Mechanymous
Everything posted by Mechanymous
Couple of Loyales/Leones from Finland...
Mechanymous replied to Mechanymous's topic in Members Rides
Got all lifted up, I like it a lot. -
Thanks Nils, I got half of the lift done today... It has that nice 80´s stance now =D at least no rubbing anymore... -
195/70r15 some rubbing without lift and trimming
Got the 6 lug done... the tire size is 195/70r15 It´s driveable but needs some trimming and a lift of course as soon as i get that done... -
I wonder if you guys know what´s happening with my ea82 MPFI, I tightened the timing belts couple of days ago and now it feels like it has no power at lower rpm and it hesitates a long time before starting to rev. I checked timing and it seems fine, also messed with the distributor to see if that helps but I didn´t notice any change in the problem. I´m kinda baffled now. can you tighten the belts too much? -
oh man that is seriously gorgeous brat! and love the scenery... greetings from finland.
We have had a a ton of problems with the subaru boxer diesels blowing up, at least here in finland... lots of cylinder blocks have been changed cause the crank bearings fail.
Nice! I like the color, not every set of rims has to be white =) I´ve wondered why people don´t weld the extra holes in the rim shut cause that looks awesome.
Damn I love the look of that thing, I also have the same rims waiting for the lift so it´s nice to see how i´ts gonna look... someday =)
My New very first Brat '86'!! I'm so SO HAPPY!!
Mechanymous replied to Dinky26's topic in Members Rides
That is one awesome brat! -
Also started modifying the toyo rims for 6 lug conversion. I used a plasma cutter cause no one seems to have a good big lathe anymore... Before after -
Got some new rims for almost free... Tyres on them are Hankook 235/75r15 (28,8"??) which maybe be a bit too much for my project. Planning on getting 215/70r15. They´re out of a Nissan pickup and I think the offset is something like 40? I really don´t know how well they will fit with a 2" lift or if they will fit at all. -
It would be yes with a normal acid battery, but that AGM (sealed battery) can be installed in that manner. Preferably the terminals would be in the top instead on the bottom like in my car but that would look such a mess with the wiring so i´m sticking with that -
I´havent been doing anything for the green one since i decided that it has way too much rust and I don´t really have the a place right now to do anything about it. The rear crossmember is so rusted through that better just use the car as spareparts... But some tiny progress is happening with the red one, the lift and bigger tyres are in working progress and I just made some minor modifications to the battery system... I got a new AGM 80Ah battery and placed in in the location of the missing sparetyre. Have still to do some cleaning up in the brackets and everything but I like it like that =) -
Yeah I really think so too, just have to paint those rims white and do some modification first Hey guys I was wondering if anyone else has had camber problems with loyale, It seems that my green machine has severe negative camber on the rear right wheel and I haven´t been able to figure out what´s causing that. This car has a lot of rust and the previous owner used it on the forest trails, so I guess he might have crashed it at some point and bent something... I will lift it up at work next week to really see what´s going on down there but If someone has any ideas please share, will be greatly appreciated. In this picture the rear has been raised with a jack. as you can see, it´s quite bad. -
I got today a set of brand new Toyota rims for the 6 lug conversion and new winter tires 195/70r15. The wheels are Nokian Hakkapeliitta tires which in my books are the very best for Finnish winter... Got a great deal too so couldn´t pass, and now I have no more excuses not to do the 6 lug conversion =D -
Hi, You wanted me to send you the side marker lights so I was trying to figure out the best way to transfer the money between countries when it hit me! can we do a swap? I´d really like to have (USDM?) lights on my green loyale cause nobody else here has them and they´re way smoother =)
I lifted the green one up today at work to see how much rust there really is, well there was, lots of it. But nothing so serious a good couple of hours with a welder couldn´t fix ... then there was this little hole that was filled with bondo, oh how I laughed and laughed. Everyone at work said I was nuts for trying to fix it, but hey it´s my car and I love it. And besides you don´t see too many of these on the road nowadays here so they should be grateful -
I don´t know if those headlights are different from the usdm version cause I haven´t seen any up-close, but I will take better pictures next week and maybe I`ll figure it out -
I checked the prices of used side markers here in finland and they´re about 25 dollars a piece from junkyard. I propably could send them sometime if you want a pair. I have to get one for my green loyale too cause the previous owner busted it up... -
So here´s my Subys so far, the red one is -91 DL with ea82 and Mpfi. About 148000miles on it. And the green one that I just got is -87 GL with ea82 carb and has seen somewhere around 111000 miles. The DL is gonna get 2" lift, 6 lug conversion and bullbar anyday now
Hi, I´ve got loads of 2,4" (6cm) tube for free and thought i could make this sort of lift from that, would that difference to the 2" be significant for the axle wear? This loyale 3 gen. i have is my daily driver so I don´t want to hugely risk popping cv´s just at this point. I think i could shorten the tube to that 2" but of course it´s a lot more work and structurally maybe not the best thing... Oh yeah and at what angle are those lift rear plates? PS. this is my first post and thanks for all the great info.
