			ccrinc
				Posts1028
				Days Won9
Everything posted by ccrinc
	The Chinese made stuff is garbage. Absolute crap. Recommendations: all can be found on Ebay: NPR Rings ACL Race bearings or Clevite repackaged NDC bearings We won't use anything but Subaru Genuine on the gasket kits (btw, use the 860 turbo head gaskets), but several people say the Gates/Rock Auto kits are good. Of course, they aren't offering a warranty like we do, so take that into consideration.
	Rick has put a toggle switch on the dash of 2 of my now long gone Subarus so that I could flip between AWD and FWD as I wished. I ran my '92 Legacy Turbo Touring Wagon LE in FWD most of the time and only flipped into AWD when the conditions required it. I had that car the longest, so it was like that for several years and still no transmission troubles when I finally sold it.
	The thing is, he already had a rod knock. Now, it sounds like a rod bearing has spun and taken out the internal idlers and tensioners as well which was bound to happen. The idlers and tensioners are internal on this engine, which has 2 chains, not a belt. Just getting to the idlers, etc. entails taking the front of the engine off (114 bolts, IIRC). They must be taken off in a specific sequence. We're building one right now...it's not for the faint of heart!
	Well...neither, actually. But, you do have to sort of "rotate" it off after you pull the bolts. Rotate counter clockwise. There's a seal on the front and an o-ring on the back of it. When you replace the o-ring, don't stretch it: sort of easily roll it back on the shaft and make sure it isn't rolled or twisted when it seats.
	Kinda going out on a limb here, but it sounds like there is a problem with the teeth on the starter and flywheel engaging properly. Like a small chunk may be chewed off the starter pinion gear or the gear is worn (it is a normal "wear" item). The problem would have to be on that side or the issue would be intermittent (like my mom's old Ford which had a tooth missing off the flywheel). What makes your situation more curious however, is that you can replicate it daily and that temperature affects it. It's obviously not electrical/electronic in nature due to lack of CEL and the fact that you've pretty much checked all that and verified it good. Therefore, it must be mechanical. Come to think of it, the starter solenoid wouldn't throw a code either, nor would worn contacts.
	The EZ36 may be the better engine (runs on regular, not premium), but I doubt it will be a direct swap. Even the EZ30 had 3 iterations. For instance, the placement of the oil pump is completely different, you'd need the EZ36 intake manifold and all that entails. Either way, I don't think you're going to get off cheap on this one. Emily
	Gears in reverse always make more noise than in forward. Only you can judge if it's exceptionally noisy for your car. While the level may be good, when is the last time you changed the fluid? It needs to be done about every 12-15,000 miles. These are both high mileage units, so a fluid change may be just what the dr. ordered.
	Just as a footnote here, but Subarus are very picky about their electronic components, even spark plugs and wires. Honestly, for the few dollars more vs. the price of a tank of gas and the improved reliability, go for the NGK plugs and wires. They last longer and give better results. You don't want to "cheap out" here. Emily
	The '02 EZ30 is a MUCH more reliable engine providing it's had the required oil changes. We have had a run on 2005 turbo engines over the last year. None of which were STi or WRXs. All were engines which died of oil starvation, leading me to believe that somewhere there is an issue with that year and that engine. Of course, SOA isn't going to admit it. And, it would be a very small percentage of the overall sales for that year. But, if a co. like ours sees that pattern, you know there's an issue with that year and that engine.
	Ocei77... He is a "she". I used to hang out here a lot, then got away from it for awhile. I guess I need to start signing my posts again since there are a lot of new members who don't know me. Emily ps: An absolutely fool proof, non-threatening substance to use to make oil seals and o-rings go in smoothly and stay in place is plain ol' petroleum jelly. Often known as "mechanic's glue".
