Everything posted by Setright
Well, the cam sensor is used to double check the engine position. The car will start and run without it working, but if the cam sensor returns a "no movement" signal even though the crank sensor has registered movement, then the ECU will complain. In short: The crankshaft sensor has higher priority.
Swede, the ECU will not pulse the injectors or fire the plugs until it has seen a signal from the crankshaft sensor. So, yes if that's faulty the car will not start. Good to keep in mind if you like dry-cranking the engine after an oil change. Unplug the crank sensor and crank the engine for ten seconds or so. Twice. Of course, I prefer to just fill the oil filter before screwing it on. Pardon me for taking off at a tangent :-)
Have a listen to this: http://www.geocities.com/vik2r/Sube/mp3/warmstart.mp3 It's my previous car, a 1990 Legacy 2.2 with the same engine as the 95. It's equipped with hydraulic valve lifters, just like the one you are talking about. I know that recording doesn't have the engine idling for too long, but you can hear a slighty rattle in there somewhere. At the time of the recording the engine had 120k miles. Car is still running with 200k miles on the clock :-)
Piston slap is with most Subes on a cold start-up. Not terminal, but slightly annoying 'cause it sounds like a Diesel! I would suggest a 10W-40 oil as the best cure. Shell "Helix Plus", for example. M1 is a good oil, and the 5W-50 oil will be good to use, but it's relatively thin at low temps and will slap more than Helix.
blinker HELP!
Setright replied to Zefy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You might want to try cleaning up the contacts in the rear light clusters. Sounds like a classic grounding problem. Your blinker could be pulling ground through the red lamps at the rear. Simple test: Disconnect the left rear cluster, try blinking left. If the blinker flashes (twice the normal rate) then it's the contacts in the cluster.
