sasquatch
Everything posted by sasquatch
It appears that this thin pipe joins on one end to a hose that connects to the underside of the throttle body and on the other end joins into a large pipe that snakes under the "arms" of the intake manifold and I have a sneaking suspicion ends at my A/C pump. It looks to me like the small pipe/large pipe junction is one piece so I'll have to replace it all..... thoughts?
I had a quick look....I appear to have a leak on the top part of the motor just under the throttle body intake on the driver's side....about 18mos ago a plastic t-fitting broke off in a similar position on the passenger side....it was a real PITA to find that little part (no close u-pull it yards). This make sense to anybody....I have very little time to work on this...I am home now but alone with my 1 year old....
So, my wife just got home in our '90 Legacy and said the check engine light was on and it was pissing water out the belly. I have to leave myself pretty much right now so I can't do a thorough diagnosis....I pulled up the hood, the water isn't coming from the top or bottom radiator hoses nor is it coming from near the throttle body (there is a coolant line on the passenger side)....the radiator was purchased new last year..........ideas where my issue might be? Thanks... I gotta go but will check this later on....
So I get a call from my wife...my beloved 90 Legacy wagon with 220k just died on her. I get off work and check it out (it was left at a gas station...nothing noticeable, not fouled, all wires connected, etc). DAMN!!! I push it across the steet to Ron's Automotive...who though not cheap is very well respected and gets the highest AAA rating. Turns out it was my fuel pump...$394!!! GACK!!! I couldn't find one with greater then a year warranty for less in a hurry so I went with it. The install wasn't bad though...for diagnosis, pump, install $490. When I asked what else the diag turned up the worst thing they came up with is "coolant flush". If that's the worst you can say about a car w/220K on it, you must be doing pretty good!! My car is ugly, faded, scratched, dented and KICKS A$$!
well...for awhile I'd been hearing a jangling sound from the rear of the car for awhile...couldn't find anything with the suspension or exhaust. Then yesterday I started hearing a griding when applying the brakes....I'd done the front not to long ago so figured the rear just needed doing. I check the rear passenger and I have a lot of pad left. I check the rear driver's side. I undo the lower bolt that allows the caliper to pivot upward and the whole caliper just comes right out. That upper bolt that is usually fixed (don't know the official name) apparently sheared right in two. So, now the upper part of the caliper isn't secure...I think it is boucing when I hit heavy bumps.... Anybody got a source for a replacement?
Subaru Wave?
sasquatch replied to JT95's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Here in the NW I'd never stop waving...
