Everything posted by JWX
83 BRAT WRX with EJ20T
what radiator did you use?
EA Tranny...behind EJ motor
I'd say try it. you put these trannys side by side they look mostly the same. as long as you don't abuse it it should take fine.
Installing an N/A XT MPFI engine into an RX
don't tell them what it is see if they can see it.
My pipe-dream for low rpm turbo spooling:
do the new ones still use that?
4.11's, 4.44's, in a D/R 5spd. Any one?
most neighbors don't have anything nice to say. have you called him out over on their board?
TWB Fabrications
you want to bend up an exhaust for me? I just need the part that is by the axle, with a a flange on the muffler side and about 2 feet of pipe on the other end. I need two, one three inch, and one 2.5. let me know.
I get 37mpg on the interstate with my RX. good going with the swap tho
RX has me on my last nerve... (UPDATE)
that could be the problem aswell. I've never had trouble with it but others have from what I've read.
I hate to ask agian, but are you sure the timing belts are dead on? it does kinda sound like vavle timing. or some sensor(s) somewhere is messed up, but not bad enough to throw a code.
- MegaSquirt....
The b3stArest Intercooler evAr!
TehThreadIsWorthlessWithOutDynoPlot
About Rallitek's Perfect Power 6
any. take any product, wire it up. or pay somebody a boat load of money.
rebuilt twin carb ea81 hesitation on RH corners
right hand drive or left hand drive?
go get one now TTIWWODP
Was there more than one 4-lug Suby bolt pattern?
so we're talking about straght line stuff? ya whatever
how you figure?
take a SAFC and wire it up and it will work? I'm not sure what you are asking me to tell you? :-\
Longer wheel studs
honestly just go look for them. its really that easy.
anything would work you just have to wire it up right
Longer wheel studs
only subaru and nissan use the M12x1.25 thread, that I have found atleast. if you search it will come to you (google be your friends)
you can run the MS for just fuel only. and mine never fuel cuts, but I think the ECU has seen better days.
New Dyno numbers for the RX...real ones this time.
you talking about that axle back my car has now? I thought it was 21/2 inch?
987 GL hatch, 1.8L, 2WD. Non-turbo. Specs
OHC or OHV
RX Springs > XT springs
you have coilovers now, technically. Coilovers aren't just for race use. they give proper travel, proper damping, all that great stuff. Which is sadly lacking when one lowers the stock stuff :-\
dude just get any standalone/piggy back/superafc and wire it up. if you don't want to work for it, then why have rewards? :-\ I would have figured sean would have known about the fuel cut, he had an RX rally car at one time.
