Everything posted by Strakes
to much body roll
Strakes replied to iluvdrt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an IPD rear sway bar. I love it. With the stock springs, the handling was pretty much neutral and the lean was gone. Since then I have put on H&R lowering springs and KYB GR2 struts. Had a great alignment shop work with me to keep the car handling neutral after all the suspension changes.
Question about tire
Strakes replied to danz75's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKeep bugging the crap out of Discount until they replace the defective tire(s). I've had BFGs before and they were nice and smooth, BFG is owned by Michelin, so the quality is pretty good. If you come to the point of replacing them with another brand, keep in mind that a Hunter-Road-Force Balance machine can pinpoint the cause of vibration. Here's a link to the kind of machine the shop should be using: http://www.gsp9700.com/pub/features/how.cfm Also, I've had a bad balance job and the above stated machine they were using had not been calibrated in a very long time. After re-calibrating, re-balancing, the vibration was gone.
96 legacy feels wobbly thrue sterring wheel.
Strakes replied to sailhard's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust a guess...do you think you bought a defective drive axle?
Bought another subie
Strakes replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShiny! I love the pic of all the change you found!
Piston Slap
Strakes replied to bkcraun's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGlad that things are working out for you! Sounds like you have a good dealer.
Strakes replied to Legacy777's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJosh, the car looks very nice!
Muffler Question
Strakes replied to Richard1296's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn our 1993 Legacy, I went through 2 aftermarket mufflers that had an annoying drone that developed on the highway. Then I put a barely used late model subaru muffler on. The Subaru muffler is nice and quiet.
Synthetic Manual Transmission Oil ?? GL4 vs GL5
Strakes replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't heard of anyone messing up their transmission with the cocktail. I've been using it and love it. Some are concerned that it isn't up to the owner's manual recommendations of keeping it all one brand of fluid. Plus, I think the GM synchromesh is GL4 and that may get some raised eyebrows. So taking their legitimate concerns into consideration, I like to change my transmission fluid more often to compensate for the lack of 100% GL5 fluid. IIRC, the main difference between GL4 and GL5 is the percentage of certain additives...GL5 having more of them.
Strakes replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn the NASIOC, many run "Uncle Scotty's Cocktail": 1qt Redline Lightweight Shockproof 1qt Pennzoil or GM Synchromesh 2qt Castrol Hypoy-C 80w-90 To avoid the "is it going to fry my transmission", many change this every 10-15K miles.
Speedometer has never been right on 99OBW
Strakes replied to Shep2112's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.caranddriver.com/features/1906/speedometer-scandal.html and http://www.caranddriver.com/features/1907/speedometer-scandal.html
radiator
Strakes replied to outback96's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/showthread.php?t=21681 Check out the above thread. See if that helps.
Power Steering Pump
Strakes replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn that case, I hope the one I get has the pulley attached.
Power Steering Pump
Strakes replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks guys! Flushing the system sounds like a plan. Metal pieces floating around can't be good. Did you take the pulley off and reuse the old one? Mine looks in good shape.
Power Steering Pump
1993 Legacy 2.2 wagon 2WD It had a funny noise every now and then. The noise was coming from the power steering pump area. So I took the belt off and spun the power steering pulley and there was a grinding feeling. I think the bearing is about to go. How hard is it to replace the power steering pump? Anyone done this before and have any advice or suggestions? Thanks guys!
how should i treat the rust on this hitch?
Strakes replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat uniberp said. I have used POR15 and it works well if you intend to repaint. If you just want to stop the rust and aren't worried about looks, use some par-al-ketone thinned with mineral spirits and a spray bottle: http://www.aircraftspruce.com/catalog/appages/paralketone.php
Legacy Bilsteins or Outback GR-2's
Strakes replied to uniberp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBilsteins are very nice. I used to have the monotube gas on an old Volvo and loved them. Never used them on a Subaru. Some JDM versions of subarus have Bilsteins. I doubt the quality from Bilstein would be an issue and should give you good service. On both of my Subarus, I am running the KYB GR2s. I really like them. KYB makes the OEM struts for subaru. I would recommend that you get the same brand and version struts on all four corners. Otherwise you may run into some weird handling issues. Finally, if you are going to get the outback struts, I am not sure, but you may need to replace the springs as well.
Vacuum oil extractor - opinion?
Strakes replied to Green96GT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou'd still have to get under the car to remove the oil filter. So I don't see how this saves you the "getting under the car" step. Have you considered this: http://www.fumotovalve.com/ I have them on my cars and like them a lot.
Will 99 Outback exhaust system fit on 91 Legacy?
Strakes replied to dburdick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your old exhaust is falling apart, you can have a muffler shop custom bend the pipes for you and place the newer muffler and resonators on your 1991. That may save you some cash. I went through 2 aftermarket mufflers that droned. I finally took an used low mileage '02 model legacy/outback muffler and had it welded onto the '93 legacy. It's nice and quiet now.
Michelin Exalto A/S on 2000 Forester?
Strakes replied to Seeker4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTwo of my friends, one with a Mercedes E series CDI, the other with a PT Cruiser that have sets of Exaltos, and they are very pleased with the tires performance.
Brake pad clarification?? Wear indicators
Strakes replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just did brakes on my wife's 93 legacy. The pads that I used had a label where each pad went, such as "RH Inner, LH Inner" and etc. With that in mind, I installed them just like it was labeled and the metal tab that's riveted on ended up being the inner pad at all 4 locations. I used brake grease/lubricant/anti-squeal on the backs of all the pads and shims.
Brake job advice
Strakes replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYabadabadoo!
Brake job advice
Strakes replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe brake job went very well. Thanks for the advice guys! The rotors were less than the minimum thickness that was stamped into it: 22mm front and 8.5mm rear. So I tossed them. With 170000 miles, I suspect they are the originals. As for the quality of parts, I put in PBR/Axxis Metal Master pads with PBR/Axxis rear rotors and OEM front rotors. After bedding/breaking the pads and rotors in, the car really stops much better than with what was on there.
Brake job advice
Strakes replied to Strakes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAh ha! I knew I forgot something! Thanks guys for your advice! I've done a cheap "autozone" brake rotor & pads before...wasn't very happy with the performance. Thanks again!
Brake job advice
Hey guys, I've replaced struts myself and am pretty good with working on my cars and have done brake jobs on Volvos. Anyways, I need to replace the brakes on my wife's 1993 Subaru Legacy Wagon 2WD. How much time should I budget for brakes? Would a Sunday afternoon suffice? And am I missing something from the following list before I start? 4 brake disc rotors Front pads Rear pads Motive Products Power bleeder for flushing brake lines and bleeding brakes. High Temp Brake Lubricant made for slider bolts, backside of pads & etc. Spray Brake cleaner P'Blaster for any hard to remove bolts. Haynes manual Thanks!
Warranty question
Strakes replied to 2005outback4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat nipper said. There should be a detailed list of items to be done for your 30K service in your owner's manual/maintenance schedule that came with your car. Stick with that, go to a trusted shop, keep the receipt, and your warranty will be fine. Link: http://www.cars101.com/subaru/subaru_maintenance.html#2000Maintenance
