mcbrat
Administrator
Everything posted by mcbrat
  1. yeah, those static pages are on my to-do list this is something else I came up with based on all the paint chips I have... http://www.ultimatesubaru.org/80s/mick/paintchips.html
  2. mcbrat replied to mcbrat's topic in Off Road
    yes, hollow to allow the bolt to go through. so, if you could find a regular newer 3.90 diff, weld it up, then use the inner cup/stub on one of the EA axles? the 3.90 VLSD out of the turbo Legacy has the solid stubs but they are different lengths. I think someone tried to use those stubs on another newer LSD diff that accepts the c-clip stubs, but it wouldn't work... I supposed you could take a 3.90 VLSD and gut the LSD part of it, and try to weld up everything inside to make a spool....????? if you could find a regular newer 3.90 diff, weld it up, then use the inner cup/stub on one of the EA axles?
  3. mcbrat posted a topic in Off Road
    I finally got around to opening up the welded diff that popped last fall at Castana... the rear stub axle on the drivers side just straight sheared off. all the welds are fine.... it also snapped off the head of the bolt.... I was running 30's and was doing a hill climb and the rear end started to bounce.... SNAP! here's a good one, and the sheared one... just replaced the stub axle, and it's ready to go.... just gotta yank the LSD back out...
  4. I didn't do anything to lower it, and I don't think anything else was done to it...
  5. He already did they are Shelby 13 x 6.5 going to be running 205/60R13s 14" x 6 Jackman Wagon wheel 15x7 Aftermarket wagon wheel - redrilled. 14x6 "flat round hole" pug steels. (Raised round holes ar 14x5.5) Subaru 14x6 Alloys. 1974 Subaru Sport Mags RW 14x6 Alloys
  6. right, get your flywheel turned to XT6 specs. if they ask what it's for or what it came out of, tell them XT6. and use a XT6 clutch kit then.
  7. any shop that turns flywheels would have to have a book that lists the specs for the flywheel. the soob flywheels are stepped, which means they have to turn 2 surfaces. the important spec is the step distance. the XT6 step is smaller, allowing for the pressure plate to be a bit closer to the clutch surface. that combined with a stronger pressure plate equate to more gripping for the clutch disc to handle the higher power output of the XT6....
  8. the clutch disc is the same for ea82 and er27 but the xt6 has a different pressure plate, and the flywheel is surfaced to different specs. if you just buy a XT6 clutch kit, then get your flywheel turned to the xt6 specs (the shop should know the specs). I'm running this setup with a 89 GL wagon D/R in my 82 Brat.
  9. here's my custom one... (not my handiwork though) http://www.ultimatesubaru.org/photos/showphoto.php?photo=1217&cat=539
  10. less than a month left.... anybody else coming?
  11. cool. I'll also have a set of (6) 15" pug alloys for sale there too...
  12. here's the bolt on one... available here... http://www.jameng.com/products/index.phtml?section=13
  13. that's okay, it's not a subaru event
  14. here's the event registration site. http://home.earthlink.net/~jhiniker/
  15. http://www.ultimatesubaru.org/forum/showthread.php?p=603837#post603837
  16. Anybody need any parts...? I will have available for potential pickup at the show.... ea81 fenders. some used, some NOS. Gen1 Brat door glass brat t-tops Nissan divorced T-Case maybe some other stuff....
  17. I took a half day off work, and went to the junkyard then had pizza and cake with wife and son. a nice relaxing evening
  18. Hatch Decals now available in Vendors Forum.....
