12
Everything posted by Subie Gal
MAYBE 1" after settle these arent lowering springs per se they are designed with PERFORMANCE in mind. less body roll = more control lower center of gravity = better balance for the Wagon? this is the only Wagon specific option which utilized OEM struts. the only other option? Japan spec, and you'll need new struts for those. (super super stiff) Jamie Thomas Jamie at chaplins.com *************************** http://www.subiegal.com
subaru makes a specific STi Pink for your 2004 model TS see:https://www.subarugenuineparts.com/advanced_search_result.php?keywords=pink+spring&osCsid=0df280aa9f37a7fe0fa3269e7a198af2 spring rates: 223 front and 195 rear very streetable. lowers the car about 1" can be used with OEM struts not bouncy, good control! Jamie Thomas Jamie at chaplins.com *************************** http://www.subiegal.com
we can help. item would be new, from subaru To view pricing, or to order the items you have requested: 1) you will need to use our OEM catalog to access https://www.subarugenuineparts.com/oe_parts_cat.html 2) look up by part number - - 91063AC000 Shout with questions. Jamie Thomas Jamie at chaplins.com *************************** http://www.subiegal.com
um... no. and no. this is not a DIY for 99.9999% of the folks out there. I just did mine last night, with the help of a Subaru Technician only one side... and things did not go as planned took us 1.5 hours with the special tools needed to do the job. defo not something i recommend trying unless you know what you're doing and have the needed tools Jamie
got them while in the UK.... cut my bumper with a dremel and installed myself bought the washer switch, the washers, the clamps yet to install the pump, hoses, t-fitting and tubing. the US bumper beam is totally in the way I have got to sort out how to plumb and keep the large US bumper beam I am not into the JDM pencil beams. they are not safe Jamie
cheap and super hefty clutch disks do not typically go hand in hand. the beefier the disk, the beefier the pressure plate you will need the beefier the clutch kit the more pressure on your flywheel. that being said... something wrong with the OEM disk? if OE wont work for you try www.clutchmasters.com talk about hefty. they have a selection to choose from Jamie
