Everything posted by Subieguy
The transmission just started making this strange grinding noise. I thought something was wrong with the left CV axle. It was going bad. I had a new replacement so, I changed it. Didn’t help at all. I put it up on jack stands so the front wheels were off the ground. I put it in first and it would not freely move the wheels without giving it a lot of gas. It vibrates really bad too. It shifts fine. Definitely not the clutch. Paul, you wouldn’t happen to know any of the part numbers for any of the oil seals I need would you?
The transmission in my 78 Brat has gone bad. I have no idea what is wrong with it but I have a replacement transmission for it. I really am just looking for some help with finding the correct oil seals for it. Specifically the oil seals where the axles mount to the transmission and back at the shifter. The usual chronic places where our transmissions leak. Also, is there anything I can buy for the shifter bushings? Thanks. Richard
Just bought a '78 wagon
Subieguy replied to jnorion's topic in Historic Subaru Forum: 50's thru 70's
You could do either. Grind a notch or spacers. -
Just buy a carb rebuild kit for it. They are quite easy to rebuild. And if you want to use those wheels you bought, they look like EA-82 wheels you just need to grind a small notch on each one of the trailing arm where the wheel was rubbing. I did that on my first Brat 11 years ago when I did not have any other wheels to put on mine. Just make sure you put some primer or paint over the freshly ground area to keep it from rusting.It's not ideal but it can work. -
help on part number 651631150
Subieguy replied to Gopherbroke's topic in Historic Subaru Forum: 50's thru 70's
Gen 1 Brat 78-81 -
Just need a set of these and your ride will be real comfortable 2003 WRX seats
Where do I find parts
Subieguy replied to GJAnderson's topic in Historic Subaru Forum: 50's thru 70's
Welcome to the Brat. These are the same exact problems I discovered when I got my first Brat 11 years ago. Just getting more difficult as time goes on to find parts. My suggestion, parts car. They come in handy. lots of this stuff just is not made anymore. Nice to have spares. Shocks and struts,just have to keep looking or find something that will work for you. I have heard that gen 2 Brat struts will work in the front with some modification. -
Steering Wheel Removal?
Subieguy replied to spicypeanut's topic in Historic Subaru Forum: 50's thru 70's
17mm nut and a light tap. If needed. Comes off easy -
Jump seats mounting frame
Subieguy replied to NEPASubaru's topic in Historic Subaru Forum: 50's thru 70's
If they are hard to come by? I guess that depends. I got my first set of seats with no frame. It took me over a year to find a frame. After that I kept finding them all the time. And a gen 2 frame is the same. Only thing different about the Gen 2 is the headrests. The mounting holes are not in the same place. -
Parts car is your best bet. That or lots of patience. The parts pop up once in a while.
Rear Disk Conversion Donor?
Subieguy replied to TIMBERTIGER's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That will work perfect -
Will EA82 AC system work on an EA71?
Subieguy replied to spicypeanut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Uh, No. If you wanted a A/C system in your EA-71 car the dealer installed them. I took a system out of my 78 Brat when I got it. It is nothing like the system in an EA-82 car. Those early dealer installed systems were so specific for the early cars. -
Cracked heads. Very common on the turbo cars. I had a 87 GL-10 turbo wagon and a 89 GL-10 turbo wagon. Both had cracked heads
13 inch tire discussion
Subieguy replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.demon-tweeks.co.uk/motorsport/competition-tyres/maxsport-rb1-rally-tyre Now this would be a great 13 inch tire! -
About 2 months ago I bought a full set of Kuhmo 185 70 13's for my Brat. Seem like a pretty good tire -
Front struts: Good luck! Rear shocks: have to do some hunting to find them. Most of the rubber bushings are still available through Subaru. Ball joints, tie rod ends. Still available.
Check to make sure there is power getting to the fuel pump. Just unplug the wire to it and test it to see if there is any juice to it. With the ignition on. Great score by the way. Oh yeah, That is the factory console and radio too.
It's been done. Just takes a lot of modifications. The EA 82 is a much wider engine. You have the cut the inner frame rails to get clearance for the wider motor. That is just to start.
