Everything posted by desertsubaru
Snow Tire
desertsubaru replied to wblocker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to a different tire dealer then. I have used Blizzaks for years on Subaru's. Just remember they are a winter tire not a performance tire. I am pretty sure you wont be taking this vehicle up to 130 mph. Beginning in 1991, the speed symbol denoting a fixed maximum speed capability of new tires must be shown only in the speed rating portion of the tire's service description, such as 225/50R16 89S. The most common tire speed rating symbols, maximum speeds and typical applications are shown below: L 75 mph 120 km/h Off-Road & Light Truck Tires M 81 mph 130 km/h Temporary Spare Tires N 87 mph 140km/h P 93 mph 150 km/h Q 99 mph 160 km/h Studless & Studdable Winter Tires R 106 mph 170 km/h H.D. Light Truck Tires S 112 mph 180 km/h Family Sedans & Vans T 118 mph 190 km/h Family Sedans & Vans U 124 mph 200 km/h H 130 mph 210 km/h Sport Sedans & Coupes V 149 mph 240 km/h Sport Sedans, Coupes & Sports Cars
1992 Loyale totaled, what's it worth?
desertsubaru replied to illgobigger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI live near Coffman metals in WV, The place that buys ginseng on the TV show Appalachian Outlaws. He pokes a rod into the cats to measure how much of the comb is intact. If any is missing he takes money off. The most I got down there when prices were up was $30 for a big chevy cat.
Thoughts on Colorado Component Rebuilders
No personal experience with CCR but have read tons of good info about them.
Is it really rod knock?
desertsubaru replied to cporath's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you rebuild this engine go the whole nine yards and do a complete rebuild. Look on carparts.com for a low mileage Junk yard engine. I found a 2.2 with 126 k for $500 bucks with a six month warranty.
desertsubaru replied to cporath's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow many mile on this engine?
Hill Holder
desertsubaru replied to mcnea001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes it works by pushing the clutch in. They can cause problems if they stick. They can also be disconnected by taking the cable off the clutch fork.
desertsubaru replied to cporath's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhy people don't check their oil is beyond me even on a new vehicle..Takes two minutes to do. You should check your oil at least once a week, Three times a week if it leaks or burns it.
Runs drives won't restart when warm
desertsubaru replied to Srubendall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo EA82s have igniters like the EJ cars have. I had a 1977 Toyota that had an igniter. When it would get hot it would quit running and wouldn't start until it cooled off, It would still spark when it was hot but a very weak spark. Replaced the igniter and it never did it again. I forget what they call it but EAs have a little thing like a coil in the distributor. Some kind of pick up coil. It could be that heating up and causing a bad spark situation. Also kind of sounds like vapor lock.
hard time getting gas in car :(
desertsubaru replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI still haven't figured out what is wrong with mine. I just learned to fill it real slow. Sucks taking 10 minutes to fill the tank.
desertsubaru replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhttp://www.ultimatesubaru.org/forum/topic/153786-hard-to-put-gas-in-tank/
Stopped running, still turns over?
desertsubaru replied to Pacosquared's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck for the basics first. Does it have spark at the spark plugs. Is it getting fuel,. Pull the drivers side Timing belt cover to inspect the timing belt. Check all relays and fuses. Also find out why it got hot and spewed water.
head lights turn on during acceleration, brake and battery light
Headlights on when car is on is normal.
1999 legacy outback low fuel light?
desertsubaru replied to Obwobbles's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIMO you should never let the fuel level get below 1/4 tank.
squealing noise when clutch is engaged
desertsubaru replied to jdhbraz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDepends on who is doing the job. Most garages charge by the book which can run into the thousands depending on hourly rate. If you look around and find a small independent work shop that does that kind of work for a fixed amount you can get them down into the Hundreds of dollars for labor and parts. Try to find a mom and pop garage that knows Subaru's.
Storing Subaru Engine
desertsubaru replied to steve56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou could build a wood frame that the motor mounts sit in. Even go as far as drilling holes for the motor mount bolts to sit in.
How much longer can she last
desertsubaru replied to barrington's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAs long as it isn't two rusty it should go a long time before major repairs. With that amount of miles I would look into doing Timing belt kit with water pump real soon..
One issue, then another
desertsubaru replied to subakev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYour brakes are shot!. Replace both sides with the kit they have on Rock auto. When you change the brakes and rotors inspect the pistons to be sure they are not leaking or sticking. Also inspect the slides and grease them.
desertsubaru replied to subakev's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHow long did it sit without moving. was it out in the rain? Could just be surface rust.
Thermostats use and function
desertsubaru replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used the Stant's Xacstat on my 03 forester. It has worked very well so far. Temp stays at one spot no matter what the outside temp is.
2001 Forester value?
desertsubaru replied to DaveT's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the jacking point is that bad then IMO the car is worth Junk price. Or you could part it out and get a little more.
2003 Forester Airbag light
Was crusing along when all of a sudden airbag light came on. What would cause this?
Replaced Alternator - now check engine and Cruise flashing. Car runs fine.
Disconnect battery for 30 minutes.
Starter Swap
Subaru never used 13 mm. They consider it bad luck.
SOS Stuck away from home. Won't start.
When I use to go to Harrys Upull I would go when they had sales on stuff like starers then buy three or 4 for parts $15 bucks plus the two entrance fee. It was nice living 15 minutes a way from it. West Virgina has no U pulls.
Ball joint boot Balloon... POP
desertsubaru replied to rendoll911's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDid you ad grease to them?
