16
Posts posted by 6 Star
Cleaned out around the Fenders and other areas that trap debris on the all the Subies.
Had four neat little piles around each vehicleThis is a 3rd generation, looking with the Front RH Door Ajar; at where the Fender connects to the Body.
This location LOVES to catch debris. It collects in the form of road-wash, and from debris falling from trees above.
I used the small bamboo branch in the above photo to fish the majority of the filth out. Compressed air, a garden hose, or a vacuum would also work great
2nd Generation cars have a similar area that catches debris in the same location.
On 3rd gen cars, there are drains on either side of the windshield wiper apron, these also like to get plugged with grime and tree debris
Hard to see, but there are two pine needles diving in to clog the drain even in these photosThis is just routine stuff that has to be done now and then. Keeps the car less damp and less likely to rust out as well
- 1
@el_freddo found them on https://a15ff11300g.sakura.ne.jp/ (playwithlegacyrs dot com) long ago...
Been wanting to re-share my favorites from that site since my original photo host crashed and burned.
Looking forward to sharing more of my own personal photos and photo-finds as I get them sorted out... this last summer I found a stash of old paper Subaru Advertisements ranging from the 70's to the 2000's...
- 1
April 1986 - Leone RX II - Japan
November 1985 - Leone Optional Parts - Japan
October 1985 - Leone 3 Door Coupe - Japan
July 1984 - Leone RX - Japan
July 1984 - *NEW* Leone FF - Japan
July 1984 - Leone Optional Parts - Japan
- 1
July 1984 - *NEW* Leone 4WD - Japan
- 1
June 1983 - Leone RX - Japan
- 1
1 hour ago, franbev said:
I actually have a third eye assembly but when I found out I would have to cut up my grill I decided not to.
Plus they look funny with the quad lights vs the singles... IDK I'm a purist on that sort of thing
1 hour ago, oczuk32 said:
Does your brat have the center high beam?
No, that was '82 only for the Brats. They have single headlights instead of quads
What would you like to know? Local to the Seattle area... cannot always get out IRL however can usually answer most Loyale questions
25 minutes ago, Willy Fisterbottom said:
6 Star are you going to spam this thread with every codswalloping pic from here
https://a15ff11300g.sakura.ne.jp/catalogue/A leone/A-type leone.html
Yes
No... only the photos that I have been meaning to revive... its a work in progress however I figured to repost them here rather than in the "OLD GEN" section as they were before.The website is called "Play With Legacy RS dot com"... depending on the system being used it may or may not show up when searched.
On the PC it will load for me, on the Laptop it will not -
August 1978 - Leone Line - Japan
December 1977 - Leone 4WD Booklet - Japan
November 1977 - Leone 4WD Lineup - Japan
April 1977 - Leone Optional Parts - Japan
May 1977 - Subaru Full Line - Japan
March 1977 - Leone Series - Japan
November 1976 - Subaru Full Line - Japan
June 1973 - Emission Control - Japan
^4WD Wagon looks so nice...^
October 1973 - Subaru Full Line - Japan
February 1975 - Spirit of Subaru - Japan
December 1972 - Leone 1400 RX Coupe
What is the interchange again on the EA82 Clutch Kits?
When going to look up a new clutch for a Dual Range '88 GL, there are two options available...
Both have 9 inch Clutch Diameter (8 & 7/8?)
One has 1 inch (25mm) Input Shaft Size, with 24 Hub Splines
The other has 7/8 inch (22mm) Input Shaft Size, with 21 Hub Splines
Curious which one would be right for my application and if the info on the interchange will help the OP -
All of my Subarus are from the 80's and still going strong... give it a chance to work out the "New Car" bugs
FrankenBrat engine: where to go from here?
in Subaru Transplants
Posted
It sounds like we need to see pictures of this Frankenstein.
Maybe its a hopped up aircraft EA81 with custom heads, like what RAM Engineering does
