Everything posted by Suzam
97 Legacy Power Door Locks
Suzam replied to gregB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you need to pull the door panel if you do need to replace it. It's mounted on a steel template along with the window switches. Easy enough, just be careful when removing the panel re are plastic holders that like to pull out of the panel, never to stay in again. Also there are a couple of screws to remove on the armrest and behind a plastic plug cover.. You can look on ebay for the whole group of switches, then you just unplug the old one and plug and play the replacement.
Engine code for a blown head gasket?
Suzam replied to Yoyota's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should be able to tell if the starter is engaging. Plan on replacing the motor and bid accordingly, if it is repairable you're in luck. If not hopefully the winning auction price warrants being able to afford a replacement engine if necessary. You always roll the dice with an auction, in most cases you should plan for the worst.
(FWD) FRONT WHEEL DRIVE {OPTION} ?
Suzam replied to myinhousebigdog321's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis topic comes up every so often, it goes back to the older 4 wheel drive trucks with locking hubs. These 4WD (note not AWD) vehicles need a transfer case shifted to 4WD to engage the front drive shaft, resulting in drive power going to the front differential which drive the wheels which was the reason for the locking hubs. If the hubs are not locked the front wheels spin freely because they are disconnected from the front differential which means that when the transfer case is disengaged from the front drive shaft the whole front drive system is dormant the only thing is the weight of the system itself is reducing MPG. This results in no drag loss while the vehicle is rolling. If the front wheels were locked but the transfer case not engaged the differential and front drive shaft would spin and be creating drag resulting in less MPG. This is not the way Subaru AWD works since it is engaged at all times but in the case of the automatics it is controlled by electronics as to how much drive goes between the front and back wheels.
Outback High RPMs
Suzam replied to wayman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat sounds wrong to me. I have a 2013 Legacy Ltd with the same drive train. Today it was only 15ªF when I started my car. The idle ran up to about 2,800 rpm the leveled off at about 2,200. After about a 2 minute warm up at idle I drove fairly easy on the road between 35 and 45 mph. My rpm never went higher than 3,000 in that time.
Need heater core replaced in Philadelphia, PA suburbs
Suzam replied to tbolt1003's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot sure where you went but for the future service Fulmer's Garage on Park Ave in Media has a couple of mechanics that have their own Subies. My daughter takes her 99 OBW there for most of her services.
2000 Subaru Legacy Automatic Transmission Problem? (Yanking Randomly)
Suzam replied to Janiporo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPossible torque converter lock up issue? You should observe 4 shifts plus a 5th reduction in RPMs when the converter locks. It sounds like it's possible it is trying to engage but unsuccessfully.
Cannot unlock my Subaru Outback Ltd with fob or keys
Suzam replied to gordsan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the answer to the mystery! I've changed out alternators before and sometimes grime or manufacturing lube gets on the new pulley causing the belt to slip on the power steering. After a day or so it works off and the steering is fine. It seems to cause it to slip and rumble at low slow turns almost at idle or while you start to move from a dead stop and turn at the same time. I once thought my steering rack was going out but it cleared up.
Suzam replied to gordsan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI PM'ed gordsan on 10/5 because I'm curious to learn the outcome of the problem. Hopefully we can attain closure. I re-read the post and even though she stated it was "Definitely my car, my keys.", i can't help but wonder if there is another Subaru in the family and the keys are for it. I can't tell you how many times I've grab the keys for one of the cars and had to return to the kitchen to grab the proper set. It's even more confusing when my daughter is home since I reprogrammed one of our MY01's remotes for her MY99 to replace her dead one. Try going out to the driveway and unlocking the car, getting in and wondering why the heck you can get the key in the ignition.
1998 Legacy Wagon doing weird things
Suzam replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXiPhone OS can use an ELM327 WiFi scanners. I purchased one on Amazon for $14.95 and downloaded several free basic apps and it works well with our MY99, MY01 and MY13 Subies.
Suzam replied to gordsan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI wonder what happened.
99 Outback Roof Rack Crossbars - Which way?
Suzam replied to Suzam's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was correct. I just needed the opinion of a total stranger because she always believes them over her own father! Go figure. Also the bet was a prepared meal be it breakfast, lunch or dinner. Winners choice. I haven't decided yet. Oh yeah, I did have to help her move too!
