Everything posted by coloradosubarules
If it has the 2.5 then you might want to ask if the headgaskets have been replaced. If my memory serves me correctly they were known for bad headgaskets. Ask when the last time the timing belt was changed as well. If the timing belt was changed ask if they changed the water pump and seals while they were in there. Hope this helps. You might want to do a search on the board for "gen1 2.5"
mudduck, if your post does not get moved automatically by an admin then you might want to post in the marketplace. Something like this: WTB: Horn for 91 loyale. You could buy one from the parts store. So where in CO did you move from? I moved to FL from CO. Is your name Jeremy by any chance? I only ask because I had a friend who went by the name of MD (mudduck because we used to talk on CB's and his was always in the weeds) Rage (because he was a huge rage against the machine fan)
Are you refering to the coil spring spacers that they sell on ebay? If so you won't have a problem if the springs are the same size as the spacers and you don't go to tall as to throw off things like brake lines..etc. I used some on my 88 XJ and they worked great. I put those thru hell and never failed me.
I do believe it would be you O2 sensor that keeps the CEL off. I gutted my cat and my CEL is off. I beleive you have an O2 before the cat and one after. I still do not believe you would have a problerm. All cats have to meet a certain standard in order to be sold. Even the high-flow cats have to be made to the EPA standards. But the $180.00 cat. You should be just fine.
Ford probe STi ooooohhhhh yeah baby!!
coloradosubarules replied to coloradosubarules's topic in Subaru Transplants
Suspisions are correct...it is a 4EAT...weither or not it is the same as the Roo will remain to be seen. I am pretty sure my Ford is a FWD only car.
