12
Everything posted by Subie Gal
http://techinfo.subaru.com or you can buy the paperback sections from any dealership the manuals are divided into 7-8 sections, each having a different price (electrical, suspension, chassis... etc) entire set of manuals will run you near $300... much easier to download and print off pages as you need them Jamie
thanks guys! i'll check the links - the ozified bolt on kit should be what's needed. many thanks for your input as always Jamie
what is the best? where to get it? do you need to modify or change wheels/anything to fit it? i've heard of scorpion lift kits, but that's about it. any help on these older model scoobs is appreciated. i'll keep searching for info many thanks in advance Jamie
Intake
Subie Gal replied to Skanky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
well since you asked First, learn how cams/valves work http://auto.howstuffworks.com/camshaft.htm Lets see... do you think that intaking water... when you should be intaking Air means the valves can compress the 2 the same? ummmm..... no. water will not compress... and thus bends rods/valves - like i said, already hydrolocked one engine so i've been all through this... but hey! what do i know... i'm just a girl.... some discussions, reviews and cautions about bending valves with bad intake setups - click each link for full article/information: http://www.vtec.net/forums/one-message?message%5fid=119099&thread_style=flat Water doesn't compress like air, and you can easily bend valves and rods if you get any appreciable amount of water in the cylinders http://forums.nasioc.com/forums/showthread.php?threadid=753 too much water can't be vaporized instantly. The engine creates a lot of vacuum (0 - 750mmHg or 0 - 30inHg depending on engine RPM, altitude, and throttle), thus it sucks a lot of water instantly http://www.overlander.com.au/pg/equipment.php?id=4 So why all the dire warnings about avoiding water and dust ingress? The first problem is that water is incompressible, so if a cylinder gets even what seems like a small quantity of water going into it, it may stall the engine and possibly bend a connecting rod or worse. The higher the compression ratio of the engine, the more the likelihood of damage. http://www.pps.net.au/4wdencounter/4wdtech/water.html Air Intake - Water and engines do not mix very well, and when they do it almost always results in bent pistons, valves and crankshaft. If you think this sounds expensive your right. http://www.cardomain.com/item/AEM21474B Warning for AEM CAI INTAKE: To avoid the possibility of introducing water into the intake system and hydrolocking your engine, the use of the AEM Air Bypass Valve is highly recommended. http://www.automotivearticles.com/Cold_Air_Intake_Install.shtml WARNING! Because this intake puts the air filter very very close to the ground, make sure you put the lower engine cover back on and there are no holes in it. You do not want to drive through a puddle and suck all that water into your engine. Hydrolocking a motor because you were too lazy to take 5 minutes to reattach the undercover would be a fate we wouldn't wish upon our most mortal of enemies! -
Intake
DISAGREE . emphatically. when you ingest water in this boxer 4... you will bend rods and valves and it does not take much to do so. been there done that and seen it happen to others... to each their own. go on and install and intake which sneaks down behind your fog light... it's a free country thanks god! but... when you hydrolock your engine in a 3" puddle... we will all point and laugh -
Intake
i personally know of 4 cars which have hydrolocked due to an Injun intake setup - one of them was only a 4" puddle... doh! this intake sits in the fender well near the fog lights and it's bad mojo not a good idea if you hit water often. you can avoid this type of intake or roll the dice an in the engine intake is fine but i do not recommend anything that penetrates the fender wall Jamie -
photos of me?? sure here is a recent one: there are loads of them on my site... go here: http://www.subiegal.com/images/me/about_jamie_thomas.htm anyway back to the RS You will not see massive gains with "just an intake" but add.... cat back exhaust, header, and down the line, even more goodies (cams, pistons, port n polish....) and yeah.. your NA can GOOOOO! - Jamie
hey there.. yep that's my car okay... on the grounding thing. it's quite possible someone went through and just cleaned up the grounds but many are adding a 'grounding kit'... these kits do diddly... dont care what anyone says. they look neat and that's about it. see below. yellow wiring = 'grounding kit' and on the intake. many will tell you to spend $300 and get the cobb tuning intake... www.cobbtuning.com well.. it's fancy and all but you can get the same performance for less. i run a Ganzflow intake with K&N drop in panel filter see intake here: Ganzflow intake can be found here: http://www.imprezars.com/products.htm K&N filter here: http://secure.cartsvr.net/catalogs/index.asp?category=237875&count=1 You wont see massive gains... 1-2 hp at the most but your gas mileage will improve and you will have added a reusable air filter... rather than having to spend $20 per air filter hope this helps... you can see more of my Imprezas here: www.subiegal.com cheers jamie
