Portland Locksmith for new code cut key
I haven't checked any of the other's, but Lithia doesn't have the tool anymore for the older stuff. They couldn't even cut the blank for my '91 Legacy (I bought the blanks from them). They are very good with older parts though - just apparently lost the tool or something. GD
Warped rotors - who's experienced this?
Interesting that this would have affected a "US" product because of foreign made steel but not a foreign made product . Probably an accident or a fluke of some kind. These things happen. At least they made it right for you. One also has to consider the convience factor - it's somewhat inconvient to take the rotors off and then to a shop to have them turned - even the shop I go to which has about a 15 minute turn-around on most days.... I can buy the new rotors at the same place I buy the pads (a different place does my machine work), and have the job done without any real downtime for the car. The cost difference is pretty negligable when you consider the extra gas and time for the machine and downtime of the car. I pay $31 for my rotors (I don't buy the cheapest around - I get them from a parts place I trust), and machining them off the car is probably comparable - maybe a bit less. I have on my Turbo, but not on the N/A's I was discussing in this thread. My '91 turbo has similar brakes to the late 90's LGT's, etc. They work excelent for that car. GD
EJ22 injector differences?
Yeah - that might account for those two. I also recently had the experience of working on a '90 MT sedan with 4.11, and also just did a tranny swap into a '96 sedan where I installed a '93 tranny and rear diff making it also a 4.11 car. Both EJ22's though the '96 had single port heads. The '90 was much sportier feeling where the '96 was pretty much a slug. Both ran very well and in fact the '90 had 255k on it (mobile 1 synth most of it's life), and the '96 only had 113k on it. I suppose the '96 must be slightly heavier - they apparently are a couple inches longer. GD
Loosey Goosey Noisey Shifter Problems
There's a pivot and associated bushing at the very bottom of the shifter - easier to access from the under the car. Just pull the shelf down and replace the bushing, etc. GD
It was 25 for the *first* key because it was cut by code. $8 for each copy. Yes there are cheaper - but I don't like the way the morons at Home Depot cut keys. Half the time they don't work for crap. GD
EA81 Water Pump Question and Lift Steering Extention Question
They did that as it's the only way to properly run the EA81T power steering setup. Ultimately that's what they were after and running everything from a single belt is too much - the single belt can't transfer that much power without being super tight and that leads to bearing failure in the accesories. It was done the right way - that's basically the way the EA82's are setup and it's as it should be. Just pickup an EA81T water pump - no problem. Those bolts should be fine. Can you snap them off with the steering wheel? Didn't think so..... GD
That's an EA81 Turbo water pump (and crank pulley I might add). The pulley is removable from the pump but you will need the EA81T pump to bolt your pulley to obviously. *edit* - Rockauto has em for $38. Obviously you have a good deal of EA81T parts there - is the engine not a turbo? If not then someone stripped a turbo and added them to a another hydro block.... I have a collection of those very same parts for modding an EA81 when I get the chance. Steering looks fine - it works right? As long as it works that's all that counts. GD
Ebay Timing Belt Kits Recommendation and Info
GeneralDisorder replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah - the one I received only had a single white line on it. So not very useful - I think the belt pictured may be different. The seals in the bearings were black instead of the orange in the pic - souldn't make any difference though. I just ordered two more kits for the '91 and the '95 currently in my garage. We shall see but I doubt it will have the lines. They aren't neccesary anyhow. Just as long as all three marks are straight up you are good. GD
cannot undo the control arm. any advice?
You really can't do that with EJ axles due to the punch-down ring on the nut. They don't have a cotter pin either. If they are stuck (not typical), then you can drive them out with a punch or you can use a large 3 jaw puller to push them out - only needed if the splines are rusted into the hub. Also if you hit it hard enough with the axle nut on then you won't be able to get the nut off - I've done it. GD
Oil pump leak EJ22T
GeneralDisorder replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLooks like the front main seal to me... which is in the oil pump housing so you might want to just pull the pump off and reseal the whole thing. GD
Steering rack swap ea2ej?
The tie rod ends? Probably, yeah. I think those all pretty much fit the same - or at least good enough to do the job. Or just tell me how long the EJ rods need to be, send me a set and I'll cut/weld them for you. That's like a 15 minute job with setup. I would definitely like to see where you come out on this. I would like to do the same thing with my Hatch - especially with the EJ22 swap on the horizon. GD
93 Loyale oil leak on back of engine
1 quart per 3k miles is not excessive according to Subaru. Sounds like you probably have leaky valve cover's. Just pull them off, clean up the cover and the rubber gasket - degrease them with some brake cleaner and then re-install with RTV on both sides of the rubber. Don't forget to RTV the rubber bolt washers too. Reaplacing them with new one's only lasts a short time and they begin weeping again. RTV will be permanent till you take the cover's off. GD
Well - new front rotors seems to have fixed it. No more pulsation on the off-ramps. I did the wheel bearing on one side and it looks like the other needs it too . Fun fun. GD
Clutch Noise???????
