Everything posted by auto2
Recommended SOB mechanic in NJ?
auto2 replied to Lisa's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat do you need done?i work in lodi and i have someone in mind but he is always so busy you cant even park on his place.
torque bind and the FWD fuse
auto2 replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2 questions, will locked 4wd be better in the snow than awd? and the fwd fuse;there is normally no fuse in it? and putting a fuse in there completes a circut making it only 2wd for towing? but the key has to be on
96 legacy ac
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwe will eliminate all other possibility's and then assume the evap switch is bad. i had a car once that i got a universal capillary tube adj switch. taped it to the low pressure line and made my own harness to the clutch.just this car needs the fans turned on at same time. hummmm,
96 legacy ac
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok thanks! so ill jump the pressure switch and the thermal switch on compressor and see what happens. the switch on evap is hard or easy to get to?
96 legacy ac
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi got about a 1/4? can more in it. took 20 minutes with it cycling like that. up about 50 pounds. its better but not normal. why wont it run all the time with the high/low switch jumped? if i unplug the switch it wont run. jump the harness plug and it runs and cycles. i leave it like this for a few days and see how it is on the highway and if the pressure stays the same by monday. ive done many a/c jobs and this one just doesnt feel right.im missing something unless a thermol switch is acting up or this system is very sensitive to the ammount of charge.
96 legacy ac
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes that is the one. i used an paper clip.even if it was low or high shouldnt it run for a minute instead of 4 seconds before it cycles off.?
96 legacy ac
i have 30 low and 200 high side on a 60 degree F day. the a/c cycles constantly. comes out cold while its on for a few seconds. i shorted the low/high side switch and it still cycles too much.shouldnt that make it run all the time? what else is telling it to cycle? i do have a ck eng light for the knock sensor i havnt bothered to change yet.
Oil disappears and reappears 2003 Legacy
auto2 replied to WmWeikel's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi had a different brand car that had a loose dip stick tube. it moved up and down and when you checked the oill you never had the right reading unless you pushed down hard on the tube first.
97 legacy 2.2 a/c low side pressure switch
<p>where is it? is it the one on the compresser? i charged the a/c. 200 high side 30 low. if i jump the clutch aa/c works and is cold.</p> <p> </p> <p> </p> <p>nvm its fixed. was fuse 11 in main realy box that was blown</p>
97 legacy 2.2 i just picked up and axles
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks, i work in a junk yard lol. im actuallly thinking about posting next time we get a subaru in for parts if anyone needs anything here. i have a 2013 impreza and now this 97 legacy wagon.
i have driven this car a few hundred miles. loud clicking on a left turn.and some shaking at speed jacked it up and looked and there are 2 almost new axles in it. so im looking around and i see a new cat and no oil leaks anyware. looking good. then i touch the axle and there are NO roll pins in either axle!!.really? im really suprised they didnt fall off the trans. i put a used axle from a 96 gt in it and the cvd is much larger in diameter on the used one. these "new" ones look like junk. are the GT axles (2.5) physically bigger ? or are these new ones chinese junk?
will axle from 97 legacy gt 2.5 fit a 2.2
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok ill save what i can so if anyone has a need send me a ring.wish i could of stuck the whole car somewhere but the yard is full. oh and the tires are 205/55/16 and my wagon has 185/70/14 i think. gonna mess up the spedo a little.
i have a 96 legacy auto 2.2 wagon. i work in a junk yard and am cutting up a 97 legacy gt 2.5 auto. 2 things: will the left axle fit in my 96? what parts should i save? anybody need anything from the gt? the engine ran good.tranny was bad which was why it got junked.
96 legacy 3 wire a/c issue
just got this car. the a/c turned on the clutch for a sec and then the clutch shut off. so i figured it was low on freon and had a slow leak. in a rush i put a can of freon in but it made no difference. hummmmm, found my guages and i had 100 on the low and high side engine off . gave the clutch 12 volts and low side went to 40 and high side hit 300 when i reved up the engine a little. ouch! too much freon.(maybe it wasnt low in the first place?) let enough out so i have 28 on the low and 200 on the high at 55 degrees at 2000 rpm. air is ice cold when i jump the clutch but compressor wont turn on now at all. i unplugged the high side switch which made no difference.jumped the high side switch .no difference. so whats next? is the low side switch in the compressor? relay? ideas
96 Legacy EJ22 constant ticking / knocking - help with diagnosis please!
auto2 replied to roodabigman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXreally a bad idea to put new lifters on a old camshaft. but with 200,000 miles i gues you have nothing to loose.
93 Impreza ls awd 299k
auto2 replied to dannybito's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe idea behind not changing the trans oil when it hasnt been done at the right times is trans fluid is very good cleaner. and if you have lots of varnish/dirt stuck to the case the new fluid will "clean" it and all that junk may go in the valve body. but i believe what gross gary says about subarus so go for it:-)
1995 Impreza axle nightmirror and question
auto2 replied to SUBARU3's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXpoint is the amount of force requiered to get it apart will also damage it so it a no go. only way is to have it in a press and smack the axle to loosen it. leave the nut on so when you mess up the threads you can run the nut back off and clean them up. i used to work in a machine shop and one day had a axle that wouldnt come apart.i aborted and the owner came in and said to pump up the press. i said NO! and walked out. a few minutes later we heard a huge bang. i ran back there and the hub exploded out of the press and went through a cement block wall behind the press.the hub was bent, the axle ruined, a huge hole in the wall......but he got them apart lol
Totally SCREWED by AAMCO...
auto2 replied to Kilroy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwhat is the cost of buying a reman trans from subaru for that car? cause something is rotten in denmark........:-(def lawyer time. good luck
2013 impreza remote start . how does it work?
auto2 replied to auto2's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was misinformed . girlfriend said "they said to push the button twice" no one told her on the seperate remote for the start that they left in the glove box lol. problem solved and it workd very well
sent the girlfriend to the dealer to have them instal the factory subaru remote start that they programed to the key fob. how does it work? which button do i push to start the car? she said they said to push "the" button twice. i tried the door lock twice. the door unlock, it cant be the trunk or panic button?
cost of subaru maintenance
auto2 replied to mott621's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi have a 2013 with 2500 miles on it. hasnt used a drop of oil yet. impreza 2.0
- OEM Remote Start Pairing
Runs better with fuel cap loose
auto2 replied to jseabolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhave you changed the gas filter?
bluetooth on 2013
does anyone understand how this buetooth works? when i left the dealer they had both our phones working. then i added an ipod which worked but then the phones stopped working even though it says in the phone menu that they are paired to the car. i tried to fix that and now the ipod wont work??????? and now nothing works but everything says paired.
Knocking in 98 Outback
auto2 replied to 808Legacy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXrod knock to me. piston slap is more of a double knock noise.knock-knock....knock kncok..... but real fast
