T'subaru
Everything posted by T'subaru
  1. interesting...on the pug alloys ? and are you using the pug adapters too?
  2. Ill keep my eyes open:)
  3. Connie, do you have a pic of what the bumper looks like? I hit alot of off the beaten path wrecking yards when I travel for work, I could be another set of eyes. Mark
  4. I'll drop by with a sample GD:)
  5. its been a quick learning experience, I have all ea82's and have not played with ej or xt6 parts yet.
  6. Im 'bout 1500 feet from the ocean here...currently driving a near transparent toyota pick up while working on my subi:lol:
  7. Are you having rust issues with them? or did you order plated?..if so what color are they? thanks
  8. I didnt want to bury this in the official thread, but im curious if any of you guys have had success in sourcing alternative lug nuts and or adapters, found vw uses 60 degree adapter, and there are several 60 degree lugs out there...im trying to use a set of 505 pug turbo alloys and want to avoid rust and or plating color issues.. thanks
  9. A big Thanks! to john in KY who is shipping me another xt6 hub:grin:
  10. Thanks John, just checked that out, both are the same size, definately xt6's
  11. my dealings so far to date I wouldnt have been able to tell ej from xt6 parts, and assumed I had ej knuckles...and I couldnt figure out why someone would have to jury rig the hub. I think GD nailed it, I have all xt6 stuff from the control arms out and someone adapted an ej hub to fit.....kinda
  12. Thanks for the info GD, having the xt6 calipers, I must have the xt6 knuckles also as I believe Legacy calipers have the p/b hook up on the rear calipers...it all makes sense now...except the way they made the Legacy hub work
  13. Thanks Turbone, Looks like I mis identified what was what.. and I agree, its a morphadite set up
  14. http://www.ultimatesubaru.org/forum/showthread.php?t=113606 Thanks, Mark
  15. I recently purchased xt6 brake assys from a car that had been converted. Rear is all good, but I ran into some weird parts on the front upon disassembly. I have the xt6 calipers set up for the park brakes, but 2 different hubs were found and the xt6 hub has spacer washers on the wheel studs and bearing shims to space it away from the hub to mimic the other hub, heres some pics..can anyone identify the mystery hub? xt6 on the left... ??? on the right note that the hub on the right has screw prep, and both rotors are prepped for flat head machine screws to hold or locate rotors to hubs. any guesses on what happened here and what parts were combined? Thanks, Mark
  16. Nice Rob! and I was just outside checking out my rx...been sitting for awhile and im tempted..but gotta finish the wagon first..miss driving the thing
  17. I ran across two different front hubs today, one looked new and had a flat surface with no screw prep for the rotor and had spacer washers between the hub and rotor, what do I have...different production year parts? Rotors are identical.
  18. I just pulled apart both front and rears this morning. Rear are 36mm front are 32mm...couldnt find my 32mm socket but 1 1/4 sae worked great.
  19. Nice! even if traced. Good times im sure with your son, my sons first 6 years were spent just east of you in Ravensdale, I couldnt wait to get home from work and hang with him. Used to bundle him up and take him walking thru our woods shortly after we first brought him home and continued until we was walking on his own. Hes definately an active outside 13 yr old now, and the good times continue:)
  20. I lived in Kent years ago, there are at least 3 wrecking yards on the east side of hwy 167 just south of downtown, should have some luck there.
  21. all excellent choices as "gimmeaticket" just wont fit:grin:
  22. T'subaru posted a topic in Off Road
    Hi all, ran acros these winches accidentally while looking for fishing gear. Some good prices to be had on superwinches and warn 2000 to 2500lb. Cheers http://www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=MainCatcat21412-cat20159&id=0060454523502a&navCount=1&podId=0060454&parentId=cat20159&masterpathid=&navAction=push&catalogCode=9IS&rid=&parentType=index&indexId=cat601233&hasJS=true
  23. Cool, so far ive met 3 members between Wa and Or, all good guys, when T'sunami Wagon is finished up I plan on attending future meets, maybe out west abit also.
  24. SWEET!!! but you can only have one Suber..damn
  25. Cool! couldnt imaging your first choice has been taken
