Everything posted by odie
no clue...I pulled it the other day to check the level and the tip was missing. guess I'll look under for an oil pan...never thought about it...my old VW didn't have one.
I need a dipstick....mine broke it's tip at one of the tiny holes at the end... The tip is somewhere in the bottom of the block but given the engine block design I don't think it can be recovered without splitting the block...I don't think any damage will occur since the oil pump pickup should have a screen. I'm searching for a dipstick and need to know what all is compatible...any EA-81 dipstick? Get a universal dipstick...if so what length was the original and where are the high & low marks on the OEM dipstick?
Are brats really this expensive now?
odie replied to comatosellama's topic in Old Gen.: 80's GL/DL/XT/Loyales...
a unique vehicle with good utility value...getting quite scarce, more so in clean condition...simple, reliable, parts availability still good... if clean and rust free...yes, worth that to the right person... consider it's often cheaper to pay top dollar for a clean example than to buy a restoration project and fix 30 years of neglect... rust & body repair knows no $$$ limit -
Exhaust Manifold to Pipe Flange Gaskets
odie replied to Feanor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
hmmm...pictures or schematic would help greatly...I'll have to look at the head & exhaust pipe more closely... or am I just visualizing this all wrong..- 21 replies
what is this spacer thing? All I've noticed is the Y pipe bolt directly to the head.. Never seen anything between the two...I thought the Y pipe was the exhaust manifold.- 21 replies
what is the deal with the exhaust manifold gaskets? I can't seem to get them to last more than a day before they start leaking... the only think I can figure is that the size of the exhaust port and the size of the flange on the pipe are not matched very well. It seems the ports are smaller that the pipe flange...they have a little over lap but not much so I'm not getting a solid seal.... is it possible the Y pipe is not correct and is off another model Subie?
13 inch tire discussion
odie replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
185s at my local goodyear -
nice
Solution to speakers in a Brat - what forum ?!?
odie replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I stuck some Polk Audio 6x9s in pre-fab boxes and stuck them behind the seats...plenty loud but I must admit, the imaging leaves a lot to be desired, it's all rear. They really over power the door and dash speakers... is there an easy way to move the door speakers forward? -
I wouldn't either if it was mine. I suggest you suck it up if you want a nice Brat. Your gonna be pissed as soon as someong else picks it up. is the inside as nice as the outside? your own words from your original post....."I have seen these sell for 9 grand."
repairing plastic interior trim ?
odie replied to odie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
polyproplene(PP) based material was my guess...strong but flexible...resistant to solvents, paints, etc...difficult to glue...most epoxies state "not recommended for polypropylene" I'll check out the HF thing... -
Made an offer on a Brat...
odie replied to Subaru_dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the rust you describe sounds pretty extensive...what is not rusted is probably soon to be next I imagine....sounds like a money pit to me...unless you need a "parts brat" or just a "beater" brat... -
interior and under hood pics would be nice. Both are good deals IMHO...I'm surprised he's willing to drop to 3K on a clean looking brat....well is does seems that most of the Brats are up in the Northwest region so rarity is not the issue it is elsewhere. Quality will be remembered long after price is forgotten "Levi Straus"....buy the best condition one, most complete, most original, most rust free.....saving $500 on getting the ugly sister will not sit well with you in a months time...if even that long
What's a good expoxy for the interior plastic trim, panels and such? I tried JB Weld and it just flakes off. It had no holding power to the plastic. It's not rigid ABS plastic but some other kinda plastic with some flexibility. what type of plastic is used?
center console wiring harness, extra plug?
color codes would be nice too...but it's probably arr B&W -
convert Brat jump seat to bolt in?
pics??? might wanna mod mine. -
wow...you got a complete pic of that dash harness with all the plugs labeled? would be nice to know what all the un-connected ones go to. I'm always wondering if I should be trying to plug them all in or not worry about it. -
trick is to find the other end of the plug that the relay attached to. Prob under near the fuse box. I've got several un-plugged plugs... but my brat seems to have had some hack jobs in the past...or one universal harness for all models and option possibilities (gl, dl, wagon, etc)? Often it's cheaper to manufacture one "all-in-one" harness. -
has anyone converted their jump seat frame to a bolt-in set up? I would like to be able to remove & replace the jump seats from time to time. But the frames are welded in
I thought the bottom rack was welded into the bed? bolt out would be nice though.
hmmm...free switch for somethng else? off road lights? does it operate a relay or can the switch handle the defroster power directly? -
power windows on an old Brat???? well it does have the cruise control too which I thought was kinda over board on an 80's economy brand. I also have a rear? defroster switch, which has power to it...but there is no rear defroster??? -
odie posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
85 Brat...the wiring bundle that goes to the center console...4 plugs total...1 is the light for the ashtray. 2 are for the OEM radio. the 4th plug went no where...I'm guessing optional seperate tape deck??? has 7 wires going to it.
