Everything posted by Legourde_Nux
bonvos winter warrior
Legourde_Nux replied to bonvo's topic in Historic Subaru Forum: 50's thru 70's
No sealant on the oil pump gasket nor the cylinder head gaskets? -
Dude, the video is awesome!!!....it's both educational and the soundtrack is a killer!!!. Try Emperor and Meshuggah when you record the test drive. ...more -
Proyect: Take apart the whole truck down to the last bolt and rebuild....that's the idea. The Weber is a "must have" of course, the idea of keeping the Brat "stock" is to keep it "simple" just the way it was designed. If someone can confirm that pics 2 and 3 are EGR related.......those parts will be removed because I'm at sea-level. Never seen those 2 sensors on pic 1. Until I'm able to take apart the engine, the "bump" on pic 4 will keep me wondering if the valve blocks are from an EA63. Guys, thanks a lot.
Fuel pump - Fuel line
Legourde_Nux replied to Dan-AZ's topic in Historic Subaru Forum: 50's thru 70's
Sounds like you're loosing pressure on the fuel tank. Based on my own experience a worn out fuel cap can make your car loose pressure for the fuel pump to pick gas from the tank. Check the fuel cap. What about the fuel filter and fuel lines? -
Bypassing the vapor canister in the bedside?
Legourde_Nux replied to Tweek's topic in Historic Subaru Forum: 50's thru 70's
Thank God, we're on the same ship......getting info for a complete overhaul of my Brat. Been running mine since 93 and haven't been able to figure out what is this: http://www.facebook.com/photo.php?fbid=10151289039051536&set=a.10151287049076536.1073741825.633381535&type=3&theater It's some kind of purge valve, should have been connected to that plastic tank you mentioned Tweek -
80 Brat strut options / jump seats
Legourde_Nux replied to vwBrat's topic in Historic Subaru Forum: 50's thru 70's
Guys, thanks a lot....although I found 2 NOS Tokico cartridges where I live, I was afraid I would need to do some mods in the future. For future reference, what can be done about the height adjuster when using the KYB?....no lift kit on my Brat. -
Someone steer me the right way...80 brat
Legourde_Nux replied to Flipside7's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Regarding an overhaul kit, the EA71 does not have a timing belt or chain, it's an OHV engine. Very simple to work with, virtually bulletproof. -
Based on what I have read so far, 1980 was the last production year of the 1st gen BRAT. In that year both 1600cc and 1800cc was available, still a 1800 1 gen BRAT is rare. 2 trim levels GL (4 headlight) and DL (2 headlights). If you can put pictures, we can help. -
This one looks awesome.....it should be on a Mad Max movie....enjoy!!!!
- 104 replies
- 1
- Subaru Baja
- Safari Snorkel
(and 2 more)
Tagged with:
new to the forum not new to subaru
Legourde_Nux replied to sikend667's topic in Meet n' Greet. Your USMB Welcome Center
Whaaat?!?!?!......it got parked under and 18 wheeler or something???
