Everything posted by JWX
Lightweight Wheels
I'd sat yes but this is theea-81 steels, I had both with out tires and the enkei's are I'd say about 3-5 pounds lighter than the steels
REAR Braided Stainless lines!
just try it with a set of stock front ones, or tell me which connection to use and I'll try it on the 89 since its not driving
Copper HG Source??
I really don't think they would do one subaru and not another, they're not THAT different. but you may have to send them a stock set
Ignition/fuel cut...on stock boost
dang man you be taking all me parts. I kid I kid
could you get a spacer (washers) and do that with it instead on cutting the bolt?
what needs to be modified?
switch cars with me so you can run this one into the ground, instead of a nice near mint RX. I think thats a good idea you can keep your engine and tranny too.
lets talk idle speed
it idles fine untill you turn the AC/defrost on then up to 2k. and yes this is the 88 thats stock
Megasquirt Info
Shadow, that will make my life so much easier when I go to put the RX stuff in my hatch. thank you man
RX troubles (not engine thou)
well aren't you helpfull I'm thinking just buy a set and send them to him.
in my RX with the defrost on it runs 2k RPM, I think this is a bit high. what does yours idle at? and is there a way to lower it? I know it kicks in for the AC but I'm not running the AC right now and 2K it still seems a bit high even for the the AC.
what’s the exact dimensions for them?
solid or urethane?
Megasquirt Info
oh right that.....well get yours installed and then you can help me with mine
wjm, more fuel to defeat detonation?
how does it do this then?
Got a new toy for the coupe!
those are nice, the black would go good in my Rotary RX. hmmm if anybody finds another set like that let me know
so nobodys looked into getting some urethane bushings made up?
the bushing for which you told me to contact Solo2subenut about.
Megasquirt Info
hookers and root beer?
bumpage
Fuel cut on stock boost???
WTH 17PSI on this engine? bastards.....all of you..........
87+ is BettAr.
I know.... I is teh sadAR now
thanks man, its good to hear somebody flogged the ***t out of it
87+ is BettAr.
I'm telling you man just throw an engine in the wagon when you get some money, I hate hear about its retirement. :/
mine doesn't, I did a third gear pull and it pulled clean to redline. now it did do something odd I went to shift into first and it stumbled, not sure if it was a fuel/ing cut or the BOV. but it hasn't done it since.
