball joint, wheel bearing, lug nuts? -
No the seals are pressed into the inside of the bearing retainer rings. The rings screw into the side of the case. The rings apparently have to be removed to get the seals out. Funny what changes in a matter of just a few months. For the past two months or so I've been getting a growling/whining sound from the front differential. I believe it is the carrier bearings going bad. The trans is also giving me other trouble, it's hard to get into 2nd gear when cold, it grabs/clunks into 3rd when hot. The clutch I put in last year is just a cheap POS that kicks and bucks the car all over the place when it gets hot. I'm almost convinced it has caused or at the least made worse the bearing issue. Live and learn right? Anyway, because of that I decided it just isn't worth the time to replace the axle seals, as they only leak about 2 ounces of fluid between engine oil changes.
One of our well versed members in Subaru repair, Davebugs is in/near Pittsburgh. I'm sure he could help you find a great car, with all maintenance done, well within your budget. But to answer your question. Every car is prone to head gasket failure... at some point. The Subaru 2.5 is just a special case. Properly repaired and cared for the 2.5 will make it to 300k miles and beyond.
Yellow wire at the coil is 12V + from the fuse panel. The Igniter gets it's power straight from the ECU. I don't know exactly which wire is power though off the top of my head, or what it should be. There is nothing in the car that should be getting 8v. It will be 12V from the battery, or ~5v if from the ECU. Check your battery connections and the lead wire that goes from the battery + to the bottom of the under hood fuse panel. There is a fusible link in there as well that may be partially burnt. Pull it out and tug on each end like you are trying to stretch it out. If it stretches and/or breaks it's bad and needs to be replaced. Crank and cam position sensors can be checked with an analog multimeter set to AC voltage. Look for the needle to jump in a pattern that corresponds with the teeth on the reluctor ring of the sprocket. There is also a resistance check that IIRC should be 3-4 ohms. Not 100% on that but it's a small number. If you get ∞ resistance obviously the sensor is bad.
Bad plug wires. People go to the parts store and buy the cheapest wires they can get, and they literally fall apart in 6 months. I just replaced the plug wires on my moms Camry. Original Toyota wires that were on the car for 12 years, and they still worked fine. It was $90 for a new set from Toyota, but they'll last until long after she owns the car.