After several years off the car, my daughter put her cross bars back on the roof of her 99 OB to move. When I looked at them, they looked like they were on backwards. They are wing shaped with a thick rounded side and a sharper opposite edge. What is the correct direction for these. I'm not posting what I think is correct because I have a little side be with her!
Towbar and parking sensors (2009 Outback)
Suzam replied to rverdoold's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA friend of mine used a toilet paper roll and a tennis ball with duct tape to simulate one on his Ford Escape. For what it's worth he had no trouble on his Ford.
99 legacy 2.2
Suzam replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMY97 2.2 and later are all interference.
my first subaru
Suzam replied to nickgentry's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board and the world of Subaru! There is a ton of info on this site and a lot of informed members who will answer any questions they can. As for your key, you sometimes have to rotate or rock the steering wheel slightly to release the locking mechanism for the key. If the wheel was turned in a way that it rests hard on the mechanism you just need to move it slightly to release the lock cylinder. Move and hold the wheel to release the presure and hopefully your key should come out with some wiggling.
2014 Legacy Ltd brake won't pull off!
Suzam replied to danbeane's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 2010+ emergency brake will only disengage two ways: #1. Driver's seat belt must be buckled (then pull the e-break button outward or GENTLY tap the gas WHILE IN GEAR to release) #2. Push the brakes firmly while pulling the e-brake release. If these don't work then something else must be wrong.
Trade in or fix it? 2002 Outback H-6
Suzam replied to Xadamx1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried servicing the trans to see if it helps the problem?
Heaters in 2014-2015 Outbacks ?
Suzam replied to Robert11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOur MY13 Legacy Ltd. has the latest 2.5 engine, and we've had no problems with the couple of single digit or the low teens mornings we had this winter. When I drive any distance in cold weather, I'll take off my coat and drive in shirt or sweatshirt sleeves with the seat heater on low and the temp set at 69-71˚ for the drivers side and the wife will set the passenger side at 74˚ with the dual controls. I think it's a little better than our MY01 Outback but not by much and maybe because of the ability to customize each side with the dual heat controls.
2002-2007 Impreza
Suzam replied to methusalah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not saying ebay is the know all fitment center, but a quick search show that the same glass is for all Impreza styles. Try "SUBARU IMPREZA OUTBACK SPORT LH REAR WINDOW GLASS" as a search.
99 OBS cyclic clunk
Suzam replied to poolskaterpt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSorry I missed the 5MT in the original post. I did copy the words "torque bind symptoms" from your post, pasted into the search and got some good hits in the first 5 or 6 for definition including the MT viscous coupler.
My new 2002 Legacy
Suzam replied to Chrisderrfer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMy 2001 Outback Wagon leaks both oil and coolant. It's really more of a seeping than leak. What exactly is leaking on yours? If it's coolant, I'd confirm that the Subaru coolant conditioner (stop leak) is in the system. If you don't know, I'd do a flush and put new coolant and the conditioner in and see what happens. Oil can be leaking from several different places like cam seals, oil pump seals and valve covers, but there is a known seeping oil issue with the head gaskets that mine has been doing for several years now. It's slow so if you check your levels regularly it shouldn't be a problem. Also the timing belt maintainece is 10 years or 105,000 miles. You should confirm it was done.
99 forester lights flash after dead battery
Suzam replied to noexprnce's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLeave the key in the "run" position while you re-connect the battery, this should reset it. It may spark slightly but it's not a big draw of power. ALSO LET US KNOW how you made out. Solutions posted for problems help us all.
95 Lego LS will not start
Suzam replied to upnorthguy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you're mechanically inclined, buy a set of starter contacts. Or purchase a rebuilt starter and replace the original one. As mickc03 stated I've also had a 95. 97 and 99 that all had he same problem and new contacts cured the problem.
Spec. B liberty MIL flashing
Suzam replied to brayden's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf the engine runs normally, I would allow it time to dry out by letting it run long enough for the engine compartment to get up to operating temperature. It may just need to dry up some moisture that got in somewhere it shouldn't. Also check for anything loosened up by water pressure.
Head lights
Suzam replied to mid atlantic's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe must have been due for one.
