Everything posted by Dwayne Oxford
NOS inner CV boot 723222022
Yup, fitment chart shows "74-"97. Thanx!
Me too. Have never replaced an axle. I watch mine and replace when they leak. Noticed long ago the quality of Subaru rubber and how long factory boots lasted. After market/parts house boots not so good. Ebay sellers have couple outer NOS boots, no inners. Guess I'll order BECK/ARNLEY 1032129 from Rock. Rubber for these old cars getting hard to get. Wonder how many still running>
Just learned Subaru has obsoleted them, the aftermarket boots don't last. Anybody able to help?
- Beware of Mevotech parts
replaced the alternator and now the blinkers don't work.
Anywhere to read about the relay fumes?
Fuse'd be good start. Try all other electrics to see if anything else wonky.
'83 GL brake caliper piston boot
Must I remove piston to replace it? Caliper is fine but boot is torn. Not finding any videos for these.
725191270 Lock Pin Boot
Thanx, will do. I'm in TN, will try to get that onto profile.
Any new ideas for the old intake manifold stuck bolt problem?
Induction heater may help.
Anybody know source?
EA 81 valve cover washers
THANX!! What I needed!
Called Nashville, TN (Downtown)Subaru, got a helpful parts man, reasonably sure 812764110 is the PN. Found couple sources; https://www.amayama.com/en/part/subaru/812764110 https://www.subarupartsdeal.com/parts/subaru-seal-washer-rocker-cover~812764110.html?vin=&make=Subaru&model=GL Series&year=1985&submodel=&extra1=&extra2=&filter=() Anybody know for sure??
84 Gen2 Wagon back from the grave.
Good show!!
Need PN and best place to buy. Old stuff getting scarce. Seeing plenty for newer engines. Are they same thing?
Frenkit
Anybody able to download their PDF catalogs? It keeps bringing me back around to ID form. Found this kit I think will fit my '83 GL wagon. https://www.ebay.com/itm/FRENKIT-Repair-Kit-brake-master-cylinder-120060/154201928962?hash=item23e726b502:g:7YYAAOSwQWFZdQov#vi-ilComp
Isolating Front Engine Rotating Noise..Common Problems?
Had similar with my '83, was loose distributor shaft.
1983 E81 Lock Washer for Rear Axle Nut
For future reference; 723237000 or 28487A https://www.subarupartsdeal.com/parts/subaru-lock-washer~723237000.html Is there any way to get emails of posts here?
Leaky brake master cylinder
For '83 GL, they appear to've been largely discontinued at/by parts houses here. Can?? get Raybestos MK1609 - Raybestos Element3 Brake Master Cylinder Repair Kits rebuild kit from Summit for $53.76. Anybody know cheaper option?
Is this the FPCU? (Fuel Pump Control Unit)
Will the black work to replace the blue?
Who needs keys? or locks re-keyed?
Can prob fix you up with glovebox lock, got eight 80-84s.
Welcome NDL. The one on my '83 4WD GL wagon is black and has 6 wires. Wish I knew why it turned 2nd shot sideways.
This is the FPCU on my '83 GL Wagon. Bottom row; BU/RD, hot when cranking. BK hot w/ign. on. Top row; BK, GRND w/ign. on., YEL, ign. pulse from coil/ dist. module. Quit pumping gas twice yesterday. Installing temporary jumpers to attempt "in flight" diagnosis when it quits again.
Fuel pump control unit '83 GL
Thanx y'all! Didn't realize how much the bushings were worn. Had .015" slop at top. Got blessed to find a Cardone rebuild on Ebay for $120. https://www.ebay.com/itm/REMAN-OEM-DISTRIBUTOR-42987-8110-DR480-03-FITS-SUBARU-DL-GL-BRAT-31-810/274358924769?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Superoo's back out on big road.
'80-'84 part numbers
Fixed mine, thanx to folks on new thread, Didn't realize how much the bushings were worn. Had .015" slop at top. Got blessed to find a Cardone rebuild on Ebay for $120. https://www.ebay.com/itm/REMAN-OEM-DISTRIBUTOR-42987-8110-DR480-03-FITS-SUBARU-DL-GL-BRAT-31-810/274358924769?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Superoo's back out on big road.
