Everything posted by BlackBoot
How many volts showing right before you start your GL?
i had a similar issue with batteries, they needed a good charging overnight and that fixed the problem, you know how old subies are with low amps on the alternator, with short trip stop starts and accessories running, the alternator can't keep a good crarge on the battery.
- Need help with XT6 problems, electrical gremlins and such
i cleaned all the contacts and put my battery on a charger for a couple of days. then tightened the belt and put in the charged battery. belt still squeals sometimes under load when cold. yeah, the resistance in the wires is probably the main issue, and if i don't fix it i'll keep burning out alternators. but for now it runs good, it's parked for the winter or until i get money, or first snowfall! also removed the muffler, great fun!
My 88' XT6 has these problems; - battery shows good voltage with tester, but dash shows lower voltage, I cleaned all contacts. - alternator gets really hot fast. - belt squeals every time when starting, the belt tensioner is stripped, where can I get a new one? - fan relays are all messed up, I have to put a fuse in the relay socket to jump the fan to run and pull the fuse out when I park. - air vents will not switch. - Tachometer sometimes is way off too high. - cybrid steering is shitty at low rpm, could that be the brushes in the motor, or low current from the alternator, belt also squeals when taking slow tight turns sometimes. any gurus with advice out there? I'm in the PNW anyone local?
Getting ready for WCSS 16, Fan/AC relays on XT6 all messed up help! and vacuum lines to vent contol also?
Still working on it, and still finding and breaking more, relays are still bad, have to check temp sensor, but will probably just end up by-passing it all, so I can have manual dual fan control. alternator near dead, I have another but don't know the state of it. where can i get a new belt tensioner, this one is all messed up.
Rear Disk Brake conversion on 85 Brat
Think I'l just pimp this car but leave the body bondo and primer.
I just put 18" wheels on my 88 XT6 now brakes look small and poop! What can I bolt on, with minimal drilling ect?
- Getting ready for WCSS 16, Fan/AC relays on XT6 all messed up help! and vacuum lines to vent contol also?
not possible, frame less windows on the doors.
Sealing Ea82 valve covers
the seals and grommets are made to work with regular motor oil , if you put an adhesive sealant on them then it affects the way things move when heating and cooling, causing binding and leaks. keep things smooth clean and lubed! things that men find desirable on cars and...
I use petroleum jelly, vaseline
89 XT6 coupe air struts
My XT6 came with the swap done, but it looked too high, i checked the rear struts and found they are FWD so 2" taller than AWD, and found the receipt from the swap in the records that came with the car, says forester fronts, 2" higher than Impreza. It has the same ground clearance as my AWD wagon 6 1/2". 2 1/2" between tire and wheel well in rear, and 3" in front. I'll leave it for now and have some fun rallying, but once it"s painted and has nice wheels I'll lower it.
Thanks, the relays I had around were from a Legacy, I had to swap the pinout on the connectors to work, or did the last guy swap it wrong? I followed everything according to the wiring diagram, and I think the rad fan relay is ok now but the ac is all busted anyway so I'm not worried about that. I will be wiring a manual control switch for the AC sub fan, for extra cooling. actuator for the vents still not responding. what is the other fuse for next to the inline AC fuse? where is the sub fan diode located?
Sandblasting alloys?
I got the spray at the hardware store, one can did 4 wheels. applied and waited, then washed off and dried and repeated.
Help me save my 93 Loyale
It's a Subaru Boxer engine, it is supposed to rev higher than other engines. People use the EA81 in aircraft at 7000 rpm all day. Giv'er gas, get up into that power band!
- My DL 1989
Head gasket job ea82
I could not find any locally, I picked through a bunch of old ones I had and selected what looked good, not very technical but all I had at the time, worked fine. I re checked the torque and re torqued after a test drive. still dunno where to get them in Canada.
I have used a generic kit off eBay, no problems. just make sure the grooves for the gaskets are very clean and lubed to seal. be careful of evenly torquing the covers on, even pressure on the whole gasket, just ask a drummer about tuning a drum, tighten each bolt a little at a time and move around between them. and the vents for the valve covers is where i see the most oil leaks, usually just dirt and a bad seal. Clean it, lube it, clamp it.
88 XT6
Dang! that passenger side fender is hell to take off! stupid snorkel and washer fluid tank in the way. much different than a Loyale, the XT has no room for tools except for a box wrench 1/8th of a turn at a time, ugh! and I have a Milwaukee cordless power ratchet and can't get it in there...got fed up with one bolt and got out the chisel and a BFH! Mission accomplished. putting it back on, not so bad, learning curve.
