				Posts1091
				Days Won1
Everything posted by Suzam
	Needcoin, if you do this, please keep records of your experience for us and report back. There have been several discussions started on the idea of better gas mileage by using FWD, however some members think that with the fact that Subaru AWD has a 90% front to 10% rear distribution of torque during normal driving that the weight of the system, not mechanical drag, has a greater impact on the MPG.
	Another Delawareian! There's been some discussion about putting in a fuse and running FWD. The biggest problem is the weight, not drag on the drivetrain so little is to be gained. Search the board and you'll find the pros and cons and that most everyone who tried it got about the same milage. The only reason that I can figure anyone gets better milage is that with the fuse in the front wheels spin easier from a standing start, so you take it easier. I get about 22-24 in our MY95 sedan in daily driving, and 28-30 on a very long highway trip. In the winter it drops 1-2 MPG which I blame on the winter formulated gasoline.
	Seems to be a popular complant for 95-96 models right now, they all seem to be experiencing the plugs getting older and melting. You can put on an aftermarket plug, they come with a several inches of new wire on them. For saftey and good connection cut off the old plug then splice and solder the wires together and use electrical heat shrinking material to seal the connections. There was a couple of posts in the last week about this.
	Well it distributes power to the front and rear sets of wheels, unless there is closed a differential on either end, both AWD and 4WD will be stuck. My friend had 2 blowouts on a jeep CJ10 pickup, one front and one back on the same side during a heavy snow storm (hit a stand pipe while 4 wheeling in a construction site). He could go nowhere. The 2 rims just spun inside the tires, if 1 tire on the front and one on the back don't have traction with open differentials you are stuck even with a locking transfer case.
	I bought a set of Michelin Pilot XGT H4 from Costco about 12k miles ago, they are much quieter and smoother running than the OEMs (which only lasted me about 44k) and Costco is having a $60 off 4 tires sale right now on their web site, so if you're not a member $40 gets you a year membership. I have similar sized tires on a Toyota Camry and they have given me over 40K and so far I'm still happy with them since they still have plenty of tread. I'm hoping to get the same performance from the one's on the Outback also.
	Funny you mention this, last November I was in a gas station in Vermont where a guy pulled up and left he engine running while filling up. As soon as he was done he turned around to replace the nozzle and a guy ran up jumped into the open door (which he had left open to jam with the radio) and took off. The other thing I'm amazed by is the driver's who go into the local 7-11 for a cup of coffee and a newspaper and leave the car out front running (to warm up or whatever) and are genuinely surprised at the fact someone would steal the car.
	149K miles on MY95 2.2 and the 4EAT has developed what I would describe as a low howl coming from the front. At first I thought maybe a noise from the driver's side driveshaft. My local mechanic took a look and said the oil was low in the front differential and upon further inspection said the ATF was higher that it should be and looked contaminated. His diagnosis is a bad seal between the front dif and transmission that caused the oil to migrate and result in low lubrication and the bearing to wear. Solution is a rebuild of the tranny. For now an ATF flush and refill the gearbox. Next oil change he'll check the levels and see if they have changed any. The noise sounds similar to a rear differential gear whine I had in an old van--it begins at about 35mph and rises in pitch (not volume) as speed increases above 35. Gearing does not matter, 2, 3 and "D" make no difference in this sound. However, the whine/howl goes away when no accelerator is used, only when applying gas, and this can be a very light load on the drive train just to take up any "slack". When coasting off the gas the whine is not there. Has anyone come across this before and verify for me if this could be a seal issue? If so I guess I'm in need of some transmission repair. Or any other possibilities? So far after about 2k miles the noise is still the same, but I am keep the car at shorter trips for now.
	I agree, check your coolant level. Do a search on the board for "burp" or "burping" to make sure you remove all air in the system. The dealer didn't want to claim they knew what is was over the phone, I guess you can't blame them, too many "but you told me it was...". Plus you can go in and get charged for a sevice.
	Our MY95 Legacy automatic MPG drops every winter. Right now I'm getting an average 20-21 when I usually get 23-24 in mostly local daily driving. I think there are 2 factors in my case. #1 is the winter mix gasoline. I know the oxygenated formulation reduces my MPG. #2 is the automatic transmission (I know yours is a manual). The extended CAT warm-up in winter weather keeps the tranny from shifting into overdrive for at least the first few miles of travel. If I get on the Interstate which is .5 mile away, it revs high for 3-4 miles. I keep it under 50 until it finally shifts up. I Also know if I take a long highway trip the 29-30 MPG I get in the warmer weather drops to 27-28 in winter. Tire pressure drops in the winter a couple of pounds, have you checked them?
