rallynutdon
Everything posted by rallynutdon
2.3 mile tarmac 13 turn course. SCCA solo I. Wide variety of cars. Free for spectators. We'll be running our Impreza rally car with 2 drivers. On Duryea drive from city park to the Pagoda atop the hill south east of Reading (can't miss the Pagoda, use Mapquest, Duryea drive and Clymer street) Don Kennedy www.RockyRoadRacing.com More info may be found here: http://www.bmr-scca.org/home.html Mods: Move if this is not the appropriate place. Thanks.
I have the same vibration. It's from a not completely round tire (you can see it on the spinning balance machine). I already sent one back and it's replacement was better but still a hassle. Right now I'm living with it till the set wears out then never buying that brand again. It is strange, sometimes it's worse than others.
IMHO and experence, that difference in compression wouldn't have me worried or doing anything if it still runs good. If it drops below 100 I'd start to think about doing something. BTW, how did you take the compression reading? Hot, cold, both dry and after squirting oil in the cylinders, plugs all out, throttle wide open? Also, I've done heads w/o jacking the engine.
I have worked on several Legacy motors with more than 150,000 miles and have never replaced a cam seal and have never had one leak. IMHO, I wouldn't bother, it's not that big a deal to do later if need be. Timing belt, yes of course. I've compressed many many tensioners in a vise in less than 2 minutes. Be patient, why waste money. There's nothing in there that doesn't make sense, just be cautious and align the timing marks according to the book.
I have a 90 wagon with 150,000 on it. Have had it for 3 years. Since I bought it the stock gauge just barely reads above 0 with fresh 20W50 when it's up to temperature. When it's up to temperature at 3500 RPM it barely reads 40. Engine is still running fine (although I suspect there is more pressure than the stock gauge is reading). I wouldn't worry about it.
My experience, 91 Legacy, now with 245,000, bought with 116,000in 1996. Transmission 3 rd gear 2 pieces seperated at 120,000, Replaced with junkjard trans with 70,000 so now trans has 190,000 and is doing fine. Motor develooped a knock at 220,000 so I swapped in a 170,000 motor. Same front and rear bearings, rear half shafts (front's have been changed at least once), same ball joints, KYB struts still good having been put on when I bought it, same PS pump, same alternator, replaced AC compressor last year, same rear, same wiper motor. Not much else replaced.