Hhhhhmmmm - questionable. If you keep track of all your parts and baggie all your nuts bolts then you can probably get it to peices ok. Changing the bearing will have to be done by a machine shop - just take them the bearing and the input shaft and ask them to swap them out. Know that reassembly is going to be the hardest part and take a lot of cleaning and careful application of sealant, etc. If you have a nice big, clean work surface I don't see why you couldn't do it. Less than $600 I'm sure. I would bet that bearing is probably around $40 to $60 or a little more. A bearing house would be cheaper than the dealer. Any of the 5 speed's from about '95 up should work. Most of the non-forester/outback one's are going to be 3.9. The neutral/reverse switches from your existing tranny will thread right in to any replacement tranny. If you are willing to fab a new 2nd cat exhaust hanger or swap the center diff housing from your existing tranny then a '90 to '94 will work also - nice thing there is that all '90 to '94 tranny's are 4.11 already. In addition to the exhaust bracket you would need to swap over the linkage adaptor - but that's just two roll pins. I just put a '93 tranny into a '96 - swapped the switches over, swapped the linkage rod adaptor, and fabbed a new exhaust bracket. Swapped in the rear diff at the same time to make the car 4.11. No - likely not. Once you open the tranny - peice of cake. You can do the same with the rear diff by removeing the back cover. Their 5 speed's are no different - suffer from the same failure eventually. It's all in how they are driven. I have a friend with a '90 Legacy that he bought new in '90 and it has 255k on the original tranny. No play in the shaft at all. Oh and if it's a hydro clutch car then you may have to swap the forks and such as well. GD
Just cut a section from the EJ inner tie rods and reweld them shorter. It's not as if inner tie-rods fail often enough that you need to be able to buy bolt-in replacements. Check out this post - there's plenty of ways you can do it: http://www.ultimatesubaru.org/forum/showpost.php?p=849578&postcount=4 GD
Sticky Speedo :D
It's the same here - odometer disclosure is not required on 10+ year old vehicles. And frankly who's to say you would even know if it had been swapped prior to you owning it..... BUT - carfax can still catch it if the car was sold when it was less than 10 years old and you lower the mileage to a point where it's less than what was on it back when it was sold. Sometimes it's unavoidable - my GF's '86 lost 18k when I swapped the cluster - that was the closest I could find in the same style cluster. GD
New front pads/rotors on both sides along with new passenger front wheel bearing (pressed in myself ), and newish axle with new grease/boots. It's almost together. We shall see in a bit..... GD
TBS-(exist for subarus?)
Book knowledge and theory built the car you are fabricating on and modifying. They must go hand-in-hand. There are things you will only learn from books and there are others that you will only learn by doing. GD
Subaru Brat side decal
There was a man.... Ed Dahl IIRC that made them and sold them on eBay although it's been several years since I looked into his offerings. You should contact a member here first - Pooparu can and has made them for folks and he does REALLY nice vinyl work - runs a decal business with a friend of his. His prices are extreemely reasonable - I can't say what he charges now but I know it was 1/3 the cost of the one's Ed produced for ebay when I talked to him a while back. He's local to me but does stuff for members here all the time - he's done entire car wraps so he very much knows what he's doing. I beleive he has a post in the vendor section too. GD
93 Loyale distributor cap/ rotor changed now fubar
No - just the two outer timing belt covers. The marks are right on the cam sprockets - 1/4" below where the belt rides. GD
I will further investigate. I spent an hour or so looking last night and unfortunately there is so much garbage being sold to people (Vortex, Helix, Tornado.... etc) that it's difficult to find anything that isn't trying to sell you something, debunk one of these craptastic wallet lightener's, or isn't replete with testing errors and unscientific conclusions. I would be willing to guess it might improve laminar flow after the TB butterfly but I can't find any real data on that either. GD
The marks are actually small holes on the outside diameter of the cam sprockets. like 1/16" holes. GD
But if the design or implementation can be improved through understanding the underlying principles of operation - would that not be important? My point is simply - if it works, great. Now lets understand why so we can make a better one...... GD
comment by sub tech re: P0420
GeneralDisorder replied to bgambino's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know - I was only joking. GD
I'm not dissagreeing with what you are saying - I agree that increased velocity in the manifold would be a desireable thing - Just wondering what the mechanism is that causes the spacer to increase the air velocity. Is it a venturi? Are they specially shaped on the inside diameter? I've never seen one of the commercially available ones..... *how* does it work? In trying to understand a new concept it is often useful to consider boundery cases. If it is desireable to move the TB away from the manifold then what would happen if you put the TB right next to the MAF and then had all that pipeing from the TB to the manifold as your spacer (mandrel bent SS tubing perhaps)? With only atmospheric pressure to work with, how is the posistion of the TB relative to the manifold going to affect velocity? And by what mechanism? The TB butterfly affects laminar flow by causing turbulence - are you saying that the spacer helps to counter-act the turbulence of the TB at the critical phase change from TB to individual intake runners? Allowing the air to "straighten out" before it enters the runners? GD
